Copper Magazine · Issue 231 · A free PS Audio publication
Issue 231 From The Listening Chair
Onkyo’s Monster M-510 power amplifier
This column is written by the staff of Just Audio, a Maryland-based brick-and-mortar and online retailer of new and vintage audio equipment and repair services. It is reprinted here by permission of The Listening Chair.
“What would an ocean be without a monster lurking in the dark?” Werner Herzog
When a vintage audio component arrives at Just Audio, it usually has a story to tell. Sometimes the component is in mint condition, having been loved and well-cared for by a longtime customer. Sometimes it’s an unusual item that creates a buzz among the staff. (See our recent article in this column on the B.I.C. Beam Box). However, every once in a while, it's something that stops us dead in our tracks.
The Onkyo M-510 Grand Integra amplifier is one of those jaw-dropping components that has come through our doors. In fact, when we first realized what we were looking at, we were in disbelief. The M-510, a prime example of a vintage Japanese “monster” component, is so legendary that it is often spoken about in the same breath as classic amps from high-end brands like Krell, Mark Levinson, and Accuphase.
When we got the M-510 in the shop, we auditioned it, refreshed ourselves as to its technical specs, and bench tested it. But before we did any of that, we couldn’t help but notice its striking appearance and sheer physical presence. The M-510 doesn’t just sit quietly on the shelf. It doesn't try to be subtle or blend in. Rather, weighing in at over 140 pounds and standing over ten inches tall, it dominates the room.
Beyond its size and heft, the M-510 is one good-looking amp. Real rosewood is used for both of the side panels of its chassis and for a handsome strip that is located on the front part of its top panel. Save for the rosewood strip, the top chassis panel consists almost exclusively of a huge heatsink.
On the front chassis panel, metal surfaces are generously appointed in brushed silver and champagne gold accents. Also on the M-510's front panel are two absolutely massive analog VU meters that illuminate in amber/gold.
Built Like a Battleship
The M-510 was part of Onkyo’s Grand Integra series components. As such, it was built not for the average listener but rather was a flagship product that sought to prove to all that Onkyo could stand shoulder-to-shoulder with audio’s most elite names. It was sold from approximately 1984 to 1992 for $3,800 USD at launch, which is approximately $10,000 today.
The Grand Integra components were designed to push technical boundaries. And push them, the M-510 did. To start, it is rated to deliver a staggering 300 watts per channel into 8 ohms, often exceeding 500 watts into lower impedances. It can drive virtually any speaker with authority. Its damping factor of 300 suggests an iron tight control over speaker cone movement and the absence of ringing high frequencies and boomy bass notes.
In addition, the M-510 features a true dual-mono design, meaning that each channel has its own dedicated architecture, including power supply. This reduces crosstalk and other types of electrical interference. It also ensures that each channel performs at its best even under demanding conditions. Looking at the M-510's power supplies, its toroidal transformers are enormous, and they are supported by massive capacitors that store and deliver energy. Each channel’s power board holds seven pairs of transistors. It’s the kind of overbuilt construction that you don’t even see in most modern components.
The M-510's rear panel also reveals that it is designed for serious audiophiles only. Rather than contain a virtual kitchen’s sink of connectors, that panel has only binding posts for two sets of speakers (these posts accommodate thick, low-gauge speaker wire), variable and direct input connectors, a signal ground connector, and a heavy-duty, captive power cord. Large rubber bumpers on the panel assure that the M-510 will not be placed too close to a wall, thus protecting the protruding connectors and allowing for proper heat dissipation.
And then there are the M-510 VU meters. They are more than just visual centerpieces; rather, they are a window into the type of power and dynamics that this machine can deliver. Watching the meters light up and dance as music plays is nothing short of mesmerizing.
But aesthetics, circuitry design, and technical specifications don’t tell the M-510's full story. What makes this amp so remarkable is how it delivers that power: effortlessly, cleanly, and with a level of control that is still impressive many decades later. As we spent time with this monster, our initial shock turned into admiration. It’s one thing to see a piece like this. But it’s another thing to experience it. Just using its silky smooth and precise controls, for example, reflects the uncompromising level of care that was used in its design and manufacture.
Finally, what sets the Onkyo M-510 apart today is its rarity. Expensive and aimed at a small niche audience of serious audiophiles only about 200 examples were reportedly sold in the United States. Few of those have survived in good condition. If you want to own one, be prepared to pay between $7,500 to $10,000.
A Connection to Audiophile Days of Past
 Of course, owning a component like the Onkyo M-510 isn’t just about looks or performance. It’s about owning a piece of audio history, a product from an era when engineers were first given the freedom to dream big and build even bigger. It’s about the craftsmanship, the attention to detail, and the uncompromising approach that went into its design.
In many ways, the M-510 is a reminder of why we do what we do at Just Audio. It’s about more than buying and selling equipment—it’s about preserving and celebrating the history of home audio. It’s about recognizing the significance of pieces like this and sharing our excitement about it with others.
Is the Onkyo M-510 one of the rarest amplifiers that we’ve ever seen? Without a doubt. But more than that, it’s one of the most memorable. It’s the kind of component that leaves a lasting impression as its designers reached for the stars and, in many ways, succeeded.
All images courtesy of The Listening Chair, a reviewing and news organization for all things audiophile.
Check out the latest from TLC on the web (www.thelisteningchair.net) and its YouTube channel (https://www.youtube.com/@thelisteningchair_).
Also note TLC’s growing social media ecosystem, including its Facebook group (https://www.facebook.com/groups/217745678009888), where members from around the world show off their gear; and LinkedIn group (https://www.linkedin.com/in/howard-kneller/), Instagram (www.instagram.com/howardkneller/), Threads (www.threads.net/@howardkneller) and X (www.x.com/HowardKneller) pages.
More from Issue 231
View All Articles in Issue 231
Favorites From T.H.E. Show SoCal 2026 by Cam Martin Oct 05, 2026 #235 Singer/Songwriter John David Schrader: On the Need to Create, Part Two by Joe Caplan Oct 05, 2026 #235 A Life in High-End Audio: The Roy Hall Interview, Part Two by Frank Doris Oct 05, 2026 #235 Grammy-Winning Producer, Songwriter, and Guitarist John Leventhal Goes Instrumental With National Drift by Ray Chelstowski Oct 05, 2026 #235 From Swimming Pool to New Listening Room—to Founding an Accidental Audio Company by Gilles Laferrière Oct 05, 2026 #235 The Vinyl Beat’s Size Matters Edition by Rudy Radelic Oct 05, 2026 #235 The Sublime Complexities of Nature by B. Jan Montana Oct 05, 2026 #235 How to Play In a Rock Band, 28: Growing Older and Dealing With It by Frank Doris Oct 05, 2026 #235 Young Rascals: From Bar Band to Stardom by Wayne Robins Oct 05, 2026 #235 Duncan Sheik: In Memoriam by Ray Chelstowski Oct 05, 2026 #235 From The Listening Chair: The Meze Audio 105 Silva Headphones by Howard Kneller Oct 05, 2026 #235 Checking Out Some NOLA Loudspeakers – and Some Thoughts About Audio Writing by Frank Doris Oct 05, 2026 #235 The Kanazawa Phonograph Museum: Music from a Time Capsule by Sebastian Polcyn Oct 05, 2026 #235 PS Audio in the News by PS Audio Staff Oct 05, 2026 #235 From The Audiophile’s Guide: Making the Most Critical Choice by Paul McGowan Oct 05, 2026 #235 Evolutionary Growth by Frank Doris Oct 05, 2026 #235 Speed Racer by Peter Xeni Oct 05, 2026 #235 Happy Halloween! by James Schrimpf Oct 05, 2026 #234 A Life in High-End Audio: The Roy Hall Interview, Part One by Frank Doris Sep 07, 2026 #234 Jason Greenlaw Offers His Personal Perspective on Jazz Guitar in Vantage Point by Frank Doris Sep 07, 2026 #234 Transcendent Phoenix: Lucina Yue Brings the Ancient Konghou Into Modern Times by Frank Doris Sep 07, 2026 #234 We Must All Follow Our Bliss by B. Jan Montana Sep 07, 2026 #234 How to Play in a Rock Band, 27: Leveling Up by Frank Doris Sep 07, 2026 #234 Ross Valory: Traveling Into New Musical Territory With All of the Above by Ray Chelstowski Sep 07, 2026 #234 Singer/Songwriter John David Schrader: On the Need to Create by Joe Caplan Sep 07, 2026 #234 The People Who Make Audio Happen: More From T.H.E. Show SoCal 2026 by Harris Fogel Sep 07, 2026 #234 The Vinyl Beat Digs Into the Gadget Box by Rudy Radelic Sep 07, 2026 #234 The Rolling Stones: Foreign Tongues Spoken Loud by Wayne Robins Sep 07, 2026 #234 Musical Moments by Rich Isaacs Sep 07, 2026 #234 Rags for Solo Piano and a Dog: David Chesky's Ragtime Music for the Modern Age by Frankly Speaking Sep 07, 2026 #234 HIGH END 2026, Vienna: Here to Stay by Carsten Barnbeck Sep 07, 2026 #234 From The Audiophile’s Guide: The Two Main Types of Loudpeakers – Box and Panel by Paul McGowan Sep 07, 2026 #234 Letting it Slide by Frank Doris Sep 07, 2026 #234 PS Audio in the News by PS Audio Staff Sep 07, 2026 #234 Long Playing by Peter Xeni Sep 07, 2026 #234 La Mer by B. Jan Montana Sep 07, 2026 #233 A Report From The Total Hi-Fi Experience Show SoCal 2026 by B. Jan Montana Aug 03, 2026 #233 Bluegrass Meets Country, Folk, Jazz and More in All That We Carried by The Squid City Slingers by Frank Doris Aug 03, 2026 #233 Corey Glover and One Tribe Nation: A Variegated Musical Collective by Ray Chelstowski Aug 03, 2026 #233 Excursions with Clive: The Late Clive Davis, A Personal History by Wayne Robins Aug 03, 2026 #233 AI, Art, and Music: A Conversation With Synthography Art by Joe Caplan Aug 03, 2026 #233 New American Symphonies: A Rediscovered Gem and a Vital Contemporary Work by Frank Doris Aug 03, 2026 #233 The Vinyl Beat: Genesis, the Dave Clark Five, Antonio Carlos Jobim and More by Rudy Radelic Aug 03, 2026 #233 How to Play in a Rock Band, 26: When It's Time to Record Your Music by Frank Doris Aug 03, 2026 #233 More From T.H.E. Show 2026, and the People Who Made it Happen by Harris Fogel Aug 03, 2026 #233 Underappreciated Artists, Part Three: Icehouse by Rich Isaacs Aug 03, 2026 #233 The Surprisingly Rich and Varied Music of Somalia by Steve Kindig Aug 03, 2026
