Issue 193 • Free Online Magazine
Issue 193 Parting Shot
Another Copper Audio Experience: Loudspeakers With Enchantment
Copper-veneered speakers from Copper reader Mike Van Hoe…it’s a natural combination! In Issue 188 we featured Mike’s copper-clad, custom-built loudspeakers. Well, he didn’t stop with one pair. Here’s the second set of speakers, built using Enchantment veneer covering from BasicCopper.com. We’ll let Mike tell the story:
When you build anything you need to think the whole process through and have a plan. Veneering with copper is actually a pretty straightforward process, very similar to wood veneering. There are several tutorials on YouTube.
One of the most enjoyable parts of the veneering process is picking out the veneer! Before you start applying it, make sure your cabinets are grain-filled and sanded as near to perfect as you can get. Imperfections have a way of biting you in the end. Make sure all the crossover and speaker terminal wiring is complete and attached. It should all be screwed or glued in before start. You don’t want to be digging inside your cabinets after you have veneered them.
I built the cabinets from MDF using plans supplied by the Creative Sound Solutions (CSS) website.
I stuff the open driver holes with crumpled up newspaper before I start. I measure the copper sheets, in this case BasicCopper.com’s Enchantment style (see the ariicle's header image above), to be a little wider and longer than the cabinet – at least 1/2-inch or so on each side. You can use scissors, a utility razor, or tin snips to cut the copper. Gentlemen, do not use your wife’s good scissors! That was mistake number one for me.
Apply contact cement on the copper and the cabinet separately, using a roller. Let them dry for a few minutes. Once the contact cement is just dry, line up the veneer and smooth it on, starting from one end, and smooth it on using a scraper with a rounded plastic edge until you get to the other end. You must be very careful and precise when you line up the veneer. It helps when there are two people to do this because once the two surfaces touch each other it is...well…GAME OVER. They are cemented together permanently. Elbow grease and patience is a must.
The wood pieces for the enclosures.
The scraper and roller used to apply the copper veneer.
As you use the scraper to smooth the veneer, you must press down and squeeze out any air bubbles and make sure the copper and cabinet are well-bonded together. Start in the middle and work to the sides. There are lots of instructional videos out there in YouTube land.
For these Enchantment-veneered speakers, I used Creative Sound Solutions (CSS) 2TD-X MTM kit, which includes all the drivers and crossover components needed. I went with the option where all the speaker components were supplied. These were a little tougher to make than when I used BasicCopper.com’s Wildfire veneer and Audio Nirvana drivers from CommonSense Audio. Why? I only veneered two sides on the Wildfire speakers. I veneered three sides of the Enchantment speakers, which was much more difficult. I had to build a jig to keep the veneer away from the cabinet, thinking I could apply the copper by myself. This was mistake number two.
Crossover components from the Creative Sound Solutions kit.
When I had everything prepared I set the veneer on top of the dowels in the jig and started applying the veneer starting in the middle of the top of the cabinet. I told myself not to panic when I realized that this was not something that could be done by myself. I immediately called my neighbor and told him I had an emergency! He ran over and he held up one end of the veneer while I applied it. I removed one dowel at a time and flattened the veneer to the cabinet using my scraper.
I waited a day or so for the contact cement to cure. After that it was just a matter of trimming the edges. Trimming is something that must be practiced before you attempt it, unless one of your buddies owns an HVAC company (like my friend Christopher). Not practicing the technique would have been mistake number three.
Gluing and clamping the cabinet.
The dowels used in the fabrication jig.
After the trimming I used a file to knock down any sharp spots. I then painted (using a roller) several coats of DuraTex (at least five) speaker cabinet coating on the front, back and bottom. The DuraTex covered the edges of the copper, resulting in a nice transition on the edges. I then wrapped the copper part of the speakers with multiple layers of kitchen cellophane (Glad Wrap or similar) Then I soldered and screwed in the drivers.
At some point in the process they start to look like speakers.
They're taking shape...
Wrapping the speakers after veneering.
Then came the most terrifying part: will the speakers even work? Did I wire the crossovers correctly? Did I maintain polarity correctly? Was this going to be mistake number three?
The results were absolutely KILLER! They sounded amazing and also looked pretty cool! I spent dozens of hours building them and they were well worth the result.
After a couple of years, I’ve noticed a that few air bubbles have appeared. Still worth it? Heck yeah!
Almost there...
And all that hard work pays off.
Header image: the Enchantment raw copper veneer sheets from BasicCopper.com.
More from Issue 193
View All Articles in Issue 193
#231 Piano Prodigy Jude Kofie Releases His Debut Album On Octave Records by Frank Doris Jun 01, 2026 #231 Underappreciated Artists, Part Two: City Boy by Rich Isaacs Jun 01, 2026 #231 Music and the Art of Creation: Talking With Saxophonist Rob Scheps by Joe Caplan Jun 01, 2026 #231 How to Play in a Rock Band, 24: Further Adventures at the 2026 Montauk Music Festival by Frank Doris Jun 01, 2026 #231 Courtney Barnett: Creature of Habit by Wayne Robins Jun 01, 2026 #231 Angine de Poitrine: Interstellar Guitar Rock Saviors Headed for Late-Night TV Pop Stardom? by Mark Lepage Jun 01, 2026 #231 My Impressions of AXPONA 2026, Part One by Frank Doris Jun 01, 2026 #231 2026 La Jolla Concours d'Elegance: Another Aesthetic Feast by B. Jan Montana Jun 01, 2026 #231 Country Music Icon Jo Dee Messina’s Bridges: A New Beginning by Ray Chelstowski Jun 01, 2026 #231 The Luxury Dispatch Hosts a Video Podcast With Ken Kessler by Ken Kessler Jun 01, 2026 #231 The Vinyl Beat: Tracking in the Motor City by Rudy Radelic Jun 01, 2026 #231 Lots of Fun With DSP: The Ferrum Audio WANDLA DAC and Its Tube Mode by Frank Doris Jun 01, 2026 #231 From The Audiophile's Guide: Digital Source Components and Streaming Audio by Paul McGowan Jun 01, 2026 #231 Onkyo’s Monster M-510 power amplifier by The Staff at Just Audio Jun 01, 2026 #231 PS Audio in the News by PS Audio Staff Jun 01, 2026 #231 Naming Convention by Peter Xeni Jun 01, 2026 #231 Les Invisibles by Frank Doris Jun 01, 2026 #231 Wildlife Scene by James Schrimpf Jun 01, 2026 #230 Camaraderie by B. Jan Montana May 04, 2026 #230 AXPONA 2026: A Family Gathering by Paul McGowan May 04, 2026 #230 Pianist Ryan Benthall Explores Jazz Realms and Far Beyond With Divine Sky by Frank Doris May 04, 2026 #230 The Vinyl Beat in AXPONA-Land by Rudy Radelic May 04, 2026 #230 Teddy Thompson’s Musical Growth Deepens With Never Be the Same by Ray Chelstowski May 04, 2026 #230 More Fun in the Sun: Florida Audio Expo, Part Two by Frank Doris May 04, 2026 #230 CanJam NYC 2026 Show Report: Heady Sound, Part Two by Frank Doris and Harris Fogel May 04, 2026 #230 Sonic Youth On Murray Street by Wayne Robins May 04, 2026 #230 Graffeo Coffee: A Symphony of Sensory Experience by Joe Caplan May 04, 2026 #230 The Saul Authority: The Story of Hi-Fi Pioneer Saul Marantz by Olivier Meunier-Plante May 04, 2026 #230 How to Play in a Rock Band, 23: Encounters With Famous Musicians, Part Two by Frank Doris May 04, 2026 #230 An Outlier in the Rack: A Vintage BIC Beam Box by The Staff at Just Audio May 04, 2026 #230 PS Audio in the News by PS Audio Staff May 04, 2026 #230 A Cautionary Tale by Rich Isaacs May 04, 2026 #230 Reel-to-Reel Roots, Part 33 (Revised): Ken Kessler Reports On the 2026 (British) AudioJumble by Ken Kessler May 04, 2026 #230 Text Messaging by Frank Doris May 04, 2026 #230 The Audiophile Rat Race by Peter Xeni May 04, 2026 #230 On the Rocks by Rich Isaacs May 04, 2026 #229 The Earliest Stars of Country Music, Part Three by Jeff Weiner Apr 06, 2026 #229 The Healing Power of Music and Sound at the Omega Institute by Joe Caplan Apr 06, 2026 #229 CanJam NYC 2026 Show Report: Heady Sound, Part One by Frank Doris Apr 06, 2026 #229 Florida Audio Expo 2026: Warming Up to High-End Audio, Part One by Frank Doris Apr 06, 2026 #229 Quick Takes: Anne Bisson, Sam Morrison, The Velvet Underground, and the Stooges by Frank Doris Apr 06, 2026 #229 The Vinyl Beat: New Arrivals, and Old Audio Show Demo Scores to Settle by Rudy Radelic Apr 06, 2026 #229 Harvard Gets a High-End Audio Education by Frank Doris Apr 06, 2026 #229 No Country for Old Knees by B. Jan Montana Apr 06, 2026 #229 How To Play in A Rock Band, 22: Encounters With Famous Musicians, Part 1 by Frank Doris Apr 06, 2026 #229 The Soulful Grooves of Guinea-Bissau by Steve Kindig Apr 06, 2026 #229 Four-Hand Piano Performance at Its Finest by Stephan Haberthür Apr 06, 2026
Almost there...
