Issue 175 • Free Online Magazine
Issue 175 Speaker Stories
Dealing With Small-Room Acoustics, Part One
Does this complaint sound familiar? “I have a small room and I just can’t get it to sound good.”
Many if not most of us have small to medium-sized listening rooms. One of the biggest problems of small room acoustics is that of the first reflections off of the walls, floors and ceilings. (For those who may be newer to the subject, first reflection points are just what the term implies – the indirect sound from the loudspeakers that reflects or bounces off the side walls, floor, and ceiling. These arrive later in time than the direct sound from the speakers, and can degrade the overall sound, frequency response, and imaging.) But there are many other considerations I’d also like to cover.
Put simply, small rooms encompass practically all domestic living spaces, with the exceedingly rare exception of someone’s domestic listening space being in a mansion or a barn, or rarer still, on par with an auditorium or hall. For most of us, our listening spaces constitute the “small” or “really small” category.
It’s helpful to realize that the bigger our room is, the more the speakers influence the overall sound, and conversely, the smaller the room, the greater the room’s effect on what we hear. (That said, it’s important to match the size of the speakers to the size of the room, a topic we’ll get into in a future installment. This also assumes you’re not doing near-field listening close to the speakers, which mitigates a lot of room issues but is not for everyone.) And when we talk about rooms, a big part of what we’re really talking about are the actual surfaces of the room, which define what we hear along with the effect of the room dimensions themselves.
One outstanding and mostly overlooked example of how to improve your room acoustics is that of installing a suspended or drop ceiling with absorptive tiles. (Metal ceiling tiles need not apply!) Because of the fibrous nature of acoustical tiles and the volume of air between the tiles and the ceiling, this acts as a huge ceiling-based bass trap, and is excellent for quelling unwanted vertically-traveling bass nodes (but not the horizontal ones). If floor footprint area is at a serious premium, installing a drop ceiling could be especially worth considering, albeit it’s a relatively expensive and not necessarily practical or aesthetically pleasing option – and you still have the issue of having to manage your horizontally-traveling reflection points and room nodes, areas of bass peaks and dips that compound and cancel each other. (See my articles, “Sub Missive” in Issue 137, “Subliminal or Sublime Bass?” in Issue 138, “Standing Room Only” in Issue 139, “The Audio Butterfly Effect” in Issue 143 and “Finding a Place for Bass” in Issue 144 for more insights.)
Okay, okay, you may well hate this suspended ceiling idea. Don’t worry; there are plenty of other ways to optimize the acoustics of smaller listening rooms. Another approach is the use of multiple subwoofers, rather than just one, or as in many peoples’ cases, none at all. The use of multiple subs can create a more even in-room bass response, as discussed in “Standing Room Only” and “The Audio Butterfly Effect.”
A small- to medium-sized listening space. Courtesy of Pexels.com/Huy Quang Nguyễn.
If you’re a veteran audio person, you may have heard about the room transition frequency, also known as the Schroeder frequency, and that making EQ adjustments to our room’s frequency response above this frequency doesn’t help our cause very much. Why? The short answer is that below the Schroeder frequency, typically between around 100 and 250 Hz, the room acts as a resonator, and above the Schroeder frequency, as a reflector and diffusor of sound.
Therefore, our room’s response can be broken down into two basic parts: the bass region where low-frequency room modes have a significant effect; and the stochastic or “random behavior” zone. The Schroeder frequency is the transition from the bass frequencies and the stochastic zone. (The Schroeder frequency is lower in a smaller room and higher in a larger room.)
The low-frequency region is where room modes create dips and peaks in the bass response, the result of areas of bass cancellation and reinforcement. When room response is measured you can see these peaks and troughs quite easily. (Today there are readily-available software utilities like REW Room EQ Wizard that make sophisticated measurements available to home users.)
The stochastic – midrange to treble – zone also contains modes, peaks and troughs, but they’re much less severe, perhaps more like a closed accordion with the bellows pressed flat up against each other, and the dips and peaks are now so close to each other that they are no longer distinguishable. (Note that because of the stochastic – random – nature of the room’s behavior, you might see subtle changes every time you take a room measurement, but from a practical standpoint, this won’t be anything that you might actually hear as a difference.
So, what can we do about these early reflections and tame our room’s response to them? The first thing is to identify where the points of first reflections are. There is a practical way of identifying them which has become a time-honored audiophile procedure. Get a friend to hold a mirror along the left wall while you sit in your listening position. He should hold the mirror at your eye level. Then ask your friend to move along the wall until you can see the reflection of your left speaker’s tweeter in the mirror. This will be your first reflection point for the left speaker. Mark this point, as this is where you’ll want to apply absorptive room treatment. Repeat the procedure for the right wall and speaker.
Absorptive material placed at the points of first reflections on the side walls. (Other room treatment is also shown.) Courtesy of GIK Acoustics.
We will cover some suggested room treatment considerations in more depth in later installments. But addressing the first reflection points will go a long way in improving the sound of your listening room, right off the bat.
Making EQ adjustments to compensate for low-frequency room nodes is an effective technique for evening out in-room bass response. By why is it that making EQ adjustments in the stochastic zone’s frequencies is generally less significant for improving our sound? It’s because the amount of audio information here is so great that your brain operates as a filter, and ignores a lot of the information. It’s also because, as noted, the higher-frequency modes are very close together and not as severe. EQ can certainly be effective in the midrange and high frequencies to address other issues, like a speaker that’s overly bright, but it should be used judiciously so as not to degrade the overall signal integrity more than is really necessary. Be cautious to generally only adjust to reduce “gremlin peaks “rather than boost vacuous dips, for example.
Add to this the reality is the fact that the measurements obtained by the measurement microphone are not truly representative of what your ears are hearing. Your ears come in pairs, each in a different position to each other, whereas your measurement mic will most likely be a single omnidirectional microphone. The mic is only going to be able to give a representation of what audio signals are being put into the room. Your ears hear a much more sophistically processed and filtered stereo sound, compared to the microphone, which takes in everything and does not filter what it “hears.” (And keep in mind that different measurement mics can have different frequency responses.)
Also consider: microphones sample the sum total of a room’s direct and reflected sound, and off-axis response without differentiating between any of it, as opposed to what your ears hear. That said, measurement software and microphones are valuable tools in measuring the frequency response of rooms, something that can’t be done “by ear” alone!
In Part Two of this series, we’ll briefly look at what may compound the problem of the measurement microphone’s sampling limitations in making adjustments for something other than what we actually hear, and what you can do to help mitigate it in ways to produce great-sounding results. We’ll also cover some free and very inexpensive ways to test your room’s behavior so that you can choose how you wish to best address reflections; look at typical problem areas which very small rooms are blighted with; and identify some pitfalls to avoid. We will also consider some of the benefits of controlled-dispersion speakers, and circumstances where you may choose to use diffusion over absorption.
Header image: well, most of our rooms aren’t that small! Courtesy of Pexels.com/Mahdi Bafande.
More from Issue 175
View All Articles in Issue 175
#231 Piano Prodigy Jude Kofie Releases His Debut Album On Octave Records by Frank Doris Jun 01, 2026 #231 Underappreciated Artists, Part Two: City Boy by Rich Isaacs Jun 01, 2026 #231 Music and the Art of Creation: Talking With Saxophonist Rob Scheps by Joe Caplan Jun 01, 2026 #231 How to Play in a Rock Band, 24: Further Adventures at the 2026 Montauk Music Festival by Frank Doris Jun 01, 2026 #231 Courtney Barnett: Creature of Habit by Wayne Robins Jun 01, 2026 #231 Angine de Poitrine: Interstellar Guitar Rock Saviors Headed for Late-Night TV Pop Stardom? by Mark Lepage Jun 01, 2026 #231 My Impressions of AXPONA 2026, Part One by Frank Doris Jun 01, 2026 #231 2026 La Jolla Concours d'Elegance: Another Aesthetic Feast by B. Jan Montana Jun 01, 2026 #231 Country Music Icon Jo Dee Messina’s Bridges: A New Beginning by Ray Chelstowski Jun 01, 2026 #231 The Luxury Dispatch Hosts a Video Podcast With Ken Kessler by Ken Kessler Jun 01, 2026 #231 The Vinyl Beat: Tracking in the Motor City by Rudy Radelic Jun 01, 2026 #231 Lots of Fun With DSP: The Ferrum Audio WANDLA DAC and Its Tube Mode by Frank Doris Jun 01, 2026 #231 From The Audiophile's Guide: Digital Source Components and Streaming Audio by Paul McGowan Jun 01, 2026 #231 Onkyo’s Monster M-510 power amplifier by The Staff at Just Audio Jun 01, 2026 #231 PS Audio in the News by PS Audio Staff Jun 01, 2026 #231 Naming Convention by Peter Xeni Jun 01, 2026 #231 Les Invisibles by Frank Doris Jun 01, 2026 #231 Wildlife Scene by James Schrimpf Jun 01, 2026 #230 Camaraderie by B. Jan Montana May 04, 2026 #230 AXPONA 2026: A Family Gathering by Paul McGowan May 04, 2026 #230 Pianist Ryan Benthall Explores Jazz Realms and Far Beyond With Divine Sky by Frank Doris May 04, 2026 #230 The Vinyl Beat in AXPONA-Land by Rudy Radelic May 04, 2026 #230 Teddy Thompson’s Musical Growth Deepens With Never Be the Same by Ray Chelstowski May 04, 2026 #230 More Fun in the Sun: Florida Audio Expo, Part Two by Frank Doris May 04, 2026 #230 CanJam NYC 2026 Show Report: Heady Sound, Part Two by Frank Doris and Harris Fogel May 04, 2026 #230 Sonic Youth On Murray Street by Wayne Robins May 04, 2026 #230 Graffeo Coffee: A Symphony of Sensory Experience by Joe Caplan May 04, 2026 #230 The Saul Authority: The Story of Hi-Fi Pioneer Saul Marantz by Olivier Meunier-Plante May 04, 2026 #230 How to Play in a Rock Band, 23: Encounters With Famous Musicians, Part Two by Frank Doris May 04, 2026 #230 An Outlier in the Rack: A Vintage BIC Beam Box by The Staff at Just Audio May 04, 2026 #230 PS Audio in the News by PS Audio Staff May 04, 2026 #230 A Cautionary Tale by Rich Isaacs May 04, 2026 #230 Reel-to-Reel Roots, Part 33 (Revised): Ken Kessler Reports On the 2026 (British) AudioJumble by Ken Kessler May 04, 2026 #230 Text Messaging by Frank Doris May 04, 2026 #230 The Audiophile Rat Race by Peter Xeni May 04, 2026 #230 On the Rocks by Rich Isaacs May 04, 2026 #229 The Earliest Stars of Country Music, Part Three by Jeff Weiner Apr 06, 2026 #229 The Healing Power of Music and Sound at the Omega Institute by Joe Caplan Apr 06, 2026 #229 CanJam NYC 2026 Show Report: Heady Sound, Part One by Frank Doris Apr 06, 2026 #229 Florida Audio Expo 2026: Warming Up to High-End Audio, Part One by Frank Doris Apr 06, 2026 #229 Quick Takes: Anne Bisson, Sam Morrison, The Velvet Underground, and the Stooges by Frank Doris Apr 06, 2026 #229 The Vinyl Beat: New Arrivals, and Old Audio Show Demo Scores to Settle by Rudy Radelic Apr 06, 2026 #229 Harvard Gets a High-End Audio Education by Frank Doris Apr 06, 2026 #229 No Country for Old Knees by B. Jan Montana Apr 06, 2026 #229 How To Play in A Rock Band, 22: Encounters With Famous Musicians, Part 1 by Frank Doris Apr 06, 2026 #229 The Soulful Grooves of Guinea-Bissau by Steve Kindig Apr 06, 2026 #229 Four-Hand Piano Performance at Its Finest by Stephan Haberthür Apr 06, 2026
