Issue 213 • Free Online Magazine
Issue 213 Frankly Speaking
How to Play In a Rock Band, Part Six: Playing On Small Stages
If you’re in most of the bands out there, playing mostly local gigs, most of the time you’ll be playing on a small stage. Or maybe, a tiny stage. Or even no stage at all. Space will be at a premium. When our band used to play at Sea Levels in Brightwaters, New York, we were shoehorned into a corner of the room to the left of the entrance, and space was so tight that if I would have moved my guitar neck more than a few inches to the left, the headstock would have smashed into a glass-framed picture on the wall. The drummer had to gingerly step over my amp to get to and from his drum throne.
The author at Sea Levels, Brightwaters, New York, March 24, 2016. A quick move to the left and that picture on the wall would have been trashed. Forgive the poor photo quality and questionable dye job.
In future installments I’ll talk about playing on medium and large stages, and outdoors, all of which have particular considerations regarding fitting the band on stage, what equipment to use, how to perform, and in the case of playing outside, how do deal with extreme hot and cold temperatures.
But on small stages, the uppermost and overriding consideration is: space is at a premium. As noted, you may not have much room to move around, or any room at all. At one gig at the Sail Inn in Montauk, NY, halfway through the first set my leg started cramping up because I had to hold it in an awkward position because otherwise I would have tripped over one of the speaker stands, or bumped into the singer. Bring the least amount of equipment possible, and the smallest in size, whether an amp, drum set, stage monitor speaker (and be prepared for the fact that you may not be able to fit a monitor on stage at all), or anything else.
On really small playing areas, if you’re a guitarist or bassist who likes to use a pedalboard, forget it. Even a 12-inch square pedalboard will take up way too much real estate. (If you think I’m exaggerating, wait until you encounter a situation like this.) Bring your essential overdrive and maybe one other pedal. Use a clip-on tuner. Don’t be precious about getting “your sound.” On tiny stages, use equipment that fits – literally. The drummer in the band may have to cut down on their amount and size of drums and cymbals.
My pal Henry Diaz (second from right) and band playing at the Gallery North Art Show and Music Festival, East Setauket, NY, September 26, 2024. There was enough room for pedalboards and stage monitors here. On some stages, there isn't.
Be considerate of your fellow band members. Everyone in the band is going to have to conserve space and make room for everyone else. Literally every square foot counts. Angle the microphone and speaker stands so that they poke into the standing room area as little as possible. If you can, check out the venue before the gig, to see just how much – or how little – space you’ll have, so you know what gear will be practical to bring.
You’re going to have to be smart about storing the band’s instrument cases, gig bags, drum cases or bags, and everything else anywhere but on the stage if at all possible. A tip: put all this stuff in your car before the gig rather than storing it on stage. Another tip: multiple guitar stands take up a lot of space. Figure out how many guitars and basses you’ll need and bring a double or triple stand, or one of those five- or six-guitar racks. If there’s simply no room for a stand at all, you can store your guitar or bass in your car between sets.
Try to keep the instrument and mic cords out of the way, to minimize the chance of tripping or stepping on them. On any stage, large or small, it’s a good idea to run the mic and PA speaker cables around and behind the band.
The odds are, you’re not going to have a sound person to mix your sound, and you may not have enough room to set up a mixer anywhere but on the stage. Putting the mixer on top of an amp will conserve space, if possible. As noted, you may not even have space for even a single onstage monitor speaker, so you’ll have to try to place the main speakers where you’ll be able to hear them, a tricky situation since if they’re behind your microphones you may have to deal with feedback issues and be limited by the amount of volume you can obtain.
When space is tight: even rock stars like Danny Miranda (Blue Öyster Cult, Queen, Meat Loaf and others) and George Cintron (Trans Siberian Orchestra, Enrique Iglesias, others) find a way to make room. Notice the small PA speakers on the right, and the mixer on top of an impromptu amp stand. The Ritz, Northport, NY, July 25, 2024.
However, if you or the band are playing mostly acoustic instruments, you may not even need PA speakers at all, but can get away with an all-in-one amp like the extremely popular Fishman Loudbox Mini. Just plug in an acoustic/electric guitar and a mic, and you’re good to go. I’ve seen numerous players use the Mini even on outdoor gigs and it’s more than enough to provide high-quality sound. And some small electric and acoustic guitar amplifiers are remarkably capable, loud, and clear, like the Henriksen Bud and Blu series amps, the AER amplifiers, and the incredibly small but powerful Phil Jones bass amps.
A terrific compact PA option is one of the Bose L1 Series portable line array systems. Introduced in 2003, the L1 models were revolutionary, comprised of a thin main driver column just a few inches wide, a subwoofer, built-in amplification, and a mixer. The L1 models set up in minutes and have become so successful they've spawned many imitators.
In smaller rooms, keeping the volumes of the instruments and vocals at a reasonable level is crucial. People need to be able to have conversations and not yell over the music, especially when ordering drinks or food. It’s a good idea to ask one of the people working at the bar, or restaurant, or wherever, if the overall volume is OK or too loud. The drummer may have to use rods or “rute sticks” or even brushes rather than standard drumsticks, in order to play at a lower volume.
This goes for gigs on medium and larger stages as well: keep your eye on the gear and instruments during breaks. Never let everyone in the band walk away from the stage, to make sure nothing gets stolen. The same goes for load in and load out. In more than 50 years of playing I’ve never had anything ripped off, but it’s because I’ve watched my gear like the proverbial hawk from the second I get to the venue to the moment I finish packing everything up.
There might even be gigs where there’s not enough room for the entire band to play. When our band played the Long Island Music and Entertainment Hall of Fame in January 2023, we were told that the band couldn’t have more than four pieces. (They’ve since built a larger stage.) At many establishments, there isn’t room for more than a trio or duo, or even for more than a single musician. So, either the band won’t be able to play such a venue, or you may have to play as a two-or three-piece and adapt the band’s style accordingly.
The good news is that most venues will allow a band enough room to stretch out somewhat, even if you won’t be able to prowl the stage. In the next installment I’ll talk about playing on medium-sized stages, where you can spread your wings a little and even perfect your rock star dance moves.
Header image: the stage at a party in Brightwaters, NY, July 19, 2024.
More from Issue 213
View All Articles in Issue 213
#231 Piano Prodigy Jude Kofie Releases His Debut Album On Octave Records by Frank Doris Jun 01, 2026 #231 Underappreciated Artists, Part Two: City Boy by Rich Isaacs Jun 01, 2026 #231 Music and the Art of Creation: Talking With Saxophonist Rob Scheps by Joe Caplan Jun 01, 2026 #231 How to Play in a Rock Band, 24: Further Adventures at the 2026 Montauk Music Festival by Frank Doris Jun 01, 2026 #231 Courtney Barnett: Creature of Habit by Wayne Robins Jun 01, 2026 #231 Angine de Poitrine: Interstellar Guitar Rock Saviors Headed for Late-Night TV Pop Stardom? by Mark Lepage Jun 01, 2026 #231 My Impressions of AXPONA 2026, Part One by Frank Doris Jun 01, 2026 #231 2026 La Jolla Concours d'Elegance: Another Aesthetic Feast by B. Jan Montana Jun 01, 2026 #231 Country Music Icon Jo Dee Messina’s Bridges: A New Beginning by Ray Chelstowski Jun 01, 2026 #231 The Luxury Dispatch Hosts a Video Podcast With Ken Kessler by Ken Kessler Jun 01, 2026 #231 The Vinyl Beat: Tracking in the Motor City by Rudy Radelic Jun 01, 2026 #231 Lots of Fun With DSP: The Ferrum Audio WANDLA DAC and Its Tube Mode by Frank Doris Jun 01, 2026 #231 From The Audiophile's Guide: Digital Source Components and Streaming Audio by Paul McGowan Jun 01, 2026 #231 Onkyo’s Monster M-510 power amplifier by The Staff at Just Audio Jun 01, 2026 #231 PS Audio in the News by PS Audio Staff Jun 01, 2026 #231 Naming Convention by Peter Xeni Jun 01, 2026 #231 Les Invisibles by Frank Doris Jun 01, 2026 #231 Wildlife Scene by James Schrimpf Jun 01, 2026 #230 Camaraderie by B. Jan Montana May 04, 2026 #230 AXPONA 2026: A Family Gathering by Paul McGowan May 04, 2026 #230 Pianist Ryan Benthall Explores Jazz Realms and Far Beyond With Divine Sky by Frank Doris May 04, 2026 #230 The Vinyl Beat in AXPONA-Land by Rudy Radelic May 04, 2026 #230 Teddy Thompson’s Musical Growth Deepens With Never Be the Same by Ray Chelstowski May 04, 2026 #230 More Fun in the Sun: Florida Audio Expo, Part Two by Frank Doris May 04, 2026 #230 CanJam NYC 2026 Show Report: Heady Sound, Part Two by Frank Doris and Harris Fogel May 04, 2026 #230 Sonic Youth On Murray Street by Wayne Robins May 04, 2026 #230 Graffeo Coffee: A Symphony of Sensory Experience by Joe Caplan May 04, 2026 #230 The Saul Authority: The Story of Hi-Fi Pioneer Saul Marantz by Olivier Meunier-Plante May 04, 2026 #230 How to Play in a Rock Band, 23: Encounters With Famous Musicians, Part Two by Frank Doris May 04, 2026 #230 An Outlier in the Rack: A Vintage BIC Beam Box by The Staff at Just Audio May 04, 2026 #230 PS Audio in the News by PS Audio Staff May 04, 2026 #230 A Cautionary Tale by Rich Isaacs May 04, 2026 #230 Reel-to-Reel Roots, Part 33 (Revised): Ken Kessler Reports On the 2026 (British) AudioJumble by Ken Kessler May 04, 2026 #230 Text Messaging by Frank Doris May 04, 2026 #230 The Audiophile Rat Race by Peter Xeni May 04, 2026 #230 On the Rocks by Rich Isaacs May 04, 2026 #229 The Earliest Stars of Country Music, Part Three by Jeff Weiner Apr 06, 2026 #229 The Healing Power of Music and Sound at the Omega Institute by Joe Caplan Apr 06, 2026 #229 CanJam NYC 2026 Show Report: Heady Sound, Part One by Frank Doris Apr 06, 2026 #229 Florida Audio Expo 2026: Warming Up to High-End Audio, Part One by Frank Doris Apr 06, 2026 #229 Quick Takes: Anne Bisson, Sam Morrison, The Velvet Underground, and the Stooges by Frank Doris Apr 06, 2026 #229 The Vinyl Beat: New Arrivals, and Old Audio Show Demo Scores to Settle by Rudy Radelic Apr 06, 2026 #229 Harvard Gets a High-End Audio Education by Frank Doris Apr 06, 2026 #229 No Country for Old Knees by B. Jan Montana Apr 06, 2026 #229 How To Play in A Rock Band, 22: Encounters With Famous Musicians, Part 1 by Frank Doris Apr 06, 2026 #229 The Soulful Grooves of Guinea-Bissau by Steve Kindig Apr 06, 2026 #229 Four-Hand Piano Performance at Its Finest by Stephan Haberthür Apr 06, 2026
