Copper Magazine · Issue 218 · A free PS Audio publication
Issue 218 PS Audio in the News
PS Audio in the News: PMG Signature Series Audio Components Make Their Debut
PS Audio has announced its all-new PMG Signature Series of top-of-the-line ultimate-performance audio components. The four models in the series include the PMG Signature Preamplifier, PMG Signature 512  PureStream DAC, PMG Signature Phono Preamplifier and PMG Signature SACD Transport. All are designed from the ground up.
PMG Signature components feature a stunning new appearance, with 1-1/2-inch thick machined aluminum front panels accented by a sweeping curved design. The front panel indicators are also touch-sensitive controllers, offering immediate control of all functions from an intuitive menu system. All PMG Signature models can also be operated by a newly-designed remote. Available in silver or black, the chassis have an elegant textured finish that complements any system and living environment. All models feature a chassis-within-a-chassis design for maximum isolation, premium internal parts, multi-layer circuit boards, and other refinements.
PMG Signature Preamplifier.
The Paul McGowan Signature Preamplifier is PS Audio’s new flagship. With a vanishingly low noise and distortion floor of -150dB, the preamplifier uncovers musical truth with explosive dynamics, infinite depth, and holographic imaging. Designed by acclaimed engineer Darren Myers, it’s fully balanced from input to output.
Its revolutionary power supply eliminates traditional electrolytic capacitors, replacing them with long-life, sonically superior film capacitors. The results are lightning-fast transient response, deeper silence, and greater dynamic swings. The preamp housed in a double chassis construction that shields against noise and interference.
The PMG Signature Preamplifier incorporates a completely reimagined gain stage. The design blends FET (field effect transistor) and BJT (bipolar junction transistor) technologies, combining the finesse and linearity of FETs with the dynamic control and drive of BJTs. Fully complementary from input to output, the gain stage operates in pure Class A, direct-coupled and servo-controlled for absolute signal integrity.
What sets this circuit apart is its innovative take on folded cascode topology. Traditional cascodes use stacked transistors to improve gain and bandwidth, but the folded version "bends" the signal path, allowing high voltage swings, low noise, and wide bandwidth without the instability or harshness of conventional designs.
PMG Signature 512 DAC.
At the core of the PMG Signature 512 DAC is the new PureStream DSD512 engine, converting any form of digital audio into a pure 8X-DSD stream – there are no PCM circuitry, no decimation filters, and no engineering compromises. The 8X-DSD stream feeds a newly-designed SpectraWave 64-tap sequencer, a digital filter that lowers noise and distortion while perfectly time-aligning the signal. From there, it flows into a direct-coupled analog output stage. This is a radical departure not only from traditional PCM-based architectures but also from conventional DSD implementations and off-the-shelf chip solutions.
The PMG Signature 512 incorporates PS Audio’s Digital Lens technology, ensuring that incoming digital data is perfectly reorganized and re-clocked before ever reaching the PureStream engine. With a fully-balanced, direct-coupled analog output stage, galvanically isolated inputs, a built-in high-performance music streamer, and precision analog volume control, the PMG Signature 512 is not just a DAC; it can serve as the centerpiece of a no-compromise reference system.
PMG Signature Phono Preamplifier.
The PMG Signature Phono Preamplifier was designed from the ground up by Darren Myers. It features a cutting-edge transimpedance input and a zero-feedback topology that strips away distortion, coloration, and noise. With dual inputs for both moving coil and moving magnet cartridges, and remote-controlled loading and gain options, the PMG Signature Phono Preamplifier adapts effortlessly to any system.
Its fully-discrete FET design delivers massive headroom, ultra-low noise, and explosive dynamics. From the beginning, this was going to be a no-compromise design. There’s not a single op-amp or integrated circuit in the signal path. Instead, every stage is constructed from hand-selected, discrete FETs and BJTs, operating in pure Class A.
The topology is fully complementary and direct-coupled – chosen not for cost considerations, but for its ability to deliver the lowest distortion, the highest resolution, and a complete absence of a sonic fingerprint. The result is astonishing headroom, ultra-low noise, and lightning-fast transient response, capable of reproducing the most delicate nuances and the most explosive dynamics with equal ease.
The Signature Phono Preamplifier’s transimpedance input gives cartridges a direct, uncolored path to amplification, eliminating loading concerns and revealing unmatched detail, texture, and space. For a more traditional approach, the voltage input offers adjustable gain and loading, all controlled remotely.
At the heart of PMG Signature Phono Preamplifier lies a bold and uncompromising design decision: the complete elimination of global feedback. Using high-voltage discrete FETs and hand-selected bipolar transistors in a fully complementary topology, this phono preamp achieves something few engineers have dared attempt – a true zero-feedback phono stage with vanishingly low noise and distortion.
The PMG Signature SACD Transport connects a DAC to the hidden magic of pure DSD that’s been locked away in SACD discs. With galvanically isolated outputs and an ultra-low jitter design, it breathes new life into a CD collection when paired with any DAC. When connected via I²S, it unlocks the raw DSD layer of SACDs, delivering what was once hidden to external DACs.
New to this model, and for that matter, any disc player ever made, is the inclusion of PS Audio’s galvanically isolated output stage. By coupling the output of the drive mechanism to the transport’s internal Digital Lens by a pulse of energy across space, any hints of noise or ground contamination are eliminated. The results of this complete electronic isolation is a previously unheard level of image separation, openness, and effortless reproduction.
PS Audio PMG Signature components will be available at a suggested US retail price of $8,499 each. Availability will be in the third quarter of 2025.
Header image: PMG Signature Series Signature 512 DAC.
More from Issue 218
View All Articles in Issue 218
#236 Magic Boy: The Jimi Hendrix Experience, Live and Rediscovered by Frank Doris Nov 02, 2026 #236 The Great Rhythmic Divide: Composer David Chesky Asks, Why Doesn't the Symphony Orchestra Groove? by David Chesky Nov 02, 2026 #236 More Record Reviews: Roni Eytan’s Microtonal Harmonica, Jane Ira Bloom, and a Frank Zappa Freak Out by Frank Doris Nov 02, 2026 #236 An Album of Inviting Beauty: Goodnight Moon from Acoustic Eidolon, And an Interview With the Artists Who Created it by Frank Doris Nov 02, 2026 #236 Never Ignore Your Inner Voice by B. Jan Montana Nov 02, 2026 #236 Composer Joseph Bertolozzi Uses Bridges, Structures and the World as Musical Instruments, Part One by Joe Caplan Nov 02, 2026 #236 Transmission: A Powerful Horn-Loaded Album from the Huntertones by Ray Chelstowski Nov 02, 2026 #236 Les Quatre Saisons du Québec: a New “Four Seasons” on Tour and on ATMA Classique by Robert Schryer Nov 02, 2026 #236 From The Audiophile's Guide: A Glossary of Terms for Today's Audio Systems, A – M by Paul McGowan Nov 02, 2026 #236 From The Listening Chair: An Introduction to Audiophile Tweaks by Howard Kneller Nov 02, 2026 #236 The Vinyl Beat Grew Two Inches Since October! by Rudy Radelic Nov 02, 2026 #236 How to Play in a Rock Band, Part 29: Figuring Out How to Play the Songs by Frank Doris Nov 02, 2026 #236 The Return of the Residents: Eskimo is On the Road by Wayne Robins Nov 02, 2026 #236 PS Audio in the News by PS Audio Staff Nov 02, 2026 #236 The People Who Make Audio Happen – Fun In Las Vegas at…CES 2026? by Harris Fogel Nov 02, 2026 #236 The Forms of Things Unknown by Frank Doris Nov 02, 2026 #236 Prophetic by Peter Xeni Nov 02, 2026 #236 Here's Looking at You, Kid by Rich Isaacs Nov 02, 2026 Favorites From T.H.E. Show SoCal 2026 by Cam Martin Oct 05, 2026 #235 Singer/Songwriter John David Schrader: On the Need to Create, Part Two by Joe Caplan Oct 05, 2026 #235 A Life in High-End Audio: The Roy Hall Interview, Part Two by Frank Doris Oct 05, 2026 #235 Grammy-Winning Producer, Songwriter, and Guitarist John Leventhal Goes Instrumental With National Drift by Ray Chelstowski Oct 05, 2026 #235 From Swimming Pool to New Listening Room—to Founding an Accidental Audio Company by Gilles Laferrière Oct 05, 2026 #235 The Vinyl Beat’s Size Matters Edition by Rudy Radelic Oct 05, 2026 #235 The Sublime Complexities of Nature by B. Jan Montana Oct 05, 2026 #235 How to Play In a Rock Band, 28: Growing Older and Dealing With It by Frank Doris Oct 05, 2026 #235 Young Rascals: From Bar Band to Stardom by Wayne Robins Oct 05, 2026 #235 Duncan Sheik: In Memoriam by Ray Chelstowski Oct 05, 2026 #235 From The Listening Chair: The Meze Audio 105 Silva Headphones by Howard Kneller Oct 05, 2026 #235 Checking Out Some NOLA Loudspeakers – and Some Thoughts About Audio Writing by Frank Doris Oct 05, 2026 #235 The Kanazawa Phonograph Museum: Music from a Time Capsule by Sebastian Polcyn Oct 05, 2026 #235 PS Audio in the News by PS Audio Staff Oct 05, 2026 #235 From The Audiophile’s Guide: Making the Most Critical Choice by Paul McGowan Oct 05, 2026 #235 Evolutionary Growth by Frank Doris Oct 05, 2026 #235 Speed Racer by Peter Xeni Oct 05, 2026 #235 Happy Halloween! by James Schrimpf Oct 05, 2026 #234 A Life in High-End Audio: The Roy Hall Interview, Part One by Frank Doris Sep 07, 2026 #234 Jason Greenlaw Offers His Personal Perspective on Jazz Guitar in Vantage Point by Frank Doris Sep 07, 2026 #234 Transcendent Phoenix: Lucina Yue Brings the Ancient Konghou Into Modern Times by Frank Doris Sep 07, 2026 #234 We Must All Follow Our Bliss by B. Jan Montana Sep 07, 2026 #234 How to Play in a Rock Band, 27: Leveling Up by Frank Doris Sep 07, 2026 #234 Ross Valory: Traveling Into New Musical Territory With All of the Above by Ray Chelstowski Sep 07, 2026 #234 Singer/Songwriter John David Schrader: On the Need to Create by Joe Caplan Sep 07, 2026 #234 The People Who Make Audio Happen: More From T.H.E. Show SoCal 2026 by Harris Fogel Sep 07, 2026 #234 The Vinyl Beat Digs Into the Gadget Box by Rudy Radelic Sep 07, 2026 #234 The Rolling Stones: Foreign Tongues Spoken Loud by Wayne Robins Sep 07, 2026 #234 Musical Moments by Rich Isaacs Sep 07, 2026
