Issue 68 • Free Online Magazine
Issue 68 SOMETHING OLD / SOMETHING NEW
Schubert Symphonies
The past 12 months have seen the release of several important new recordings of Schubert symphonies, two of which are part of series of all nine (yeah, I’m counting that “Unfinished” one, but I count it, since it’s probably Schubert’s most often-recorded work).
Following their 2016 recording of Symphonies 1, 3, and 4, the Antwerp Symphony Orchestra and conductor Philipp Herreweghe are back on the Phi label with another volume in the set. This one features Symphonies 2 and 5, both of which are in B flat.
Nobody who hears the slow introduction to the first movement of Symphony No. 2, D. 125, can doubt that young Schubert was obsessed with Beethoven. The wind-heavy, thundering orchestration, the intense harmonies – these are tributes to his favorite composer. The transition from slow introduction to main first-movement sonata form themes (in this case marked Allegro vivace) is subtler in this piece than in some, and before you know it you’re flitting along on sixteenth notes. Herreweghe shows his signature grace, and the Antwerp players produce a relaxed yet virtuosic sound.
The other work on his recording, Symphony No. 5, D. 485, ends with a movement that’s also marked Allegro vivace. Herreweghe takes the tempo easy, pulling the reins tight in a way that some might find too confining. But vivace means “lively,” not “wild,” and this interpretation is both energetic and elegant.
It seems likely that Herreweghe and Antwerp will record the remaining symphonies while they’re at it, although it has not been officially announced. There’s no speculation required about the new recording by Residentie Orkest The Hague and conductor Jan Willem de Vriend, which is titled Schubert: The Complete Symphonies, Vol. 1. This first offering, on the Challenge Classics label, includes Symphonies 2 and 4.
Comparing de Vriend’s opening Largo – Allegro vivace with that of Herreweghe, the immediate difference is the interpretation of the initial dotted rhythm. Herreweghe, whose background is steeped in early music, uses a technique called “overdotting” (not normally associated with repertoire of Schubert’s day) to draw the first dotted eighth note longer in each pattern, thus making the following sixteenth shorter. De Vriend’s more mathematically correct interpretation is the standard one.
Throughout the Largo, de Vriend shapes each phrase as an answer to the last, often using slight dynamic changes to etch out the contrast. The allegro vivace, although a hair slower than Herreweghe’s, makes up for that by sounding more frenetic and less controlled.
De Vriend proves he can do elegance as well as anybody in the second movement, a theme-and-variation Andante. He shapes the phrases exquisitely, with the tiniest delay at each climax and cadence. It leaves you breathless. And that Residentie Orkest woodwind section is word class.
The so-called “Tragic” Symphony, No. 4 in C minor, D. 417, rounds out the album. The dramatic Allegro finale movement doesn’t have quite the bite and rhythmic delineation it might, with the technically challenging A-section bridge coming slightly unglued.
Besides those two worthy studio recordings, 2018 has also brought out two top-notch live recordings of Schubert symphonies. BR Klassik released a performance of the “Great” Symphony No. 9 in C Major, D. 944, with the Symphonieorchester des bayerischen Rundfunks (Bavarian Radio Orchestra), conducted by their current music director, Mariss Jansons.
The Ninth Symphony hasn’t always been called that. It was published posthumously – in 1840, a dozen years after Schubert’s death — as Symphony No. 7 (his actual seventh symphony was written but not fully orchestrated), and some sticklers still call it the Eighth because the one before it is the famous “Unfinished.” In any event, it is Schubert’s last completed symphony, although not his last completed work; it’s also known that he was drafting a tenth symphony when he died in 1828.
And, while the nickname “Great” was first attached to this work to distinguish it from the shorter C major symphony, No. 6, these days it’s associated with the grandeur of the piece. That’s a good term for this B.R.O. performance. From the French horn’s hunting call in the opening Andante bars, through the Allegro ma non troppo first movement, Jansons fills the Philharmonie am Gasteig with sweeping grandeur. In spite of some ensemble issues with the violins, the way Jansons distinguishes the instrumental voices – particularly the reeds – makes this first movement an interesting addition to the catalog.
The articulation in the Scherzo Allegro third movement gives a sense of Teutonic rural foot-stomping, a timely that Schubert was, in his bones, a composer of folk music. Again, the careful articulation earns attention: listen to the slight bite of the third beat in the violins during some passages, propelling the dance forward, and the slight delay of the last downbeat of some phrases.
The other new live recording features the Orchestre Révolutionnaire et Romantique led by Sir John Elliot Gardiner at the Concertgebouw. This is the second live release of ORR/Gardiner on the SDG label, the first being Beethoven Symphonies 5 and 7 at Carnegie Hall. This one includes Schubert’s Fifth plus Brahms’ Serenade No. 2 in A Major. It’s a thrilling performance, marred somewhat by extraneous audience noises, some of which are so loud that one wonders if it’s the sound engineer coughing. Nevertheless, it’s a great reading of Schubert 5.
Because YouTube only has the entire Schubert as a single video, here are the start times of each movement:
  1. Allegro
  2. Andante con moto (starts 7:18)
III. Menuetto. Allegro molto – Trio (starts 18:04)
  1. Allegro vivace (starts 23:12)
The third movement is an interesting miniature, a mere five-minute affair, but intensely symphonic, with so much harmonic development and complex orchestration it could be mistaken for an excerpt from a sonata-form first movement. Gardiner revels in the drama, slashing the downbeats like he’s conducting a windstorm, the better to contrast with the sweet, gentle Trio.
That sense of abandon is also present in the finale. It’s fun to compare Gardiner to Herreweghe, since both conductors have such solid resumes in early music. Herreweghe sculpts the Antwerp Symphony’s sound into delicate wisps. Gardiner rides the ORR into a burning building; apparently he does believe that vivace can mean “wild.”
More from Issue 68
View All Articles in Issue 68
#228 Serita’s Black Rose Duo Shakes Your Soul With a Blend of Funk, Rock, Blues and a Whole Lot More by Frank Doris Mar 02, 2026 #228 Vinyl, A Love Story by Wayne Robins Mar 02, 2026 #228 Thrill Seeker by B. Jan Montana Mar 02, 2026 #228 The Vinyl Beat: Donald Byrd, Bill Evans, Wes Montgomery, Eddie Palmieri and Frank Sinatra by Rudy Radelic Mar 02, 2026 #228 Listening to Prestige: The History of a Vitally Important Jazz Record Label by Frank Doris Mar 02, 2026 #228 How to Play in a Rock Band, 21: Touring With James Lee Stanley by Frank Doris Mar 02, 2026 #228 The NAMM 2026 Show: The Music Industry’s Premier Event by John Volanski Mar 02, 2026 #228 The Earliest Stars of Country Music, Part Two by Jeff Weiner Mar 02, 2026 #228 From The Audiophile's Guide: A Brief History of Stereophonic Sound by Paul McGowan Mar 02, 2026 #228 A Bone to Pick With Streaming Audio by Frank Doris Mar 02, 2026 #228 Blast Off With Bluesman Duke Robillard by Ray Chelstowski Mar 02, 2026 #228 A Visit to the Marten Loudspeaker Factory in Göteborg, Sweden by Ingo Schulz and Sebastian Polcyn Mar 02, 2026 #228 Pure Distortion by Peter Xeni Mar 02, 2026 #228 A Nagra Factory Tour by Markus "Marsu" Manthey Mar 02, 2026 #228 Back to My Reel-to-Reel Roots, Part 27: Noodge and Ye Shall Receive, Part Two by Ken Kessler Mar 02, 2026 #228 PS Audio in the News by PS Audio Staff Mar 02, 2026 #228 90-Degree Stereo by Frank Doris Mar 02, 2026 #228 The Keys to Art by Rich Isaacs Mar 02, 2026 #227 Seth Lewis Gets in the Groove With Take a Look Around: a Tribute to the Meters by Frank Doris Feb 02, 2026 #227 Passport to Sound: May Anwar’s Audio Learning Experience for Young People by Frank Doris Feb 02, 2026 #227 Conjectures on Cosmic Consciousness by B. Jan Montana Feb 02, 2026 #227 The Big Takeover Turns 45 by Wayne Robins Feb 02, 2026 #227 Music and Chocolate: On the Sensory Connection by Joe Caplan Feb 02, 2026 #227 Singer/Songwriter Chris Berardo: Getting Wilder All the Time by Ray Chelstowski Feb 02, 2026 #227 The Earliest Stars of Country Music, Part One by Jeff Weiner Feb 02, 2026 #227 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part Two by Rudy Radelic Feb 02, 2026 #227 How to Play in a Rock Band, 20: On the Road With Blood, Sweat & Tears’ Guitarist Gabe Cummins by Frank Doris Feb 02, 2026 #227 From The Audiophile’s Guide: Audio Specs and Measuring by Paul McGowan Feb 02, 2026 #227 Our Brain is Always Listening by Peter Trübner Feb 02, 2026 #227 PS Audio in the News by PS Audio Staff Feb 02, 2026 #227 The Listening Chair: Sleek Style and Sound From the Luxman L3 by Howard Kneller Feb 02, 2026 #227 The Los Angeles and Orange County Audio Society Celebrates Its 32nd Anniversary, Honoring David and Sheryl Lee Wilson and Bernie Grundman by Harris Fogel Feb 02, 2026 #227 Back to My Reel-to-Reel Roots, Part 26: Half Full – Not Half Empty, Redux by Ken Kessler Feb 02, 2026 #227 That's What Puzzles Us... by Frank Doris Feb 02, 2026 #227 Record-Breaking by Peter Xeni Feb 02, 2026 #227 The Long and Winding Road by B. Jan Montana Feb 02, 2026 #226 JJ Murphy’s Sleep Paralysis is a Genre-Bending Musical Journey Through Jazz, Fusion and More by Frank Doris Jan 05, 2026 #226 Stewardship by Consent by B. Jan Montana Jan 05, 2026 #226 Food, Music, and Sensory Experience: An Interview With Professor Jonathan Zearfoss of the Culinary Institute of America by Joe Caplan Jan 05, 2026 #226 Studio Confidential: A Who’s Who of Recording Engineers Tell Their Stories by Frank Doris Jan 05, 2026 #226 Pilot Radio is Reborn, 50 Years Later: Talking With CEO Barak Epstein by Frank Doris Jan 05, 2026 #226 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part One by Rudy Radelic Jan 05, 2026 #226 Capital Audiofest 2025: Must-See Stereo, Part Two by Frank Doris Jan 05, 2026 #226 My Morning Jacket’s Carl Broemel and Tyler Ramsey Collaborate on Their Acoustic Guitar Album, Celestun by Ray Chelstowski Jan 05, 2026 #226 The People Who Make Audio Happen: CanJam SoCal 2025, Part Two by Harris Fogel Jan 05, 2026 #226 How to Play in a Rock Band, 19: Touring Can Make You Crazy, Part One by Frank Doris Jan 05, 2026 #226 Linda Ronstadt Goes Bigger by Wayne Robins Jan 05, 2026
Schubert Symphonies
  1. Allegro
