Issue 130 • Free Online Magazine
Issue 130 OCTAVE PITCH
Octave Records' New System Setup Disc and Book
Octave Records has two new announcements this time out. The Audiophile Reference Disc SACD was created to help listeners get the best out of their stereo systems, by providing reference-quality music and test tracks.
The release of the disc coincides with the debut of the book Audiophile’s Guide: The Stereo, a comprehensive guide to system setup by PS Audio CEO Paul McGowan, and a companion to the disc.
The Audiophile Reference Disc is playable on any SACD, CD, DVD, or Blu-ray player. It also comes with a second DVD data disc containing DSD, high-resolution and standard-resolution PCM files, available for ripping to a hard drive or playing in a player. In addition, when used with PS Audio transports and DACs, the SACD DSD layer will be sent from the transport to the DAC for playback.
The Audiophile Reference Disc and Audiophile's Guide: The Stereo Book.
The master DSD and PCM files are also available for purchase and download from psaudio.com at this link.
As Paul points out, “For years I have wanted to put together a step-by-step instruction book with specific recordings tuned to each instructional step. After nearly 50 years of setting up and adjusting 2-channel audio systems, a pattern began to develop. In nearly every case, owners of high-end audio systems were making the same basic setup errors: speakers too close to the front wall, with too much toe-in; or with the soundstage forward of the speakers. The speakers didn’t ‘disappear’ as they should when set up properly.
What I discovered is that in setting up their system, listeners all had their favorite tracks where their system sounded right – but those tracks weren’t themselves right. At the back of my mind I kept wishing for a set of known reference recordings that were specific to setup instructions. Former setup discs were great for many things, but they were not specific to the basics of setup and they didn’t have an accompanying guide book.”
The Audiophile Reference Disc begins with a series of tracks for system setup starting points, including left, right and phantom center channel identification, and checking for correct phase (polarity). Subsequent music tracks facilitate more sophisticated evaluations like in-room bass response, soundstage width and depth, resolution, a system burn-in track and more.
The Audiophile Reference Disc was designed to be used in conjunction with The Audiophile’s Guide book. The Guide details each step in the stereo setup instructional process, and a corresponding reference audio track is designated to check and verify the results. The disc and book go over every aspect of getting the most out of stereo system reproduction, from a single voice to the most complex and dynamic musical passages.
Recorded and mastered using Octave Records’ exclusive DSDDirect Mastered 192kHz/24-bit process and 96kHz/24-bit and 44.1kHz/16-bit PCM, The Audiophile Reference Disc was produced using state-of-the-art high-resolution audio technology and was created for use as a true reference-quality system-evaluation tool. The disc was produced by Octave Records’ Giselle Collazo and Jessica Carson and mastered and mixed by Octave engineer Gus Skinas and Giselle. Over many weeks of mixing, each track was brought into PS Audio’s Music Room Two and auditioned on the reference system, based around Infinity IRS V loudspeakers. Paul notes, “I had the final say on what got accepted and what had to go back for additional tuning and tweaking. It was a long, long process of back and forth until we were satisfied.”
Audiophile’s Guide: The Stereo Book is subtitled “Unlock the Secrets to Great Sound” and the book explains how to achieve this. The Guide begins with a history of stereophonic sound and moves into chapters on what to listen for and how to achieve the best from an audio system, covering topics like establishing a budget, what to buy and what not to, analog vs. digital, tubes vs. solid-state, achieving a spacious “3-D” sound from loudspeakers, tuning the system to the listening room, system tweaking and fine-tuning and much more. The book can be read as a standalone reference, or used in conjunction with The Audiophile Reference Disc.
Paul adds, “The types of tracks we needed on the disc were obvious from what was required in the Guide. For example, ‘Dualities’ (a previously unreleased track by Octave Records artist Clandestine Amigo) was an obvious choice, because once you get the soundstage and imaging depth working correctly on your system, you need a way to verify you have it right.
Jessica Carson of Clandestine Amigo.
During the recording of this song, we came up with the idea of measuring the distance from the singers to the microphones. Jessica and Giselle sing the first verse from three feet away, then six and nine feet away on the second and third verses. On a good system, you can hear the difference in their distances from the Tim de Paravicini-modified AKG C24 Blumlein stereo mic. Some listeners who have highly resolving systems will notice a distinct rumble on that particular track. It’s the air conditioning unit atop the roof of our warehouse where this was recorded. I consider it an Easter egg of sorts—which is why we left it in.”
Other tracks include solo acoustic and electric piano, solo acoustic guitar, live studio recordings of small and medium-sized groups, and other musical variety. “Slow Moving Ferns” delivers sonic fireworks via 32 tracks of analog and digital synthesizers recorded in pure DSD directly into Octave’s Sonoma multitrack recorder. The disc also features an all-out system-workout drum track, “Transmogrification.” It was recorded by Banshee Tree drummer Michelle Pietrafitta in PS Audio’s warehouse using the Tim de Paravicini-modified Blumlein stereo C24, along with Shure Beta 52, and SM7B Soundelux U195, beyerdynamic M201, Telefunken M80 and Audix D4 mics. This track has serious dynamic impact and if your system is up to the task, you’ll feel the bass drum hit you in the chest. Play it loud!
Chris Brunhaver and Giselle Collazo in the studio. Chris Brunhaver and Giselle Collazo in the studio.
More from Issue 130
View All Articles in Issue 130
#228 Serita’s Black Rose Duo Shakes Your Soul With a Blend of Funk, Rock, Blues and a Whole Lot More by Frank Doris Mar 02, 2026 #228 Vinyl, A Love Story by Wayne Robins Mar 02, 2026 #228 Thrill Seeker by B. Jan Montana Mar 02, 2026 #228 The Vinyl Beat: Donald Byrd, Bill Evans, Wes Montgomery, Eddie Palmieri and Frank Sinatra by Rudy Radelic Mar 02, 2026 #228 Listening to Prestige: The History of a Vitally Important Jazz Record Label by Frank Doris Mar 02, 2026 #228 How to Play in a Rock Band, 21: Touring With James Lee Stanley by Frank Doris Mar 02, 2026 #228 The NAMM 2026 Show: The Music Industry’s Premier Event by John Volanski Mar 02, 2026 #228 The Earliest Stars of Country Music, Part Two by Jeff Weiner Mar 02, 2026 #228 From The Audiophile's Guide: A Brief History of Stereophonic Sound by Paul McGowan Mar 02, 2026 #228 A Bone to Pick With Streaming Audio by Frank Doris Mar 02, 2026 #228 Blast Off With Bluesman Duke Robillard by Ray Chelstowski Mar 02, 2026 #228 A Visit to the Marten Loudspeaker Factory in Göteborg, Sweden by Ingo Schulz and Sebastian Polcyn Mar 02, 2026 #228 Pure Distortion by Peter Xeni Mar 02, 2026 #228 A Nagra Factory Tour by Markus "Marsu" Manthey Mar 02, 2026 #228 Back to My Reel-to-Reel Roots, Part 27: Noodge and Ye Shall Receive, Part Two by Ken Kessler Mar 02, 2026 #228 PS Audio in the News by PS Audio Staff Mar 02, 2026 #228 90-Degree Stereo by Frank Doris Mar 02, 2026 #228 The Keys to Art by Rich Isaacs Mar 02, 2026 #227 Seth Lewis Gets in the Groove With Take a Look Around: a Tribute to the Meters by Frank Doris Feb 02, 2026 #227 Passport to Sound: May Anwar’s Audio Learning Experience for Young People by Frank Doris Feb 02, 2026 #227 Conjectures on Cosmic Consciousness by B. Jan Montana Feb 02, 2026 #227 The Big Takeover Turns 45 by Wayne Robins Feb 02, 2026 #227 Music and Chocolate: On the Sensory Connection by Joe Caplan Feb 02, 2026 #227 Singer/Songwriter Chris Berardo: Getting Wilder All the Time by Ray Chelstowski Feb 02, 2026 #227 The Earliest Stars of Country Music, Part One by Jeff Weiner Feb 02, 2026 #227 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part Two by Rudy Radelic Feb 02, 2026 #227 How to Play in a Rock Band, 20: On the Road With Blood, Sweat & Tears’ Guitarist Gabe Cummins by Frank Doris Feb 02, 2026 #227 From The Audiophile’s Guide: Audio Specs and Measuring by Paul McGowan Feb 02, 2026 #227 Our Brain is Always Listening by Peter Trübner Feb 02, 2026 #227 PS Audio in the News by PS Audio Staff Feb 02, 2026 #227 The Listening Chair: Sleek Style and Sound From the Luxman L3 by Howard Kneller Feb 02, 2026 #227 The Los Angeles and Orange County Audio Society Celebrates Its 32nd Anniversary, Honoring David and Sheryl Lee Wilson and Bernie Grundman by Harris Fogel Feb 02, 2026 #227 Back to My Reel-to-Reel Roots, Part 26: Half Full – Not Half Empty, Redux by Ken Kessler Feb 02, 2026 #227 That's What Puzzles Us... by Frank Doris Feb 02, 2026 #227 Record-Breaking by Peter Xeni Feb 02, 2026 #227 The Long and Winding Road by B. Jan Montana Feb 02, 2026 #226 JJ Murphy’s Sleep Paralysis is a Genre-Bending Musical Journey Through Jazz, Fusion and More by Frank Doris Jan 05, 2026 #226 Stewardship by Consent by B. Jan Montana Jan 05, 2026 #226 Food, Music, and Sensory Experience: An Interview With Professor Jonathan Zearfoss of the Culinary Institute of America by Joe Caplan Jan 05, 2026 #226 Studio Confidential: A Who’s Who of Recording Engineers Tell Their Stories by Frank Doris Jan 05, 2026 #226 Pilot Radio is Reborn, 50 Years Later: Talking With CEO Barak Epstein by Frank Doris Jan 05, 2026 #226 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part One by Rudy Radelic Jan 05, 2026 #226 Capital Audiofest 2025: Must-See Stereo, Part Two by Frank Doris Jan 05, 2026 #226 My Morning Jacket’s Carl Broemel and Tyler Ramsey Collaborate on Their Acoustic Guitar Album, Celestun by Ray Chelstowski Jan 05, 2026 #226 The People Who Make Audio Happen: CanJam SoCal 2025, Part Two by Harris Fogel Jan 05, 2026 #226 How to Play in a Rock Band, 19: Touring Can Make You Crazy, Part One by Frank Doris Jan 05, 2026 #226 Linda Ronstadt Goes Bigger by Wayne Robins Jan 05, 2026
