Issue 16 • Free Online Magazine
Issue 16 QUIBBLES AND BITS
Sigma Delta Modulators Part II
In my last column, I wrote about how a SDM might be used to faithfully reconstruct an incoming signal, even if its output is constrained to an apparently hopelessly reduced bit depth.  We can do this if we can ensure that the Signal Transfer Function (STF) and Noise Transfer Function (NTF) have appropriate characteristics.  Today I will expand on how we can make that work.  I had originally planned to conclude with some personal remarks on the DSD-vs-PCM debate, but I will leave those for a complete post in the next issue.
We want the NTF and STF to be frequency dependent, but the Sigma stage I described is clearly not frequency dependent, and neither is the Delta stage, so it’s not at all apparent how that can come to pass.  Therefore we need to introduce some frequency dependence into the picture.  The way we do that is to augment the Sigma stage with a filter called the “Loop Filter”.  This is usually a low-pass filter, and its incorporation means that the NTF and STF now become frequency dependent.  If the “Transfer Function” of the Loop Filter (a deeply technical way of expressing its frequency response) is H(z), then the frequency response of the STF will be also given by H(z), and that of the NTF will be given by 1- H(z).  This is the basis of the simple Linear Model of SDM design.
Don’t worry if none of that means anything to you, because addressing these design issues takes us right to the bleeding edge of today’s digital audio technology.  The best approach to understanding the design of an SDM remains this Linear Model, where we treat the Quantization error introduced at the Quantizer stage as a noise source.  However, any model’s accuracy is – self-evidently – limited by its “limiting assumptions”.  In this case the limiting assumption is that the Quantization error can be adequately represented by a noise source.  According to the Linear Model, relatively simple SDMs should exhibit stunningly good performance, where in reality they do not.  In fact they fall very substantially short of the mark.  Clearly, a noise source is not as ideal a substitute for the Quantization error as we had hoped.  Unfortunately, though, we don’t yet have a better candidate available.
In the absence of a good guiding model, SDM designers stick to an empirical methodology based on trial and error.  The most successful approach is based on increasing the “order” of the modulator.  The simple SDM I described last time has a single Sigma stage, and is called a “first order” SDM.  If we simply add a second Sigma stage we get a “second order” SDM.  We can add as many Sigma stages as we like, and however many we add, that’s the “order” of the SDM.  The higher the “order” of the SDM, the better its performance ought to be.  I make that sound so much easier than it actually is, particularly when it comes to the task of fine-tuning the SDM’s NTF performance.
In practice, real-world SDM designs run into problems.  Lots of them.  First of these is overloads.  If the signal fed into the Quantizer overloads the Quantizer then the SDM will go unstable.  In effect, we are forcing the Quantizer into hard clipping.  In a SDM, because of the feedback, the result of such an overload will reverberate within the output of the SDM for a very considerable time.  Overloads become a progressively higher problem as the “order” of the SDM is increased, and ultimately impose an upper limit on the “order” of practical SDMs.
A second problem is that high order digital filters can themselves be unstable, not so much because of any inherent instability, but because of truncation and other precision errors in the processing and execution of the filter.  Proper filter design tools can identify and optimize for these errors, but can rarely make them go away entirely.  Unstable filters can cause all sorts of problems in SDMs, from the addition of noise and distortion to total malfunction.
A third problem is that SDMs are found to have any number of unexpected error or fault loops in which they can find themselves trapped, which are not yet adequately explained or predicted by any theoretical treatment.  These include phenomena known as “limit cycles”, “birdies”, “idle tones” and others.  They can be frustratingly difficult to detect – sometimes even to describe – let alone to design around.
Real-world high performance SDMs for DSD applications are typically between 5th and 10th order.  Below 5th order the performance is inadequate, and above 10th order they are rarely sufficiently stable.  The professional audio product “Weiss Saracon”, for example, offers a choice of SDM structures, having orders 6, 8, and 10.  Each SDM structure produces a DSD output file with subtly different sonic signatures, differences which many well-tuned audiophile ears can reliably detect.  And as with religion, the fact that there are several of them from which to choose is not sufficient to guarantee that one of them is correct!
These and other limitations mean that the best SDMs deliver a dynamic range of about ~120dB – better than the ~98dB of 16–bit PCM, but less than the ~146dB capacity of 24–bit PCM.  Distortion is also an issue, albeit usually a minor one.  Overall, the noise and distortion performance of the very best SDMs is more or less equivalent to those of the very best analog circuits currently used in preamplifiers and amplifiers.  In principle we ought to be able to achieve better than that, and in future we very well might, but right now you could argue that what we are getting is as good as we need.
Interestingly enough, one of those limitations can be readily made to go away.  The problem of overloads can be largely eliminated by using a multi-bit Quantizer.  This approach is used in almost all commercial ADCs which use an analog SDM in the input stage, configured to provide a 3–bit to 5–bit intermediate result.  This intermediate result is then converted in the digital domain to the desired output format, whether PCM or DSD.  Likewise, almost all commercial DACs employ a digital SDM in the input stage, configured to provide a 3–bit to 5–bit intermediate result which is then converted to analog using a simple R–2R ladder.  SDMs are therefore deeply involved at both ends of the PCM audio chain, though they mostly don’t use the 1–bit bit depth of DSD (or, for that matter, its 2.8MHz sample rate).  When you listen to PCM, you cannot escape the fact that you are listening to SDMs.
The key takeaway from the study of SDMs is that while their performance can indeed be extremely good, the current state-of-the-art does not permit us to design that performance on an a priori basis to a high degree of accuracy.  Instead, SDMs must be evaluated phenomenologically.  In other words we must carefully measure their characteristics – linearity, distortion, noise, dynamic range, etc.  In this regard, SDMs are very much like analog electronic devices such as amplifiers.  We can bring a lot of design intelligence to bear, but at the end of the day those designs cannot tell us all we need to know about their performance; the skill – and golden ears – of the designer tend to become the critical differentiating factors.
The conclusion of Richard’s examination of Sigma-Delta Modulators will appear in Copper #17–-Ed.
More from Issue 16
View All Articles in Issue 16
#227 Seth Lewis Gets in the Groove With Take a Look Around: a Tribute to the Meters by Frank Doris Feb 02, 2026 #227 Passport to Sound: May Anwar’s Audio Learning Experience for Young People by Frank Doris Feb 02, 2026 #227 Conjectures on Cosmic Consciousness by B. Jan Montana Feb 02, 2026 #227 The Big Takeover Turns 45 by Wayne Robins Feb 02, 2026 #227 Music and Chocolate: On the Sensory Connection by Joe Caplan Feb 02, 2026 #227 Singer/Songwriter Chris Berardo: Getting Wilder All the Time by Ray Chelstowski Feb 02, 2026 #227 The Earliest Stars of Country Music, Part One by Jeff Weiner Feb 02, 2026 #227 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part Two by Rudy Radelic Feb 02, 2026 #227 How to Play in a Rock Band, 20: On the Road With Blood, Sweat & Tears’ Guitarist Gabe Cummins by Frank Doris Feb 02, 2026 #227 From The Audiophile’s Guide: Audio Specs and Measuring by Paul McGowan Feb 02, 2026 #227 Our Brain is Always Listening by Peter Trübner Feb 02, 2026 #227 PS Audio in the News by PS Audio Staff Feb 02, 2026 #227 The Listening Chair: Sleek Style and Sound From the Luxman L3 by Howard Kneller Feb 02, 2026 #227 The Los Angeles and Orange County Audio Society Celebrates Its 32nd Anniversary, Honoring David and Sheryl Lee Wilson and Bernie Grundman by Harris Fogel Feb 02, 2026 #227 Back to My Reel-to-Reel Roots, Part 26: Half Full – Not Half Empty, Redux by Ken Kessler Feb 02, 2026 #227 That's What Puzzles Us... by Frank Doris Feb 02, 2026 #227 Record-Breaking by Peter Xeni Feb 02, 2026 #227 The Long and Winding Road by B. Jan Montana Feb 02, 2026 #226 JJ Murphy’s Sleep Paralysis is a Genre-Bending Musical Journey Through Jazz, Fusion and More by Frank Doris Jan 05, 2026 #226 Stewardship by Consent by B. Jan Montana Jan 05, 2026 #226 Food, Music, and Sensory Experience: An Interview With Professor Jonathan Zearfoss of the Culinary Institute of America by Joe Caplan Jan 05, 2026 #226 Studio Confidential: A Who’s Who of Recording Engineers Tell Their Stories by Frank Doris Jan 05, 2026 #226 Pilot Radio is Reborn, 50 Years Later: Talking With CEO Barak Epstein by Frank Doris Jan 05, 2026 #226 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part One by Rudy Radelic Jan 05, 2026 #226 Capital Audiofest 2025: Must-See Stereo, Part Two by Frank Doris Jan 05, 2026 #226 My Morning Jacket’s Carl Broemel and Tyler Ramsey Collaborate on Their Acoustic Guitar Album, Celestun by Ray Chelstowski Jan 05, 2026 #226 The People Who Make Audio Happen: CanJam SoCal 2025, Part Two by Harris Fogel Jan 05, 2026 #226 How to Play in a Rock Band, 19: Touring Can Make You Crazy, Part One by Frank Doris Jan 05, 2026 #226 Linda Ronstadt Goes Bigger by Wayne Robins Jan 05, 2026 #226 From The Audiophile’s Guide: Active Room Correction and Digital Signal Processing by Paul McGowan Jan 05, 2026 #226 PS Audio in the News by Frank Doris Jan 05, 2026 #226 Back to My Reel-to-Reel Roots, Part 25: Half-Full, Not Empty by Ken Kessler Jan 05, 2026 #226 Happy New Year! by Frank Doris Jan 05, 2026 #226 Turn It Down! by Peter Xeni Jan 05, 2026 #226 Ghost Riders by James Schrimpf Jan 05, 2026 #226 A Factory Tour of Audio Manufacturer German Physiks by Markus "Marsu" Manthey Jan 04, 2026 #225 Capital Audiofest 2025: Must-See Stereo, Part One by Frank Doris Dec 01, 2025 #225 Otis Taylor and the Electrics Delivers a Powerful Set of Hypnotic Modern Blues by Frank Doris Dec 01, 2025 #225 A Christmas Miracle by B. Jan Montana Dec 01, 2025 #225 T.H.E. Show New York 2025, Part Two: Plenty to See, Hear, and Enjoy by Frank Doris Dec 01, 2025 #225 Underappreciated Artists, Part One: Martin Briley by Rich Isaacs Dec 01, 2025 #225 Rock and Roll is Here to Stay by Wayne Robins Dec 01, 2025 #225 A Lifetime of Holiday Record (and CD) Listening by Rudy Radelic Dec 01, 2025 #225 Little Feat: Not Saying Goodbye, Not Yet by Ray Chelstowski Dec 01, 2025 #225 How to Play in a Rock Band, Part 18: Dealing With Burnout by Frank Doris Dec 01, 2025 #225 The People Who Make Audio Happen: CanJam SoCal 2025 by Harris Fogel Dec 01, 2025 #225 Chicago’s Sonic Sanctuaries: Four Hi‑Fi Listening Bars Channeling the Jazz‑Kissa Spirit by Olivier Meunier-Plante Dec 01, 2025
