Issue 185 • Free Online Magazine
Issue 185 Featured
Eccentric Records (and How to Fix Them)
We are talking here about physical, not psychological or emotional, eccentricity (that could be a whole ‘nother article). In Issue 184, fellow writer (and parts fabricator extraordinaire) J.I. Agnew wrote of a simple device he created to center vinyl records that had an oversized, but centered, spindle hole. He allowed that his creation could not correct for records that were pressed off-center. A reader commented that there was such a device – the DS Audio ES-001 Eccentricity Detector. The problem (for most of us) is that it costs $5,995. I have to wonder how many have been sold at such a dear price.
Decades ago, I came up with a very low-tech, but effective, means of reasonably centering records that had been pressed off-center. It is not capable of making fine, micrometer-level corrections, but if you can see the arm moving back and forth as the record rotates, it will nearly eliminate that movement and the resulting gross pitch variation.
The record label showing the spindle hole before modification.
Step One: Identify the point at which the stylus is farthest from the center when the record is rotating. Observe the movement and try to locate the spot on the label that is directly across from the stylus. If you can carefully (I said CAREFULLY) rotate the platter more slowly by hand, it is a little easier to determine the right spot. Identify whatever writing is radially across from the stylus at its farthest point, and use a small piece of a Post-it note (or something temporary) to mark that point.
The enlarged hole.
Step Two: You will need to remove the record from the platter and gently ream out the hole only where it is closest to the point you marked. You are not trying to create a larger circular hole, but rather a slightly oval or egg-shaped opening. There are many common items that can be used as a reaming tool – a metal nail file, a small screwdriver, or something similar. You want something that is narrow enough to move in the hole, and you only want one edge to contact the vinyl as you work – you don’t want to scrape away any of the hole that is not across from your target point.
It's the Swiss Army knife of record hole modification tools!
I found the perfect tool in the scraper/reamer blade on the Swiss Army knife I’ve had since high school. Use a small back-and-forth motion. Again, be very careful, because one slip and your tool can go right across the grooves. How much you need to scrape away involves a trial-and-error approach. Do a little reaming and put the record back on the turntable, pushing the reamed area against the spindle. Observe the arm movement again and determine if it still appears off-center. If it does, repeat the process until you are satisfied with the result.
(The Phillips screwdriver/file blade is also useful if you just need to enlarge the hole all around. The cross-section of the shaft has both a right angle and an arc. The shaft is almost exactly the diameter of turntable spindles and record center holes. The sharp right angle edge of the shaft works to scrape the vinyl.)
Here's the enlarged hole with the mark indicating where to place it on the turntable spindle.
Step Three: Draw an arrow on the inside of the label where you reamed pointing to the spindle (hey, you’ve already messed with the resale value by reaming the hole, so who cares?). Whenever you play the record, simply push the arrow against the spindle. It is a good idea to put a Post-it note on the inner sleeve telling you that you need to center it each time you play.
It is possible (probable?) that you may need to repeat this whole process for the other record side. At the very least, you should determine the best spot and mark the label at the center hole on both sides.
This procedure has rescued some of my albums, taking them from unlistenable to enjoyable. Alas, I could not remember which ones, so I had to sacrifice a junk LP for illustration purposes (please don’t judge me by the title). I did forget to mark the spot on the label with a Post-it prior to starting the reaming, but it was where the catalog number (KL 1118) appeared.
More from Issue 185
View All Articles in Issue 185
#231 Piano Prodigy Jude Kofie Releases His Debut Album On Octave Records by Frank Doris Jun 01, 2026 #231 Underappreciated Artists, Part Two: City Boy by Rich Isaacs Jun 01, 2026 #231 Music and the Art of Creation: Talking With Saxophonist Rob Scheps by Joe Caplan Jun 01, 2026 #231 How to Play in a Rock Band, 24: Further Adventures at the 2026 Montauk Music Festival by Frank Doris Jun 01, 2026 #231 Courtney Barnett: Creature of Habit by Wayne Robins Jun 01, 2026 #231 Angine de Poitrine: Interstellar Guitar Rock Saviors Headed for Late-Night TV Pop Stardom? by Mark Lepage Jun 01, 2026 #231 My Impressions of AXPONA 2026, Part One by Frank Doris Jun 01, 2026 #231 2026 La Jolla Concours d'Elegance: Another Aesthetic Feast by B. Jan Montana Jun 01, 2026 #231 Country Music Icon Jo Dee Messina’s Bridges: A New Beginning by Ray Chelstowski Jun 01, 2026 #231 The Luxury Dispatch Hosts a Video Podcast With Ken Kessler by Ken Kessler Jun 01, 2026 #231 The Vinyl Beat: Tracking in the Motor City by Rudy Radelic Jun 01, 2026 #231 Lots of Fun With DSP: The Ferrum Audio WANDLA DAC and Its Tube Mode by Frank Doris Jun 01, 2026 #231 From The Audiophile's Guide: Digital Source Components and Streaming Audio by Paul McGowan Jun 01, 2026 #231 Onkyo’s Monster M-510 power amplifier by The Staff at Just Audio Jun 01, 2026 #231 PS Audio in the News by PS Audio Staff Jun 01, 2026 #231 Naming Convention by Peter Xeni Jun 01, 2026 #231 Les Invisibles by Frank Doris Jun 01, 2026 #231 Wildlife Scene by James Schrimpf Jun 01, 2026 #230 Camaraderie by B. Jan Montana May 04, 2026 #230 AXPONA 2026: A Family Gathering by Paul McGowan May 04, 2026 #230 Pianist Ryan Benthall Explores Jazz Realms and Far Beyond With Divine Sky by Frank Doris May 04, 2026 #230 The Vinyl Beat in AXPONA-Land by Rudy Radelic May 04, 2026 #230 Teddy Thompson’s Musical Growth Deepens With Never Be the Same by Ray Chelstowski May 04, 2026 #230 More Fun in the Sun: Florida Audio Expo, Part Two by Frank Doris May 04, 2026 #230 CanJam NYC 2026 Show Report: Heady Sound, Part Two by Frank Doris and Harris Fogel May 04, 2026 #230 Sonic Youth On Murray Street by Wayne Robins May 04, 2026 #230 Graffeo Coffee: A Symphony of Sensory Experience by Joe Caplan May 04, 2026 #230 The Saul Authority: The Story of Hi-Fi Pioneer Saul Marantz by Olivier Meunier-Plante May 04, 2026 #230 How to Play in a Rock Band, 23: Encounters With Famous Musicians, Part Two by Frank Doris May 04, 2026 #230 An Outlier in the Rack: A Vintage BIC Beam Box by The Staff at Just Audio May 04, 2026 #230 PS Audio in the News by PS Audio Staff May 04, 2026 #230 A Cautionary Tale by Rich Isaacs May 04, 2026 #230 Reel-to-Reel Roots, Part 33 (Revised): Ken Kessler Reports On the 2026 (British) AudioJumble by Ken Kessler May 04, 2026 #230 Text Messaging by Frank Doris May 04, 2026 #230 The Audiophile Rat Race by Peter Xeni May 04, 2026 #230 On the Rocks by Rich Isaacs May 04, 2026 #229 The Earliest Stars of Country Music, Part Three by Jeff Weiner Apr 06, 2026 #229 The Healing Power of Music and Sound at the Omega Institute by Joe Caplan Apr 06, 2026 #229 CanJam NYC 2026 Show Report: Heady Sound, Part One by Frank Doris Apr 06, 2026 #229 Florida Audio Expo 2026: Warming Up to High-End Audio, Part One by Frank Doris Apr 06, 2026 #229 Quick Takes: Anne Bisson, Sam Morrison, The Velvet Underground, and the Stooges by Frank Doris Apr 06, 2026 #229 The Vinyl Beat: New Arrivals, and Old Audio Show Demo Scores to Settle by Rudy Radelic Apr 06, 2026 #229 Harvard Gets a High-End Audio Education by Frank Doris Apr 06, 2026 #229 No Country for Old Knees by B. Jan Montana Apr 06, 2026 #229 How To Play in A Rock Band, 22: Encounters With Famous Musicians, Part 1 by Frank Doris Apr 06, 2026 #229 The Soulful Grooves of Guinea-Bissau by Steve Kindig Apr 06, 2026 #229 Four-Hand Piano Performance at Its Finest by Stephan Haberthür Apr 06, 2026
The enlarged hole.
