Copper Magazine · Issue 22 · A free PS Audio publication
Issue 22 QUIBBLES AND BITS
Purer, More Perfect Sound
I have spent a lot of time focusing on the Red Book standard of CD Audio, which calls for 16-bit data at a 44.1kHz sample rate.  In doing so, I imagine I  have given implicit support to the commonly-held notion that this standard is perfectly adequate for use in high-end audio applications.  After all, this is what Sony and Phillips promised us back in 1982: “Pure, Perfect Sound – Forever”.  While the ‘forever’ part referred to the actual CD disk itself, the ‘pure, perfect sound’ part was clearly attributed to their new digital audio standard.
But if this really is ‘pure and perfect’ as the promise grandly claims, why, then, do we have all these Hi-Rez audio formats floating around?  Why do we need 24-bit formats if 16-bit is pure and perfect? Why all these high sample rates if what’s-his-name’s theory says 44.1kHz is plenty high enough?  Why bother with DSD and its phenomenally complicated underpinnings?  These are good questions, and need to be addressed.
The argument for the superiority of 24-bit over 16-bit is perhaps the least contentious and best understood aspect.  Simply put, every extra bit of bit depth allows us to push the noise floor down by an additional 6dB.  So the 8 extra bits offered by a 24-bit format translates to a whopping 48dB reduction in the noise floor.  Very roughly speaking, the very best analog electronics, microphones, and magnetic tape, all have a noise floor which is of the order of 20dB above that of 24-bit audio, and 20dB below that of 16-bit audio.  In simple terms, this means that 16-bit audio cannot come close to capturing the full dynamic range of the best analog signals you might ask it to encode, but 24-bit audio has it handily covered with plenty of margin in hand.
So, in areas of noise floor and dynamic range, going from 16-bit to 24-bit buys us a great deal of potential benefit at a cost of only 50% in additional file size.  I say ‘potential’ benefit, because you do require seriously high quality source material in order to take advantage of those benefits.  But if you’re reading this, the chances are you have more than just a passing interest in ‘seriously high quality source material’!
Moving on to the sample rate.  There are two immediately obvious benefits to increasing the sample rate.  First of all, there is actually a further reduction in the noise floor to be had.  Without going into all the ifs and buts, this amounts to an additional 3dB of noise floor reduction for every doubling of the sample rate.  However, since moving to 24-bit sampling has bought us all the noise floor reduction we can handle, this aspect of increased sample rate is not really very exciting.  The second obvious benefit is more nuanced – the fact that by increasing the sampling rate we can also increase the frequency range that we can capture.  This bears examination in more detail.
Suppose we double the sample rate from 44.1kHz to 88.2kHz, and thereby double the Nyquist frequency from 22.05kHz to 44.1kHz.  This means we can now capture a range of audio frequencies that extend quite a way above the nominal upper limit of audibility.  This is where things start to get contentious.  The main issue is that the vast majority of scientific study tends to support the general notion that as human beings we don’t hear any frequencies above 20kHz.  Furthermore, that only applies to what Vinny Gambini memorably referred to as “yoots”.  Once you get to my age, you’ll be lucky if you can still make it to 15kHz.  However, the topic of frequency audibility does throw up some occasional odd results.
For example, in a scientific paper from 2000, Tsutomu Oohashi et al reported that by measuring a number of subjects’ EEG and PET scan responses, they showed that when played Gamelan music (known to be rich in ultrasonic harmonics) their brains did in fact respond to frequencies above 22kHz.  The problem is that this paper’s results – referred to as the ‘Hypersonic Effect’ – have not been satisfactorily replicated, and in addition some valid technical criticisms have been made of its methodology.  Even the authors themselves showed no apparent interest in following up on their work.
Overall, this, like other arguments of its ilk, doesn’t appear to provide any plausible basis upon which to build a case in favor of high sample rate PCM formats.
Various other studies have looked at ways of assessing whether or not the human ear/brain is capable of resolving sonic effects due to relative timing factors – such as the discernability of time misalignment between signals from spatially displaced speakers (Milind Kunchur, 2007) – and a reasonably consistent picture emerges that we are sensitive to time alignments in the range 1-10μs.  This has been argued to imply that our brains are able to process audio signals with a bandwidth approaching 100kHz.  This is interesting because it suggests (in a roundabout kind of way) that we may be able to perceive certain effects of hypersonic harmonics of audible frequencies, without necessarily being able to detect those harmonics in isolation (i.e. Oohashi’s idea redux).
Any treatment of timing-related issues opens the door to the discussion of phase, since phase and timing are one and the same thing.  A phase error applied to a particular frequency simply means that that frequency is delayed (or advanced) in time.  For example, a time delay of 10μs is exactly the same as a phase retard of 0.628 radians for a 10kHz frequency.  Interesting things happen when you start to apply different time delays (i.e. different phase errors) to the different individual frequencies within a waveform.  What happens is that the frequency response doesn’t change per se, but the shape of the waveform does.  So the question arises – are phase errors which change the shape of a waveform, but not its frequency content, audible?  It has taken a while, but a consensus seems to be emerging that yes, they are.
The connection between the audibility of phase and the improved fidelity of high sample-rate PCM recording is a slightly tortuous one, but I believe it is very important.  Recall that Nyquist/Shannon sampling theory requires the very simple assumption that the signal is band-limited to the Nyquist Frequency.  Therefore, in any practical implementation, a signal has to be passed through a low-pass filter before it can be digitally sampled.  I’m running short of room in this column, but basically, the lower the sampling rate, the more aggressive this low-pass ‘anti-aliasing’ filter needs to be, because the Nyquist Frequency gets closer and closer to the upper limit of the audio band.  With 44.1kHz sampling, the two are very close indeed.
As a pretty good rule of thumb, the more aggressive the filter, the greater the phase (and other) errors it introduces.  These errors are at their worst at the frequencies above the top of the audio band where the filter is doing most of its work, but the residual phase errors do leak down into the audio band itself.  My contention is that the ‘sound’ of PCM audio – to the extent that it adds a distinct sound signature of its own – is the ‘sound’ of the band-limiting filters that the signal must go through before being digitally encoded.  And I attribute a significant element of that ‘sound signature’ – if not the whole ball of wax – to phase errors.  By progressively increasing the sample rate, it allows you to use progressively more gentle anti-aliasing filters, whose phase errors may be less and less sonically intrusive.
Interestingly, with DSD, because the sample rate is so high, we can consider it to have effectively a linear phase response across the entire audio band and into the hypersonic range.  Indeed, this may well be a significant reason why its adherents prefer its sound over high sample-rate PCM.
I believe that end-to-end (i.e. Mic-to-Speaker) phase linearity is going to be the next major advance in digital audio technology, one which we will see flower during the next decade.  In fact, it may be that this is at least one of the precepts behind the nascent MQA technology.
More from Issue 22
View All Articles in Issue 22
Favorites From T.H.E. Show SoCal 2026 by Cam Martin Oct 05, 2026 #235 Singer/Songwriter John David Schrader: On the Need to Create, Part Two by Joe Caplan Oct 05, 2026 #235 A Life in High-End Audio: The Roy Hall Interview, Part Two by Frank Doris Oct 05, 2026 #235 Grammy-Winning Producer, Songwriter, and Guitarist John Leventhal Goes Instrumental With National Drift by Ray Chelstowski Oct 05, 2026 #235 From Swimming Pool to New Listening Room—to Founding an Accidental Audio Company by Gilles Laferrière Oct 05, 2026 #235 The Vinyl Beat’s Size Matters Edition by Rudy Radelic Oct 05, 2026 #235 The Sublime Complexities of Nature by B. Jan Montana Oct 05, 2026 #235 How to Play In a Rock Band, 28: Growing Older and Dealing With It by Frank Doris Oct 05, 2026 #235 Young Rascals: From Bar Band to Stardom by Wayne Robins Oct 05, 2026 #235 Duncan Sheik: In Memoriam by Ray Chelstowski Oct 05, 2026 #235 From The Listening Chair: The Meze Audio 105 Silva Headphones by Howard Kneller Oct 05, 2026 #235 Checking Out Some NOLA Loudspeakers – and Some Thoughts About Audio Writing by Frank Doris Oct 05, 2026 #235 The Kanazawa Phonograph Museum: Music from a Time Capsule by Sebastian Polcyn Oct 05, 2026 #235 PS Audio in the News by PS Audio Staff Oct 05, 2026 #235 From The Audiophile’s Guide: Making the Most Critical Choice by Paul McGowan Oct 05, 2026 #235 Evolutionary Growth by Frank Doris Oct 05, 2026 #235 Speed Racer by Peter Xeni Oct 05, 2026 #235 Happy Halloween! by James Schrimpf Oct 05, 2026 #234 A Life in High-End Audio: The Roy Hall Interview, Part One by Frank Doris Sep 07, 2026 #234 Jason Greenlaw Offers His Personal Perspective on Jazz Guitar in Vantage Point by Frank Doris Sep 07, 2026 #234 Transcendent Phoenix: Lucina Yue Brings the Ancient Konghou Into Modern Times by Frank Doris Sep 07, 2026 #234 We Must All Follow Our Bliss by B. Jan Montana Sep 07, 2026 #234 How to Play in a Rock Band, 27: Leveling Up by Frank Doris Sep 07, 2026 #234 Ross Valory: Traveling Into New Musical Territory With All of the Above by Ray Chelstowski Sep 07, 2026 #234 Singer/Songwriter John David Schrader: On the Need to Create by Joe Caplan Sep 07, 2026 #234 The People Who Make Audio Happen: More From T.H.E. Show SoCal 2026 by Harris Fogel Sep 07, 2026 #234 The Vinyl Beat Digs Into the Gadget Box by Rudy Radelic Sep 07, 2026 #234 The Rolling Stones: Foreign Tongues Spoken Loud by Wayne Robins Sep 07, 2026 #234 Musical Moments by Rich Isaacs Sep 07, 2026 #234 Rags for Solo Piano and a Dog: David Chesky's Ragtime Music for the Modern Age by Frankly Speaking Sep 07, 2026 #234 HIGH END 2026, Vienna: Here to Stay by Carsten Barnbeck Sep 07, 2026 #234 From The Audiophile’s Guide: The Two Main Types of Loudpeakers – Box and Panel by Paul McGowan Sep 07, 2026 #234 Letting it Slide by Frank Doris Sep 07, 2026 #234 PS Audio in the News by PS Audio Staff Sep 07, 2026 #234 Long Playing by Peter Xeni Sep 07, 2026 #234 La Mer by B. Jan Montana Sep 07, 2026 #233 A Report From The Total Hi-Fi Experience Show SoCal 2026 by B. Jan Montana Aug 03, 2026 #233 Bluegrass Meets Country, Folk, Jazz and More in All That We Carried by The Squid City Slingers by Frank Doris Aug 03, 2026 #233 Corey Glover and One Tribe Nation: A Variegated Musical Collective by Ray Chelstowski Aug 03, 2026 #233 Excursions with Clive: The Late Clive Davis, A Personal History by Wayne Robins Aug 03, 2026 #233 AI, Art, and Music: A Conversation With Synthography Art by Joe Caplan Aug 03, 2026 #233 New American Symphonies: A Rediscovered Gem and a Vital Contemporary Work by Frank Doris Aug 03, 2026 #233 The Vinyl Beat: Genesis, the Dave Clark Five, Antonio Carlos Jobim and More by Rudy Radelic Aug 03, 2026 #233 How to Play in a Rock Band, 26: When It's Time to Record Your Music by Frank Doris Aug 03, 2026 #233 More From T.H.E. Show 2026, and the People Who Made it Happen by Harris Fogel Aug 03, 2026 #233 Underappreciated Artists, Part Three: Icehouse by Rich Isaacs Aug 03, 2026 #233 The Surprisingly Rich and Varied Music of Somalia by Steve Kindig Aug 03, 2026
