| Color Options | Pearl White, Sable Black |
| Enclosure Type | Two piece – Sealed upper cabinet mid-tweeter module, Passive radiator lower cabinet (4 10” side-firing passive radiators) |
| High Frequency Transducer | 2 x 2.5” planar magnetic with Teonex diaphragm |
| Mid Frequency Transducer | 10” planar magnetic with Teonex diaphragm |
| Low Frequency Transducer | 4 x 8” woofers, cast frame, aluminum cone, 12lb advanced magnet structure |
| Crossover Frequency | 400 Hz, 2500 Hz – LR4 |
| Sensitivity (2.83V @ 1M) | 88 dB |
| Nominal Impedance | 4 ohm (3.6 ohm minimum impedance) |
| Recommended Amplifier Power | 100-600W |
| Frequency Response | 23Hz-20kHz (-6dB) half space, 20 Hz (-6dB) in-room |
| Dimensions (HxWxD) | 60.5” x 16” x 25.75” with base (10” width not including base) |
| Net Weight | 230 lbs (104.5 kg) |
Aspen FR30 Loudspeaker
Save up to 40% on Aspen Loudspeakers. Click "Trade-up" below to see the new price.
Design
Application
Overview
The Drivers
The Enclosure
Features
16 key featuresFULL RANGE 3-WAY SYSTEM
88 dB SENSITIVITY
TWO 2.5" PLANAR RIBBON TWEETERS
10" PLANAR RIBBON MIDRANGE
FOUR 8" LOW DISTORTION HIGH EXCURSION WOOFERS
FOUR 10" LOW DISTORTION HIGH EXCURSION BASS RADIATORS
REAR TWEETER LEVEL CONTROL
BAFFLE STEP ADJUSTMENT FOR BEST SPEAKER PLACEMENT
FLAT IMPEDANCE CURVE FOR EASY AMPLIFIER LOAD
SMOOTH AND FULL OFF AXIS RESPONSE
IN-ROOM BASS RESPONSE TO 20hz @ -6db
TWO PIECE CABINET FOR EASY SETUP
ADJUSTABLE FEET
EASY TO POSITION FOR BEST PERFORMANCE
HEAVY INTERNAL BRACING FOR LOW CABINET VIBRATION
CUSTOM FILM CAPACITORS & PREMIUM AIR-CORE INDUCTORS
Reviews
reviews
I tend to be a bit hypercritical in evaluating anything I consider for purchase. The FR30, did more than live up to my hopes, however, and one way to sum up is to state that I'm buying my review pair as another set of reference speakers. The FR30 is truly outstanding, highly recommended, and well worth the set-up effort necessary to make it perform at its best!
Read full review →
I consistently heard super-powerful bass, a really rich and robust midrange, smooth highs, and the kind of effortlessness and scale that you get from big speakers with large and/or lots of drivers....I heard no disparity between what the woofers and planar-magnetic drivers were playing......anyone looking for a pair of speakers that are this large and styled in such an unusual way should explore them. I could tell that there was at least the potential that amazing sound could emerge from them
Read full review →
The Aspens projected an electrically charged soundfield that was big and dimensional, with notes that were bold and fully formed, supple and dynamic. Even the quieter moments seemed to emit an energetic presence, a kind of radiant musical assertiveness. The speakers sounded well balanced across the frequency range. They also balanced power and agility, machismo and finesse, soaring highs and low-end heft
Read full review →
Even if we didn't get to try them in our usual conditions, our visit clearly showed: the PS Audio Aspen FR30 are impressive in practically every aspect. With their elegant design, they have what it takes to conquer a prominent place in the living room, despite their size. Their incredibly natural, dynamic sound then seems to flow effortlessly from the gigantic floor-standing loudspeakers. The nimble magentostats combine their advantages excellently with the powerfully gripping bass section
Read full review →
Having read about the development of these speakers literally for years, in various online postings, I was both keen to hear them and also filled with a little trepidation that they'd not live up to expectation. I needn't have worried: it only took a few tracks to realise that the Aspen FR30 is every bit a sensational design and - to cut to the chase - nothing short of one of the high-end bargains of the moment, making some much pricier speakers seem just a little bit silly
Read full review →
PS Audio lays out a stage that is both wide and deep, filled with vibrant life, and even extends upward beyond the height of the speakers. The resolution on offer seems very fine across the entire frequency range
Read full review →I am hearing something close to wheat i heard in the concert hall. Turning up the volume and with really good recordings the sound is so very much like my memories of what I heard at Lincoln Center.The new equipment ups the ability of the system to a new level. And the PSAudio Aspen speakers, 30s in one system and 20s in the other are so good that they can easily display the improved signal coming from the new equipment.
Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
