Issue 205 • Free Online Magazine
Issue 205 Audio Anthropology
Test Records and Demo Discs, Part One
In the days before digital music, the primary medium for sound reproduction was records. Sure, there were some who preferred reel-to-reel tapes, but they were in the minority. The turntable was king, and it had to be properly set up. Any audiophile worth his (or her) salt owned at least one or two test records specifically designed for that task.
Most such albums had test tones at various frequencies, and some had tracks that would challenge the trackability of your cartridge or help you determine whether or not your system was properly wired in phase. Many contained recordings of music (or sounds) that were meant to show off your hi-fi. In addition, a strobe pattern was often printed on the label to show whether or not the platter was rotating at the precisely correct speed. Some discs were issued by record labels, some by audio publications, and others were the product of equipment manufacturers.
Over the years, I’ve collected a disproportionate number of such discs (it helped that I worked in record stores for much of my adult life, so I could obtain the ones I wanted at reasonable prices). Here are some of them:
An Adventure in High Fidelity (1954)
One of the oldest albums in my collection predates the stereo era. This boxed release was put out by RCA Victor to demonstrate their “New Orthophonic” recording system. Along with a single LP and a turntable mat, it included a rather extensive booklet covering audio terms, with charts showing the frequency range of various instruments, and a lengthy essay by Robert D. Darrell, who “achieved international renown as an authority on phonograph records with the publication in 1936 of his Gramophone Shop Encyclopedia of Recorded Music, a pioneering work that instituted the art of discography.”
The music on the disc includes a nine-part symphonic suite commissioned by RCA and composed by Robert Russell Bennett, a highly regarded orchestrator of the time. Each part is given a paragraph noting the instrumentation. It’s worth listing the titles of the parts: “The Arrival at the Great Gates of the Castle Hi Fi,” “Welcome of the Page Boy Dynam,” “The Variable Pitch of Princess Rhumbamba,” “The Balinese Ballad of the Tweeter and the Woofer,” “The Circular Serenade of the Diamond Stylus,” “The Waltz of the Vinylite Biscuits,” “The Tomb of the Ogre Distortion,” “Blasphemy of the Amplifier,” and “The Full Frequency Fountain of Farewell.” Clearly, Mr. Bennett imbued his commission with equal parts of seriousness and whimsy. The notes for the finale concluded with: “It leaves the listener overwhelmed by a sonal (sic) experience unlike any he ever can have known before – a dream of High Fidelity that Bennett, his musicians, and RCA Victor engineers have made an incomparable reality.”
The rest of the music on the LP ranges from classical to opera to pop/easy listening. And yes, it’s a mono “Shaded Dog” pressing.
Elektra Playback System Calibration Record (1956)
This was a 10-inch pressing from the Elektra record label. In contrast to the above album, it consists entirely of test tones at various frequencies with no musical selections. The notes say: “The purpose of this record is to provide a standard for the calibration of playback mechanisms designed for 33-1/3 microgroove recordings.” It is interesting to note that the mastering was done without the high-frequency pre-emphasis inherent in the RIAA equalization curve. The explanation given is that, “in order to make a test record according to the standard pre-emphasized characteristic, the average level would have to be impractically low.” I have to believe that this limitation has been overcome in modern pressings, as most of my other, newer test records utilize the standard pre-emphasis.
For those unfamiliar with the RIAA (Record Industry Association of America) curve, it is an equalization standard that boosts the high frequencies and attenuates the low frequencies presented to the mastering lathe, relying on an inverse equalization curve (provided in all phono stages) to achieve flat response upon playback. This process results in reduced surface noise, improved trackability, and greater playing time per side because the grooves can be closer together. In the early days of LPs, different labels had different curves, and hi-fi preamps often allowed you to select from as many as four or five varying standards. The adoption of the RIAA curve as universal occurred around the mid-1950s.
CBS Laboratories Broadcast Test Record (Date unknown)
This is another seriously technical test record with tones but no music. One side is for monaural reproduction and the other side is for stereo. Unlike the Elektra record, the disc was mastered with the full RIAA curve, as evidenced by the chart of said curve printed on the back. A unique feature of the album is the inclusion of strobe patterns for 33-1/3 and 45 RPM actually pressed into the plastic as the last bands on sides one and two. In this case, rather than serving as visual indicators, the patterns are intended to be played into an oscilloscope to determine speed accuracy.
Seven Steps to Better Listening (1964)
One more from CBS Laboratories – this time intended more for the non-professional audience. The seven steps address channel identification (left/right), phasing, balance, tone settings, channel separation, elimination of buzzes and rattles, and adjustments to reduce record wear.
The notes state: “Whether you are an advanced High Fidelity enthusiast, and/or a down-to-earth lover of good music, you will find SEVEN STEPS TO BETTER LISTENING an invaluable key to musical enjoyment. You will learn to depend upon it to adjust your equipment, regardless of cost, whether it is new or old, and also to appraise the true capability of any equipment you plan to purchase. You will use it again and again because it shows how to improve the quality and naturalness of reproduction of all your records, and enables you to capture the true spirit of each performance.” Lofty words, indeed.
The accompanying booklet says, “PLEASE READ BEFORE PLAYING THIS RECORD,” followed by the line “This record is self-explanatory.” While that would seem contradictory, the point is that you are being warned not to play side A with a monaural cartridge/stylus. (By the way, explanatory is misspelled as expanatory.) The notes were written by Audio magazine’s Edward Tatnall Canby, a highly-regarded audio writer of the time.
CBS Laboratories SQ Quadrophonic Test Record (1973)
Wow – remember Quad? Twice the speakers, twice the amplifier channels, twice the setup headaches, three times (SQ, QS, CD-4) the formats!
I have to believe that my copy is missing a booklet, as the track listings on the back (and label) include some seriously technical jargon, e.g., “1kHz, 0 dB channel level, Right Back – Counterclockwise Helical Modulation, 3.54 cm/sec–Right +90º rel left, each 2.5cm/sec rms.”
Phew! Glad I didn’t go down that rabbit hole in the ’70s. Why do I even own this record?
An Introduction to the World of SQ Quadrophonic Sound (1973)
The category is Most test and demonstration albums from a single label” (at least in my collection). And the envelope goes to… Columbia/CBS! Bonus – “This disc may also be played on any conventional stereo system as any other high fidelity recording.”
Another unnecessary acquisition, but at least I can listen to this, as it’s all music and no test tones, but do I really want to hear Andy Williams sing “MacArthur Park”?
The next installment in this series will feature test records issued by various stereo equipment manufacturers.
More from Issue 205
View All Articles in Issue 205
#234 A Life in High-End Audio: The Roy Hall Interview, Part One by Frank Doris Sep 07, 2026 #234 Jason Greenlaw Offers His Personal Perspective on Jazz Guitar in Vantage Point by Frank Doris Sep 07, 2026 #234 Transcendent Phoenix: Lucina Yue Brings the Ancient Konghou Into Modern Times by Frank Doris Sep 07, 2026 #234 We Must All Follow Our Bliss by B. Jan Montana Sep 07, 2026 #234 How to Play in a Rock Band, 27: Leveling Up by Frank Doris Sep 07, 2026 #234 Ross Valory: Traveling Into New Musical Territory With All of the Above by Ray Chelstowski Sep 07, 2026 #234 Singer/Songwriter John David Schrader: On the Need to Create by Joe Caplan Sep 07, 2026 #234 The People Who Make Audio Happen: More From T.H.E. Show SoCal 2026 by Harris Fogel Sep 07, 2026 #234 The Vinyl Beat Digs Into the Gadget Box by Rudy Radelic Sep 07, 2026 #234 The Rolling Stones: Foreign Tongues Spoken Loud by Wayne Robins Sep 07, 2026 #234 Musical Moments by Rich Isaacs Sep 07, 2026 #234 Rags for Solo Piano and a Dog: David Chesky's Ragtime Music for the Modern Age by Frankly Speaking Sep 07, 2026 #234 HIGH END 2026, Vienna: Here to Stay by Carsten Barnbeck Sep 07, 2026 #234 From The Audiophile’s Guide: The Two Main Types of Loudpeakers – Box and Panel by Paul McGowan Sep 07, 2026 #234 Letting it Slide by Frank Doris Sep 07, 2026 #234 PS Audio in the News by PS Audio Staff Sep 07, 2026 #234 Long Playing by Peter Xeni Sep 07, 2026 #234 La Mer by B. Jan Montana Sep 07, 2026 #233 A Report From The Total Hi-Fi Experience Show SoCal 2026 by B. Jan Montana Aug 03, 2026 #233 Bluegrass Meets Country, Folk, Jazz and More in All That We Carried by The Squid City Slingers by Frank Doris Aug 03, 2026 #233 Corey Glover and One Tribe Nation: A Variegated Musical Collective by Ray Chelstowski Aug 03, 2026 #233 Excursions with Clive: The Late Clive Davis, A Personal History by Wayne Robins Aug 03, 2026 #233 AI, Art, and Music: A Conversation With Synthography Art by Joe Caplan Aug 03, 2026 #233 New American Symphonies: A Rediscovered Gem and a Vital Contemporary Work by Frank Doris Aug 03, 2026 #233 The Vinyl Beat: Genesis, the Dave Clark Five, Antonio Carlos Jobim and More by Rudy Radelic Aug 03, 2026 #233 How to Play in a Rock Band, 26: When It's Time to Record Your Music by Frank Doris Aug 03, 2026 #233 More From T.H.E. Show 2026, and the People Who Made it Happen by Harris Fogel Aug 03, 2026 #233 Underappreciated Artists, Part Three: Icehouse by Rich Isaacs Aug 03, 2026 #233 The Surprisingly Rich and Varied Music of Somalia by Steve Kindig Aug 03, 2026 #233 A Remarkable Discographic Legacy: The LP Recordings of the Basel Symphony Orchestra by Stephan Haberthür Aug 03, 2026 #233 From The Audiophile’s Guide: The Importance of Loudspeakers by Paul McGowan Aug 03, 2026 #233 From Swimming Pool to New Listening Room: A Conversation with Norman Varney of AV RoomService by Gilles Laferrière Aug 03, 2026 #233 PS Audio in the News by PS Audio Staff Aug 03, 2026 #233 Audio Jewelry by Peter Xeni Aug 03, 2026 #233 Enrich Your Life by Frank Doris Aug 03, 2026 #233 The Searcher by James Schrimpf Aug 03, 2026 #232 What came first: Art or Music? A Conversation With Artist Jose Acosta by Joe Caplan Jul 06, 2026 #232 Blow By Blow: The Jeff Beck Story: An Insightful Book About a Guitar Icon by Ray Chelstowski Jul 06, 2026 #232 Creed Over Camaraderie? by B. Jan Montana Jul 06, 2026 #232 Chronicles of a Sound Pilgrim at the 2026 Montreal Audiofest by Hugues Morin Jul 06, 2026 #232 The Vinyl Beat: Summer Grooves by Rudy Radelic Jul 06, 2026 #232 Hibbing Hillbilly Dylan's Acoustic Rock by Wayne Robins Jul 06, 2026 #232 Quad Quads and Plasmatronics Tweeters: An Extraordinary System Comes to Life by Frank Doris Jul 06, 2026 #232 In Praise of Live Music, Once Again by Ted Shafran Jul 06, 2026 #232 Allnic Audio’s L-9000 Preamplifier: Design and Engineering Innovation by Howard Kneller Jul 06, 2026 #232 “Best Of” Lists and Rage Bait: Enough Already by Frank Doris Jul 06, 2026 #232 Quick Takes: Bud Shank, Paulo Almeida, Jakob Dreyer, Tim Eriksen and Peter Irvine by Frank Doris Jul 06, 2026
