Issue 39 • Free Online Magazine
Issue 39 VINTAGE WHINE
Nostalgia Ain’t What It Used to Be
I’ve previously mentioned audio icon Henry Kloss’ time at AR (Vintage Whine, way back in Copper #5). The time will come for me to do a comprehensive review of Kloss’ post-AR serial enterprises, KLH, Advent, Kloss Video, Cambridge SoundWorks, and Tivoli—but this is not that piece. Right now, I’d like to focus on Kloss’ genius at packaging audio gear to fit almost any environment—and how the present vinyl revival is inspiring a new generation to take a crack at packaging phonographs as Kloss once did. The problem is—they’re doing a terrible job of it.
Kloss often used cutting-edge technology in his products, being an early adopter of transistor amplifiers, Dolby B, chrome dioxide cassettes, and three-gun projection TV, but such innovations were rarely showy or done with much fanfare (the exception being the large KLH 9 electrostats). They were simply done to provide better sound in well-packaged, reasonably-priced products.
For decades, almost every American home had a small countertop radio in the kitchen. Such radios were generally AM only, and often possessed dubious sound quality. Kloss’ first “hi-fi for all seasons” product was the KLH Model Eight  (always spelled out as “Eight”, for some reason),  a compact tube-type FM-only radio/amp with a separate speaker of matching size, made from 1960-65. Barely a hand-span in width, the Eight was notable for its fine sound quality; its clean styling still influences product design, and many Eights are still in use today. The Eight showed that there was a market for good-sounding products that could be used almost anywhere—and Kloss later returned to that market again and again, with Cambridge SoundWorks and Tivoli.
As important as the Eight was, the products I’d like to focus upon today are the KLH Models 11,15, 20, and 20 Plus. These products encompassed two classes of audio products upon which many budding audiophiles cut their teeth, and with which many regular folks found musical enjoyment: compact systems and portable systems. The 11—apparently numerals were okay—was a cleverly packaged portable system in a suitcase, literally. The rather cheesy Garrard record changer and electronics comprised the bottom half of the suitcase, the top being a clip-on lid for travel. The separate small speakers clipped on opposite ends of the buttoned-up turntable, forming a faux-leather suitcase such as Samsonite used to make.
The 11 was notable for several reasons: its compact size and fully-enclosed design were possible because its electronics were all-transistor, supposedly one of the first units to be all solid state.Note that while the speakers can pack in with the turntable, they are separate—allowing proper enclosure design and avoiding the acoustic feedback that would likely result from having all in a common enclosure (a lesson today’s hipster designs seem to have missed).
More ambitious than portable systems were compact systems. Most—like the KLH Models 15 and 20—had turntable and electronics in one enclosure, with two separate speakers . Some inexpensive units seemed to teeter between the portable and compact classifications, with the turntable and one speaker in a common enclosure, with the second speaker clipping onto the front for transport. Not so good.
Both portables and compacts were popular with college students for obvious reasons. Compacts had a little more domestic sensibility, with wood-veneered cabinets. The KLH 15 was still phono-only; the 20 was more ambitious, and featured a vernier-tuning FM tuner in addition to the turntable, along with bigger/better speakers. It’s important to note that these were not cheap systems: the 11’s $200 price tag in 1965 equals over $1500 today, and the 20’s $400 price is over $3000 in 2017 bucks.
The 20 Plus (seen atop the page) was the 20 decked out in mid-century modern glory: the phono/amp unit received a wooden flip-top lid and all three pieces mounted on spun-aluminum pedestals, creating a  not-quite-console.
So: why am I dwelling upon products that most of us would sniffily regard as lo-fi, or mid-fi at best? Because they were well-designed, functional, solidly-built products that gave pleasure to an entire generation. Kloss had a singular genius for maximizing the performance of everything he touched, and even his least-expensive products were good-sounding, competently designed and easy to use. They were not built (or priced) to be throw-aways; the sheer number of old Models Eight and 20 still in use is impressive.
Contrast the 11, 15, and 20 with almost any product from Johnny-come-lately turntable builders inspired by nostalgia and the LP revival. Look at, say, Crosley. Whether you choose the cheesy faux-retro models or the just plain cheesy plasticky models, these are reportedly dangerous record-chewers. The company introduced a few higher-priced turntables that are fairly credible, built by ProJect. But if you wanted a ProJect-built table, would you want it with the Crosley name attached?
Crowdfunding sites often feature badly-designed audio products—yes, there are some good crowdfunded products, I’ve worked with a number of them. But in general, turntables offered for crowdfunding seem ill-conceived, ill-designed, and unlikely to ever reach production.Remember the Floating Record on Kickstarter? It raised over $1.5M with an uphill-working tonearm. There have been vertical turntables in the past, but they all seemed a little more aware of the laws of physics. How about the Atmo Sfera platterless table? Over 60,000 Euro raised.
Remember that little VW bus that would run around your record and play it—supposedly? Well, the present generation seems unaware: a modern take on it raised over $350,000 on Kickstarter. A more suave but no less ridiculous cousin, the Love turntable, raised over $860,000 on Kickstarter. And there are plenty of all-in-one units out there that have turntable and speakers in the same enclosure, like this thing. I can’t imagine all the issues that would have.
It’s a little ironic that these clunky devices were all prompted by the nostalgia over records. All they do is make me nostalgic for well-designed, solidly-built, no-BS audio products.
Is that whirring sound Henry Kloss spinning in his grave?
More from Issue 39
View All Articles in Issue 39
#230 Camaraderie by B. Jan Montana May 04, 2026 #230 AXPONA 2026: A Family Gathering by Paul McGowan May 04, 2026 #230 Pianist Ryan Benthall Explores Jazz Realms and Far Beyond With Divine Sky by Frank Doris May 04, 2026 #230 The Vinyl Beat in AXPONA-Land by Rudy Radelic May 04, 2026 #230 Teddy Thompson’s Musical Growth Deepens With Never Be the Same by Ray Chesltowski May 04, 2026 #230 More Fun in the Sun: Florida Audio Expo, Part Two by Frank Doris May 04, 2026 #230 CanJam NYC 2026 Show Report: Heady Sound, Part Two by Frank Doris and Harris Fogel May 04, 2026 #230 Sonic Youth On Murray Street by Wayne Robins May 04, 2026 #230 Graffeo Coffee: A Symphony of Sensory Experience by Joe Caplan May 04, 2026 #230 The Saul Authority: The Story of Hi-Fi Pioneer Saul Marantz by Olivier Meunier-Plante May 04, 2026 #230 How to Play in a Rock Band, 23: Encounters With Famous Musicians, Part Two by Frank Doris May 04, 2026 #230 An Outlier in the Rack: A Vintage BIC Beam Box by The Staff at Just Audio May 04, 2026 #230 PS Audio in the News by PS Audio Staff May 04, 2026 #230 A Cautionary Tale by Rich Isaacs May 04, 2026 #230 Reel-to-Reel Roots, Part 33 (Revised): Ken Kessler Reports On the 2026 (British) AudioJumble by Ken Kessler May 04, 2026 #230 Text Messaging by Frank Doris May 04, 2026 #230 The Audiophile Rat Race by Peter Xeni May 04, 2026 #230 On the Rocks by Rich Isaacs May 04, 2026 #229 The Earliest Stars of Country Music, Part Three by Jeff Weiner Apr 06, 2026 #229 The Healing Power of Music and Sound at the Omega Institute by Joe Caplan Apr 06, 2026 #229 CanJam NYC 2026 Show Report: Heady Sound, Part One by Frank Doris Apr 06, 2026 #229 Florida Audio Expo 2026: Warming Up to High-End Audio, Part One by Frank Doris Apr 06, 2026 #229 Quick Takes: Anne Bisson, Sam Morrison, The Velvet Underground, and the Stooges by Frank Doris Apr 06, 2026 #229 The Vinyl Beat: New Arrivals, and Old Audio Show Demo Scores to Settle by Rudy Radelic Apr 06, 2026 #229 Harvard Gets a High-End Audio Education by Frank Doris Apr 06, 2026 #229 No Country for Old Knees by B. Jan Montana Apr 06, 2026 #229 How To Play in A Rock Band, 22: Encounters With Famous Musicians, Part 1 by Frank Doris Apr 06, 2026 #229 The Soulful Grooves of Guinea-Bissau by Steve Kindig Apr 06, 2026 #229 Four-Hand Piano Performance at Its Finest by Stephan Haberthür Apr 06, 2026 #229 The People Who Make Audio Happen: Supreme Acoustics Systems’ Las Vegas Grand Opening by Harris Fogel Apr 06, 2026 #229 Blue Öyster Cult: Tyranny and Expectations by Wayne Robins Apr 06, 2026 #229 Guitarist Rick Vito’s Cinematic New Album, Slidemaster by Ray Chelstowski Apr 06, 2026 #229 Measurements and Observational Listening by Paul McGowan Apr 06, 2026 #229 PS Audio in the News by PS Audio Staff Apr 06, 2026 #229 Back to My Reel-to-Reel Roots, Part 28: The Cassette Strikes Back by Ken Kessler Apr 06, 2026 #229 Are You Receiving Me? by Frank Doris Apr 06, 2026 #229 Hospitality by Peter Xeni Apr 06, 2026 #229 Cantina Gateway by James Schrimpf Apr 06, 2026 #228 Serita’s Black Rose Duo Shakes Your Soul With a Blend of Funk, Rock, Blues and a Whole Lot More by Frank Doris Mar 02, 2026 #228 Vinyl, A Love Story by Wayne Robins Mar 02, 2026 #228 Thrill Seeker by B. Jan Montana Mar 02, 2026 #228 The Vinyl Beat: Donald Byrd, Bill Evans, Wes Montgomery, Eddie Palmieri and Frank Sinatra by Rudy Radelic Mar 02, 2026 #228 Listening to Prestige: The History of a Vitally Important Jazz Record Label by Frank Doris Mar 02, 2026 #228 How to Play in a Rock Band, 21: Touring With James Lee Stanley by Frank Doris Mar 02, 2026 #228 The NAMM 2026 Show: The Music Industry’s Premier Event by John Volanski Mar 02, 2026 #228 The Earliest Stars of Country Music, Part Two by Jeff Weiner Mar 02, 2026 #228 From The Audiophile's Guide: A Brief History of Stereophonic Sound by Paul McGowan Mar 02, 2026
