Copper Magazine · Issue 232 · A free PS Audio publication
Issue 232 Paul's Place
Budgets, and Systems From Small to Outrageous
The cost of building a high-performance, audiophile-grade two-channel stereo system can span quite a range, from next to nothing to more than the cost of some homes. I’ll let you in on a secret, though: there’s often little correlation between stereo cost and performance.
In the half-century I’ve devoted to the high-end audio industry, I’ve heard every manner of system. Some of the very worst have been the most expensive, and some of the best were quite affordable. Like anything else in our lives, simply throwing money at a problem or a project doesn’t guarantee success. In fact, unless you’re equipped with some basic knowledge, your investment may backfire. Without adequate information, preferably coupled with a knowledgeable, trusted guide to steer you in the right direction, plowing your hard-earned money into a two-channel audio system can be a real crapshoot.When someone asks me what equipment to buy, I start with a series of three questions:
What are your goals?
What are your limitations?
What is your budget?
Let’s follow that same process here.
What Are Your Goals and Limitations?
This simple question is often the hardest for people to answer, or at least to put into words. Typical answers range from a simple “just give me good sound” to “I want the biggest, baddest, most bone-rattlingly killer sound system on the planet.” These answers are adequate to get us started, but the real answers I’m looking for would go something closer to this:
“I’m hoping to set up a modest system in my living room that the family can easily use for everyday listening; and on occasion, I want to crank it up and have it sound like there’s a rock band playing in my living room.”
Or, “I’m looking for a small, unobtrusive set of speakers to go on either side of my television – something that can render classical and jazz in lifelike proportions and that I can easily switch to play the television audio.”
Or, “I want a no-holds-barred high-end system that just blows me and my friends away.”
Answers like these give me a better idea of where to point you in terms of equipment choices and budget.To help you understand how this can be applied in the real world, let me tell you about my own home setup. While at work, I get to enjoy one of the greatest high-performance two-channel reference systems in the world; PS Audio’s Music Room with its amazing Aspen loudspeakers and full-on PS Audio electronics set, but at home it’s a different story. My wife, Terri, wanted to build our home system herself. Since she too loves music and high-performance audio, I took her through my three questions to help identify her priorities. Her answers looked something like this:
 Goals:
A turntable-based system with the ability to stream radio, Pandora, Tidal, and Qobuz
Full-range but it’ll never be played at live concert levels
The speakers need to sonically disappear
Limitations:
Must be small in footprint and not intrusive on the décor
Must be simple to operate so even our grandkids can use it
Budget: $4,000 maximum
With these answers in mind, it was easy for Terri to start her search and come up with her dream system. Here’s what she ended up with:
Turntable: Rega P3 with MM cartridge ($1,100)
Amplifier: PS Audio Sprout100 (discontinued)
Speakers: KEF LS50 ($1,200) (later upgraded to PS Audio Aspen FR5s [$4,400 for the pair])
Subwoofer: REL T5i ($600)
Cables ($200)
System total: ~$3,800
This system images beautifully, sounds great, and achieves Terri’s goals. Had she been a little less particular about primarily playing vinyl records, she could have gotten the same quality at an even lower cost.So, step one is to think about what you hope to achieve with your system. In other words, write down your goals. Step two factors in your limitations, such as where the system will be placed and how much real estate and visual prominence you and your significant other are willing to cede to the system. Once you’ve identified the answers to these two important questions, we can move on to the third question of budget. How much are you willing to invest in great sound?
What Is Your Budget?
Now that you’ve identified your goals and limitations, let’s talk budget. I’ve broken down system types into three general categories: the Casual System, the Serious System, and the Whacked-Out System. For a point of reference, my home system I just described might fall into the upper end of the Casual System category, while the PS Audio Reference System would most certainly land in the Whacked-Out category.
Casual Systems
The vast majority of serious two-channel audio systems would fall into this first category. We want great sound and we’re willing to spend a few bucks and invest a few hours of setup to get there. For a Casual System, you should plan to budget between $1,000 and $6,000 for everything you need. Next, select the various pieces of equipment from trusted manufacturers of two- channel separates. You’ll be able to identify these manufacturers because:
You’ve done a little homework, by reading this book, to find out whether or not they’re invested in bringing life to music
Their products are purpose-built, to provide a specific outcome for a limited set of variables
They’re respected by the greater high-end audio community
Their stated goals are to honor musical truth
Serious Systems
Serious Systems are more committed to a single person listening with intent. Their primary purpose is to help the listener forge a more intimate connection with the music than is possible with the Casual System, recreating  a more believable live performance in the home. That means they require more money to build, more space in the room to place, and more time and care to set up. For the Serious System you’ll need to budget between $3,000 and $30,000 for everything you need. Now, for those unfamiliar with high-end audio, 30,000 smackaroos might at first seem like either a misprint or insanity; but I assure you, among audiophiles it’s a perfectly normal investment. The average Serious System falls somewhere in the middle of this price range, hovering between $8,000 and $15,000, though I’ve heard some great Serious Systems that people cobbled together for around $8,000.
Then select the various pieces of equipment from trusted manufacturers of two-channel separates, using the criteria mentioned before.
PS Audio's Summit system costs $15,000 and includes the StellarGold DAC/preamp, two M1200 monoblock amplifiers, a Stellar P3 PowerPlant, a pair of Aspen FR10 speakers, and AudioQuest cables and interconnects.
Whacked-Out Systems
As the name of this level implies, the sky’s the limit. I’ve seen some seriously unbelievable setups exceeding a million dollars, but for the most part you can put together a beautiful and impressive Whacked-Out System for as low as $15,000. More likely, though, the sweet spot’s going to start at $25,000 or so. The keys for a Whacked-Out System to be worth its cost in both time and effort include skill, knowledge, and tireless effort, in addition to going for the cost-is-no-object components that synergistically mesh into audio nirvana. This level of system needs a personal guide and is certainly not for the faint at heart. Once built and experienced, though, there’s few pleasures on Earth that compare.
This Clarisys Audio speaker system and associated electronics shown at Florida Audio Expo 2026 costs about half a million dollars. Courtesy of Frank Doris.
For the Whacked-Out System you’ll need to budget at least $25,000 and more likely closer to $50,000 and up. It’s not uncommon that all the electronics in these upper-end systems are sourced from one manufacturer, but electronics are only a third of the battle. We still have loudspeakers, cables, AC power systems, and the room itself to conquer. Thus, in most Whacked-Out Systems, perhaps the electronics are of the same breed, but then the loudspeakers, cables, AC power components, room and tuning products are likely from a variety of vendors. In these systems, everything matters. Components are chosen for performance as well as synergy within the chain.
Few manufacturers produce components worthy of a Whacked-Out System, though claims to the contrary often overwhelm one’s search for the perfect component. Aside from a great deal of research via forums, reviews, audio tradeshows, and connections to others with similar goals, a personal guide is really helpful (that’s my goal through this series of books). These guides can also be found at the companies making the components, a trusted dealer, or a fellow traveler along the path to audio nirvana.
(Shameless plug: one of my long-term goals at PS Audio was the building of a complete system with proper synergy between electronics and loudspeakers—the most difficult combo to get to play nice with each other. Now, with the introduction of PS Audio’s Aspen loudspeakers, the circle is complete.)
The bottom line is that truly great sound can be obtained in your home for under $1,000. It’s not all about the money! It’s far more important to understand what you want to achieve, then approach it methodically to make the most efficient use of your money, your time, and the real estate in your home you’re willing to devote to music.
Header image: the PS Audio Foundation system ($5,000) including a Strata MK2 integrated amp with DAC and phono stage, Stellar P3 Power Plant, Aspen FR5 speakers with stands, and AudioQuest Rocket speaker cables.
More from Issue 232
View All Articles in Issue 232
#236 Magic Boy: The Jimi Hendrix Experience, Live and Rediscovered by Frank Doris Nov 02, 2026 #236 The Great Rhythmic Divide: Composer David Chesky Asks, Why Doesn't the Symphony Orchestra Groove? by David Chesky Nov 02, 2026 #236 More Record Reviews: Roni Eytan’s Microtonal Harmonica, Jane Ira Bloom, and a Frank Zappa Freak Out by Frank Doris Nov 02, 2026 #236 An Album of Inviting Beauty: Goodnight Moon from Acoustic Eidolon, And an Interview With the Artists Who Created it by Frank Doris Nov 02, 2026 #236 Never Ignore Your Inner Voice by B. Jan Montana Nov 02, 2026 #236 Composer Joseph Bertolozzi Uses Bridges, Structures and the World as Musical Instruments, Part One by Joe Caplan Nov 02, 2026 #236 Transmission: A Powerful Horn-Loaded Album from the Huntertones by Ray Chelstowski Nov 02, 2026 #236 Les Quatre Saisons du Québec: a New “Four Seasons” on Tour and on ATMA Classique by Robert Schryer Nov 02, 2026 #236 From The Audiophile's Guide: A Glossary of Terms for Today's Audio Systems, A – M by Paul McGowan Nov 02, 2026 #236 From The Listening Chair: An Introduction to Audiophile Tweaks by Howard Kneller Nov 02, 2026 #236 The Vinyl Beat Grew Two Inches Since October! by Rudy Radelic Nov 02, 2026 #236 How to Play in a Rock Band, Part 29: Figuring Out How to Play the Songs by Frank Doris Nov 02, 2026 #236 The Return of the Residents: Eskimo is On the Road by Wayne Robins Nov 02, 2026 #236 PS Audio in the News by PS Audio Staff Nov 02, 2026 #236 The People Who Make Audio Happen – Fun In Las Vegas at…CES 2026? by Harris Fogel Nov 02, 2026 #236 The Forms of Things Unknown by Frank Doris Nov 02, 2026 #236 Prophetic by Peter Xeni Nov 02, 2026 #236 Here's Looking at You, Kid by Rich Isaacs Nov 02, 2026 Favorites From T.H.E. Show SoCal 2026 by Cam Martin Oct 05, 2026 #235 Singer/Songwriter John David Schrader: On the Need to Create, Part Two by Joe Caplan Oct 05, 2026 #235 A Life in High-End Audio: The Roy Hall Interview, Part Two by Frank Doris Oct 05, 2026 #235 Grammy-Winning Producer, Songwriter, and Guitarist John Leventhal Goes Instrumental With National Drift by Ray Chelstowski Oct 05, 2026 #235 From Swimming Pool to New Listening Room—to Founding an Accidental Audio Company by Gilles Laferrière Oct 05, 2026 #235 The Vinyl Beat’s Size Matters Edition by Rudy Radelic Oct 05, 2026 #235 The Sublime Complexities of Nature by B. Jan Montana Oct 05, 2026 #235 How to Play In a Rock Band, 28: Growing Older and Dealing With It by Frank Doris Oct 05, 2026 #235 Young Rascals: From Bar Band to Stardom by Wayne Robins Oct 05, 2026 #235 Duncan Sheik: In Memoriam by Ray Chelstowski Oct 05, 2026 #235 From The Listening Chair: The Meze Audio 105 Silva Headphones by Howard Kneller Oct 05, 2026 #235 Checking Out Some NOLA Loudspeakers – and Some Thoughts About Audio Writing by Frank Doris Oct 05, 2026 #235 The Kanazawa Phonograph Museum: Music from a Time Capsule by Sebastian Polcyn Oct 05, 2026 #235 PS Audio in the News by PS Audio Staff Oct 05, 2026 #235 From The Audiophile’s Guide: Making the Most Critical Choice by Paul McGowan Oct 05, 2026 #235 Evolutionary Growth by Frank Doris Oct 05, 2026 #235 Speed Racer by Peter Xeni Oct 05, 2026 #235 Happy Halloween! by James Schrimpf Oct 05, 2026 #234 A Life in High-End Audio: The Roy Hall Interview, Part One by Frank Doris Sep 07, 2026 #234 Jason Greenlaw Offers His Personal Perspective on Jazz Guitar in Vantage Point by Frank Doris Sep 07, 2026 #234 Transcendent Phoenix: Lucina Yue Brings the Ancient Konghou Into Modern Times by Frank Doris Sep 07, 2026 #234 We Must All Follow Our Bliss by B. Jan Montana Sep 07, 2026 #234 How to Play in a Rock Band, 27: Leveling Up by Frank Doris Sep 07, 2026 #234 Ross Valory: Traveling Into New Musical Territory With All of the Above by Ray Chelstowski Sep 07, 2026 #234 Singer/Songwriter John David Schrader: On the Need to Create by Joe Caplan Sep 07, 2026 #234 The People Who Make Audio Happen: More From T.H.E. Show SoCal 2026 by Harris Fogel Sep 07, 2026 #234 The Vinyl Beat Digs Into the Gadget Box by Rudy Radelic Sep 07, 2026 #234 The Rolling Stones: Foreign Tongues Spoken Loud by Wayne Robins Sep 07, 2026 #234 Musical Moments by Rich Isaacs Sep 07, 2026
 Goals:
Limitations:
Cables ($200)
Casual Systems
Serious Systems
Whacked-Out Systems
