Issue 74 • Free Online Magazine
Issue 74 IN MY ROOM
5400 Hours of Fun, Part 3
[We previously featured Ken Fritz’s amazing speaker and listening room project in Copper #72 and #73. We’ll wrap up now with some of the details. I hope you’ll find this inspirational— although I doubt if many will read this and think, “yeah, I could do that”. I certainly couldn’t!–-Ed.]
I might add that all the pine painted trim in the room was run in my shop using #1 molding pine. I own a 1 inch diameter spindle shaper and a myriad of profile knives, which made it possible and easy to produce all the pine trim throughout the room. Being able to run all my moldings, it was easy to fabricate trim that was outside the standard shapes when I so desired.
All the white oak raised panels, chair rail moldings and associated oak accoutrements were produced from the wood that I harvested 20 years earlier from this property. The two 30 inch diameter white oak trees had grown too close to the footings and foundations of both the house and the shop; I trimmed the two trees into a pole and had a crane service tie them off at the top. I then cut 12 ft.  sections at the bottom of the trees and continued to have them lowered to the ground as I cut successive 12 foot logs. I then rented a portable saw mill and my wife and I logged all the lumber. We then stickered and covered it on our property and let it all air dry for about 8 years. After that, we then took it to out manufacturing plant in Petersburg ,Virginia, where we stickered and stacked  it on top of our pallet racks for another 8 or so years. After that time the lumber was down to 7% moisture content, and we proceeded to make all the oak raised panels, chair rails and other pieces for the room.
Sue and I feel it’s unique to have made all the white oak pieces from two trees on the property.
In order to have some sort of protective grilles on the speakers, we used .080 inch diameter EPDM rubber strings stretched in front of the drivers, through the top and bottom looms. This material was used by Krell in their Modulare loudspeaker systems.  Before I thought to ask Dan D’Agostino if he would allow me to use his material, I was planning on just using double knit material I bought from Jim Thiel.
The effect of the rubber strings was magnificent. Before I embarked on doing this and having ALL the top and bottom looms machined for the three front and four surround towers I tried an experiment. I fabricated a 2 ft. wide by 3 ft high loom and after stretching the rubber strings I asked my wife to stand next to a speaker and move it in and out of the soundfield. I needed to make sure that this type of grill wouldn’t impede or change the character the emanating sound. I could hear no difference so I proceeded to have all the looms for all the speakers machined and powder coated black.
A top view of the Krell amplifiers I chose to drive the three front channels and subs.
A shot of the looms for the seven loudspeakers ready for powder coating.
Another shot of the looms for the seven loudspeakers ready for powder coating.
This shot was taken after all of the looms were strung and installed in the top and bottom of the speakers. You will note that, at that point, the room was not fully completed.
Stretching the looms in place on the speakers.
This image shows the tedious work of stretching the .080” EPDM rubber strings.
Another shot to show the tedious work of stretching the .080” EPDM rubber strings.
A rear view of one of the towers with a Krell FPB 600 in place.
In the image below, we are painting the yellow Kevlar cones black to eliminate the bullseye effect when looking at the speakers. When I ordered all the 72 mid-bass drivers from Scan Speak, I never thought about how it would be looking at 72 bullseyes. The cones were also available with a black coating which I should’ve ordered. When I spoke with an engineer at Scan Speak and asked him if I could purchase the black doping material, he suggested I just blacken them with a magic marker instead. Besides being easier, it didn’t increase the mass of the cones, as would’ve been the case with the black mastic. In reality, the cone excursions of the drivers are almost nothing, so increased mass would’ve made little difference as the cones only operate from 60 to 200HZ.
A surround tower next to a front speaker, for a size reference. Note the eight 15-inch Krell sub drivers in the background and the yet empty bass absorber cavity, one in each front room corner.
A view of the interconnection of the mid and tweeter drivers. Note the top tweeter driver facing to the rear, wired out of phase, for a dipole arrangement.
A view of one of the surround towers, which were built in mirror image pairs,. This is looking at the cast polymer battle and drivers through the stretched grill created by the EPDM strings.
Rubber strings cut to size waiting to be strung.
An image of the front of one of the three front speakers prior to installation of the rubber grills.
A view of the drivers behind the stretched rubber grills.
Stretching and installing the grills.
A view of the left front channel, with the Krell subs behind, and bass trap in the left corner of the room.
More from Issue 74
View All Articles in Issue 74
#226 JJ Murphy’s Sleep Paralysis is a Genre-Bending Musical Journey Through Jazz, Fusion and More by Frank Doris Jan 05, 2026 #226 Stewardship by Consent by B. Jan Montana Jan 05, 2026 #226 Food, Music, and Sensory Experience: An Interview With Professor Jonathan Zearfoss of the Culinary Institute of America by Joe Caplan Jan 05, 2026 #226 Studio Confidential: A Who’s Who of Recording Engineers Tell Their Stories by Frank Doris Jan 05, 2026 #226 Pilot Radio is Reborn, 50 Years Later: Talking With CEO Barak Epstein by Frank Doris Jan 05, 2026 #226 The Vinyl Beat Goes Down to Tijuana (By Way of Los Angeles), Part One by Rudy Radelic Jan 05, 2026 #226 Capital Audiofest 2025: Must-See Stereo, Part Two by Frank Doris Jan 05, 2026 #226 My Morning Jacket’s Carl Broemel and Tyler Ramsey Collaborate on Their Acoustic Guitar Album, Celestun by Ray Chelstowski Jan 05, 2026 #226 The People Who Make Audio Happen: CanJam SoCal 2025, Part Two by Harris Fogel Jan 05, 2026 #226 How to Play in a Rock Band, 19: Touring Can Make You Crazy, Part One by Frank Doris Jan 05, 2026 #226 Linda Ronstadt Goes Bigger by Wayne Robins Jan 05, 2026 #226 From The Audiophile’s Guide: Active Room Correction and Digital Signal Processing by Paul McGowan Jan 05, 2026 #226 PS Audio in the News by Frank Doris Jan 05, 2026 #226 Back to My Reel-to-Reel Roots, Part 25: Half-Full, Not Empty by Ken Kessler Jan 05, 2026 #226 Happy New Year! by Frank Doris Jan 05, 2026 #226 Turn It Down! by Peter Xeni Jan 05, 2026 #226 Ghost Riders by James Schrimpf Jan 05, 2026 #226 A Factory Tour of Audio Manufacturer German Physiks by Markus "Marsu" Manthey Jan 04, 2026 #225 Capital Audiofest 2025: Must-See Stereo, Part One by Frank Doris Dec 01, 2025 #225 Otis Taylor and the Electrics Delivers a Powerful Set of Hypnotic Modern Blues by Frank Doris Dec 01, 2025 #225 A Christmas Miracle by B. Jan Montana Dec 01, 2025 #225 T.H.E. Show New York 2025, Part Two: Plenty to See, Hear, and Enjoy by Frank Doris Dec 01, 2025 #225 Underappreciated Artists, Part One: Martin Briley by Rich Isaacs Dec 01, 2025 #225 Rock and Roll is Here to Stay by Wayne Robins Dec 01, 2025 #225 A Lifetime of Holiday Record (and CD) Listening by Rudy Radelic Dec 01, 2025 #225 Little Feat: Not Saying Goodbye, Not Yet by Ray Chelstowski Dec 01, 2025 #225 How to Play in a Rock Band, Part 18: Dealing With Burnout by Frank Doris Dec 01, 2025 #225 The People Who Make Audio Happen: CanJam SoCal 2025 by Harris Fogel Dec 01, 2025 #225 Chicago’s Sonic Sanctuaries: Four Hi‑Fi Listening Bars Channeling the Jazz‑Kissa Spirit by Olivier Meunier-Plante Dec 01, 2025 #225 From The Audiophile’s Guide: Controlling Bass Frequencies Through Membrane Absorbers (and How to Build Your Own) by Paul McGowan Dec 01, 2025 #225 Your Editor’s Tips for Attending Audio Shows by Frank Doris Dec 01, 2025 #225 PS Audio in the News by Frank Doris Dec 01, 2025 #225 Back to My Reel-to-Reel Roots, Part 24 by Ken Kessler Dec 01, 2025 #225 Holiday Music by Frank Doris Dec 01, 2025 #225 Puppy Prognostication by Peter Xeni Dec 01, 2025 #225 How to Post Comments on Copper by Frank Doris Dec 01, 2025 #225 Living Color by Rudy Radelic Dec 01, 2025 #224 T.H.E. Show New York 2025, Part One: A New Beginning by Frank Doris Nov 03, 2025 #224 Fool’s Leap of Faith is the Extraordinary Octave Records Debut from Singer/Songwriter Tyler Burba and Visit by Frank Doris Nov 03, 2025 #224 The Beatles’ “Aeolian Cadences.” What? by Wayne Robins Nov 03, 2025 #224 Persona Non Grata by B. Jan Montana Nov 03, 2025 #224 Talking With Recording Engineer Barry Diament of Soundkeeper Recordings, Part Two by Frank Doris Nov 03, 2025 #224 B Sides, B Movies, and Beware of Zombies by Rudy Radelic Nov 03, 2025 #224 The Burn-In Chronicles: 1,000 Hours to Sonic Salvation by Olivier Meunier-Plante Nov 03, 2025 #224 A Conversation With Mat Weisfeld of VPI Industries by Joe Caplan Nov 03, 2025 #224 Blues-Rocker Kenny Wayne Shepherd Celebrates 30 Years of Ledbetter Heights by Ray Chelstowski Nov 03, 2025 #224 Playing in a Rock Band, 17: When Good Gigs Go Bad, Part Two by Frank Doris Nov 03, 2025
