Issue 190 • Free Online Magazine
Issue 190 Revolutions Per Minute
Original Vinyl Pressings or Re-pressings – How Do You Choose?
Record collectors around the world will typically part with a much greater share of their hard-earned for a first pressing of an album, than for a subsequent re-pressing. But what does this actually mean, and is a first pressing any better in real manufacturing terms?
As previously discussed In Issues 92, 93, and -94, the vinyl record manufacturing process consists of three main stages: mastering, plating, and pressing. In the mastering stage, the recording is transferred from the medium it had been stored on (the master tape in the good old days and a variety of digital formats thereafter), to grooves on a blank master disk.
To ensure that the program material is compatible with how it would be represented on record grooves, signal processing may be applied, altering the original recording, with one of two aims. If the goal is the ultimate in sound quality and cost is no object (a very rare set of circumstances, both then and now), the usually very minimal changes that are applied during the disk mastering stage are intended to highlight the strengths of the particular mastering system with the given material and ensure that it sounds as good as possible when reproduced from the grooves of the final product. When the budget is low, signal processing often serves the purpose to merely to protect the sensitive cutter head from damage, with no regard to how this may impact the sound quality.
When an album is later remastered, the recording goes to the mastering stage anew, to create a new set of master disks. The new masters may be produced from a different source, using different equipment, by a different engineer, at a different facility. More often than not, remastering is necessitated because the original stampers (or mothers; see below) have been discarded, lost, damaged, or have deteriorated and a new set of masters is needed to create new sets of stampers for a repress. While all remastered records are also re-pressings, not all re-pressings are remastered. In purely technical terms, the remastering process does not in itself guarantee better results. It simply denotes that the final product may sound different from the original masters.
The author inspecting a freshly-cut lacquer master disk on a disk mastering lathe, using a microscope. Courtesy of Agnew Analog Reference Instruments.
Once the master disks are cut, whether these are original masters or the product of remastering, they are sent off for plating. In the plating stage, the stampers are created, which will then be used to press the multiple copies of the record.
A set of stampers can be used to press a few thousand records at most. This creates an interesting situation. An internationally renowned artist back in the 1970s could easily have a "first pressing" run of several hundred thousand copies, in anticipation of the expected volume of sales. That "first pressing" would not be possible with a single set of stampers and would most probably also require multiple sets of master disks, multiple sets of mothers and multiple sets of stampers, fitted to multiple presses. Depending on the standards of quality control, there could be minor or not-so-minor differences between records from within that first pressing. A "second pressing," done a few months later to satisfy the demand, would not necessarily have bigger differences that those found between samples from the first pressing.
Conversely, an artist at the onset of their career nowadays could order a first pressing of a mere 300 copies just to test the waters. If they sell, a repress of, say, another 300 copies would be made, using the same set of stampers used for the first pressing. In theory, sonic differences in this case would be extremely minor, if any at all. However, I have personally experienced two opposite extremes of unforeseen circumstances. In one case, the stampers were inadvertently damaged in between the first and second pressing. This created noise and distortion on the entire second pressing run. However, the opposite is also possible. In another instance, during the first pressing, some debris became lodged onto the stamper, creating a small click at a certain point in the music, during a quiet passage where it was quite noticeable, on approximately half of the records of the first pressing. For the repress, the stampers were carefully cleaned, so the repress actually sounds better than the first pressing, using the same set of stampers.
During the plating stage, multiple stampers can be generated from a metal mother. Replacing a worn or damaged stamper with a fresh one will usually result in a substantial improvement is sound quality. However, due to the nature of the plating process, the original "center" of the lathe is lost, requiring each stamper to be individually re-centered manually, using optical measurement instruments and a punch. This establishes the location of the center hole of the record, which would ideally be perfectly concentric with the groove spiral. In practice, however, there are manufacturing tolerances for that. As the stampers need to be securely mounted onto the molds of a hydraulic press, the hole punched on the stamper is larger in diameter than the center hole of the record, allowing a bush to be used to clamp the stamper down from the center. This leaves the characteristic mark around the center hole, under the paper label. A pin running in the bushing establishes the center hole on the final product.
As such, the centering of the stamper is only indirectly establishing a center. The accumulative errors of centering the stamper, mounting it on the mold, and the geometric errors of the pin, determine the overall concentricity of the final product. As a result, while a fresh stamper may improve some aspects of sound quality, it can introduce eccentricity, creating a different problem. Conversely, it could also happen that the fresh stamper is more accurately centered than the original, in which case the re-press would sound considerably better than the first pressing.
Scribing on a metal mother. Courtesy of Agnew Analog Reference Instruments.
The scribing on a metal mother. Courtesy of Agnew Analog Reference Instruments.
Last, but not least, comes the pressing stage itself. A re-press is often done years later, at a different pressing plant, sometimes in a different country. Different presses, in different states of wear and tear, using different steam, water and hydraulic installations, in different climate conditions, using different virgin or recycled vinyl compounds, with an enormous diversity in operator skill and in-house manufacturing standards, all have a huge effect upon the sound of the final product. Even just using a different PVC compound will make a difference, using the same stampers. It is extremely difficult to guess whether the original pressing or a subsequent re-press would offer the best sound quality, unless more information is known about where and how it was done.
Collectible items, with records being no exception, are not necessarily valued for their usability. Rarity and bragging rights may often be valued much more than the sound quality. I personally value sound quality above all else. A remaster or a re-press may be better or worse than the original, depending on a huge number of factors. As a general rule, if detailed information is offered regarding how the process was done and specific people are named for doing it, this is usually a sign that quality did matter. If no information is offered, more often than not, there is nothing exciting to say. Would you buy a record advertised as "Remastered using automated settings by whoever worked the night shift and then pressed at the cheapest place we could find with no quality control whatsoever? " If the re-issue just states "Remastered," it probably looks better in terms of marketing cachet, but may imply the above. However, an original pressing does not necessarily mean that it wasn't mastered by the new trainee working the graveyard shift. Information is key to being able to estimate how high your expectations should be set. The availability of information adds value to a product, for me. Marketing is all nice, but it is the real substance behind it that makes a record sound good or not.
An SMT record press at United Record Pressing. Courtesy of Wikimedia Commons/David McClister.
Header image:  J.I. Agnew reflected on a metal mother, played back on a turntable with a Shure V15III cartridge on an SME tonearm. Courtesy of Agnew Analog Reference Instruments.
More from Issue 190
View All Articles in Issue 190
#231 Piano Prodigy Jude Kofie Releases His Debut Album On Octave Records by Frank Doris Jun 01, 2026 #231 Underappreciated Artists, Part Two: City Boy by Rich Isaacs Jun 01, 2026 #231 Music and the Art of Creation: Talking With Saxophonist Rob Scheps by Joe Caplan Jun 01, 2026 #231 How to Play in a Rock Band, 24: Further Adventures at the 2026 Montauk Music Festival by Frank Doris Jun 01, 2026 #231 Courtney Barnett: Creature of Habit by Wayne Robins Jun 01, 2026 #231 Angine de Poitrine: Interstellar Guitar Rock Saviors Headed for Late-Night TV Pop Stardom? by Mark Lepage Jun 01, 2026 #231 My Impressions of AXPONA 2026, Part One by Frank Doris Jun 01, 2026 #231 2026 La Jolla Concours d'Elegance: Another Aesthetic Feast by B. Jan Montana Jun 01, 2026 #231 Country Music Icon Jo Dee Messina’s Bridges: A New Beginning by Ray Chelstowski Jun 01, 2026 #231 The Luxury Dispatch Hosts a Video Podcast With Ken Kessler by Ken Kessler Jun 01, 2026 #231 The Vinyl Beat: Tracking in the Motor City by Rudy Radelic Jun 01, 2026 #231 Lots of Fun With DSP: The Ferrum Audio WANDLA DAC and Its Tube Mode by Frank Doris Jun 01, 2026 #231 From The Audiophile's Guide: Digital Source Components and Streaming Audio by Paul McGowan Jun 01, 2026 #231 Onkyo’s Monster M-510 power amplifier by The Staff at Just Audio Jun 01, 2026 #231 PS Audio in the News by PS Audio Staff Jun 01, 2026 #231 Naming Convention by Peter Xeni Jun 01, 2026 #231 Les Invisibles by Frank Doris Jun 01, 2026 #231 Wildlife Scene by James Schrimpf Jun 01, 2026 #230 Camaraderie by B. Jan Montana May 04, 2026 #230 AXPONA 2026: A Family Gathering by Paul McGowan May 04, 2026 #230 Pianist Ryan Benthall Explores Jazz Realms and Far Beyond With Divine Sky by Frank Doris May 04, 2026 #230 The Vinyl Beat in AXPONA-Land by Rudy Radelic May 04, 2026 #230 Teddy Thompson’s Musical Growth Deepens With Never Be the Same by Ray Chelstowski May 04, 2026 #230 More Fun in the Sun: Florida Audio Expo, Part Two by Frank Doris May 04, 2026 #230 CanJam NYC 2026 Show Report: Heady Sound, Part Two by Frank Doris and Harris Fogel May 04, 2026 #230 Sonic Youth On Murray Street by Wayne Robins May 04, 2026 #230 Graffeo Coffee: A Symphony of Sensory Experience by Joe Caplan May 04, 2026 #230 The Saul Authority: The Story of Hi-Fi Pioneer Saul Marantz by Olivier Meunier-Plante May 04, 2026 #230 How to Play in a Rock Band, 23: Encounters With Famous Musicians, Part Two by Frank Doris May 04, 2026 #230 An Outlier in the Rack: A Vintage BIC Beam Box by The Staff at Just Audio May 04, 2026 #230 PS Audio in the News by PS Audio Staff May 04, 2026 #230 A Cautionary Tale by Rich Isaacs May 04, 2026 #230 Reel-to-Reel Roots, Part 33 (Revised): Ken Kessler Reports On the 2026 (British) AudioJumble by Ken Kessler May 04, 2026 #230 Text Messaging by Frank Doris May 04, 2026 #230 The Audiophile Rat Race by Peter Xeni May 04, 2026 #230 On the Rocks by Rich Isaacs May 04, 2026 #229 The Earliest Stars of Country Music, Part Three by Jeff Weiner Apr 06, 2026 #229 The Healing Power of Music and Sound at the Omega Institute by Joe Caplan Apr 06, 2026 #229 CanJam NYC 2026 Show Report: Heady Sound, Part One by Frank Doris Apr 06, 2026 #229 Florida Audio Expo 2026: Warming Up to High-End Audio, Part One by Frank Doris Apr 06, 2026 #229 Quick Takes: Anne Bisson, Sam Morrison, The Velvet Underground, and the Stooges by Frank Doris Apr 06, 2026 #229 The Vinyl Beat: New Arrivals, and Old Audio Show Demo Scores to Settle by Rudy Radelic Apr 06, 2026 #229 Harvard Gets a High-End Audio Education by Frank Doris Apr 06, 2026 #229 No Country for Old Knees by B. Jan Montana Apr 06, 2026 #229 How To Play in A Rock Band, 22: Encounters With Famous Musicians, Part 1 by Frank Doris Apr 06, 2026 #229 The Soulful Grooves of Guinea-Bissau by Steve Kindig Apr 06, 2026 #229 Four-Hand Piano Performance at Its Finest by Stephan Haberthür Apr 06, 2026
