| Color Options | Satin White, Satin Black |
| Enclosure Type | Sealed Box |
| Maximum Output | 113 dB @ 2m ground plane |
| Input Impedance | 50kΩ (RCA), 100kΩ (XLR) |
| Power Requirements | 120/230 VAC, 50/60 Hz (auto-sensing) |
| Idle Consumption | 40W |
| Driver Excursion | 60mm Xmax p-p / 80mm Xmech p-p |
| Amplifier Power | 1000W continuous (1800W power supply) |
| Frequency Response | -6 dB @ 20 Hz anechoic (ground plane), flat to below 20 Hz in-room with room gain; ±0.5 dB to 500 Hz |
| Dimensions (HxWxD) |
14.75"W × 16.75"H × 17.5"D (18.125" with grille)
| Net Weight |
77 lbs (35 kg) |
| Shipped Dimensions (HxWxD) |
17"W x 20"H x 22"D |
| Shipped Weight |
83 lbs (37.7 kg) |
Foundry F12 Subwoofer
Optional Add-ons
Design
Application
Overview
The Driver
The Room
Power and Control
State of the Art
Extraordinary Performance
Chris Brunhaver on subwoofers
Features
12 key featuresMUSIC-FIRST, REFERENCE-GRADE BASS
CUSTOM 12-INCH ULTRA-LONG-THROW DRIVER
SEALED ENCLOSURE FOR FAST, ACCURATE TRANSIENTS
1000-WATT HIGH-CURRENT AMPLIFICATION
EXTREME LINEAR EXCURSION FOR LOW DISTORTION
FLAT IN-ROOM RESPONSE BELOW 20 HZ
ADVANCED DSP WITH ROOM EQ AND DELAY CONTROL
MULTIPLE INPUT OPTIONS FOR ANY SYSTEM
WIRED OR WIRELESS INTEGRATION VIA WISA
COMPACT FOOTPRINT FOR ACOUSTICALLY CORRECT PLACEMENT
DESIGNED FOR MULTI-SUB CONFIGURATIONS
STACKABLE FOR INCREASED OUTPUT AND HEADROOM
Reviews
3 reviews
I'm very happy the Foundry F12. This is the first subwoofer that I owned that is truly musical. The quality of the unit is top notch. It added so much depth to my music. A definite compliment to my tower speakers.
“Adding two Foundry F12 subwoofers transformed my system. Properly placed and dialed in, they’re a seamless extension of my main speakers — never drawing attention to themselves, only speaking when asked. The last octave may not hold a lot of notes, but it carries enormous weight and emotion— tighter midbass, clearer placement of instruments, and a more immersive soundstage. The F12s don’t just add bass; they complete the system.”
The thing that surprised is how the subs affect the highs and mids in a very positive way. Soundstage is massive, wall to wall. And imaging is more precise. This is a significant improvement for me. Thanks Chris for great SW.
Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
