Stellar M1200 Mono Amplifier |
| Unit Weight | 27 lbs [12.2 kg] (each) |
| Unit Dimensions | 17”W x 3.75”H x 12”D (13"D w/connectors) 17”W x 7.5”H x 12”D (Stacked) |
| Shipping Weight | 29 lbs [13.15 kg] (each) |
| Shipping Dimensions | 22”W x 8”H x 17”D (each) |
| Color Options | Black Silver |
| Vacuum tube type | 12AU7 |
| Voltage Options (Factory set only) |
Japan 100V North America 120V Europe/Asia/Australia/New Zealand 230V |
| Mains Power Inputs | IEC C14 |
| Idle Power Consumption | 27W |
| Power Factor | >0.9 @ rated power 4Ω |
| Accessories Included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS 1363) (230V version) |
| Audio Inputs | RCA (Unbalanced) XLR (Balanced) |
| Speaker Outputs | Copper base nickel plated binding posts (2 pair) |
| DC Trigger Input | 3.5mm 5-15VDC |
| Warranty | 3 years parts and labor |
Signal |
| Gain | 30.5dB +/-0.5dB |
| Sensitivity for rated output power | 2.08V |
| Signal to Noise | 1kHz@1200 Watts > 112dB |
| Input impedance | Unbalanced 50KΩ Balanced 100KΩ |
| Output Impedance | 50Hz, 2.8VRMS <0.007Ω |
| Damping factor | 50Hz. 2.8VRMS 8Ω >1100 4Ω >550 |
| Frequency Response | 2.8VRMS into 4Ω 10Hz – 20KHz +/- 0.5dB 10Hz – 45KHz +0.1/-3.0dB |
THD & IM |
| 1KHz, 1W/4Ω | < 0.005% |
| 10-20KHz, 1W/4Ω | < 0.01% |
| 1KHz, 150W/4Ω | < 0.02% |
Output Power |
120vac mains, 1kHz, 1% THD |
| 8Ω | 600W minimum |
| 4Ω | 1200W minimum |
| 2Ω | Stable for musical transients |
M1200 Amplifier - Factory Certified
Note:
Design
Applications
Overview
The Vacuum Tube Input
Output Stage
Features
15 key featuresMONO POWER AMPLIFIER PAIR
ZERO-LOSS TUBE INPUT STAGE
POWERFUL MOSFET OUTPUT STAGE
RCA SINGLE ENDED INPUT
XLR "TRUE" BALANCED INPUT
600 WATTS PER CHANNEL 8Ω
1200 WATTS RMS INTO 4Ω
2Ω STABLE
ICE EDGE TECHNOLOGY
DAMPING FACTOR > 1100
FRONT PANEL STANDBY BUTTON
VERY LITTLE HEAT PRODUCTION
DUAL, SOLID, COPPER PLATED OUTPUT POSTS
27 LBS. EACH
INPUT 12v TRIGGER
Reviews
0 reviewsNo reviews yet for this product.
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
