Issue 14 • Free Online Magazine
Issue 14 FEATURED
Subwoofery: Trick or Treat?
Part 2 – “Fast” bass? Really??? …
… Just when I think some errant audiophile terminology is finally extinct, it rears its ugly head again.  I am still amazed when audio reviewers describe subwoofer bass as fast or slow.
First, let me get the most insulting statement out of the way: If a subwoofer could be described as very fast, it would be a tweeter!
When a subwoofer is described as slow, it’s nearly always poor integration with the main speaker.  Poor integration can range from wrong location (this is much more than simply finding where to put it) to wrong crossover implementation to wrong levels and more.  These factors can be just a bit off and still affect the sound – and they are inter-related.
If a sub can be described as fast, that’s also a problem.  You shouldn’t be aware of it – in much the same way that you never think about how fast or slow it is when listening to live music.
A relatively straightforward goal can be best described as never feeling the need to readjust the sub with different recordings or types of music.  When you get that aspect working you are done, or at least well on the way.
We will explore these topics and techniques later in this series.
However, there are some other pesky performance issues with some subs that can also contribute to the illusion of fast or slow bass:
(1)  The main issue about speed that I encounter isn’t how fast the woofer starts – but how quickly does it stop?  This issue can definitely contribute to the slow bass illusion.  It’s one reason why speaker manufacturers are continually looking for more rigid, but lower mass drivers.  Not for speed, but for control.
(2)  Cabinet resonances can also contribute to the slow illusion.  Although the sub may only be working up to 35 Hz, if its enclosure has a sympathetic (…what a weird adjective!…) resonance at 140 Hz, it can often be described by some as being slow.
(3)  An out-of-band subwoofer anomaly (fortunately this is rare) can also add to the illusion.  If it is flat to your 40 Hz crossover point, but it has a peak at 80, then here comes the illusion again (though it depends somewhat on the slope of the crossover).
To close out this section, let’s agree that we want the sub to disappear as an obvious source of the sound.  If you are aware of it, especially as to its speed, you probably have some work to do.  It’s not rocket science (sorry, couldn’t think of a better descriptor), and the rewards for your effort will pay musical dividends for years to come.
Part 3 – Finding the anchor point for the best Dynamics, Presence & Tone
This has to be my pet peeve when evaluating audio installations.  It is so very important – but rarely mentioned – and sadly, it is done even less.
First, a description of the issue:
Dynamics are essential in order to have the music “pluck your heartstrings”.  That’s why the current overuse of compression (of dynamics) in recordings is so damaging – but hey, that’s another topic…
Here, we are discussing the effects of bass peaks and dips in your playback system.  The peaks destroy dynamic range as they were never intended to be there.  They mask musical dynamic subtleties in the recording that are meant by the musician to be heard, but you can’t fully experience them, as they are overshadowed by the excess bass sounds.
The same lack of dynamics is true (but for a different reason) whenever there are dips in the bass frequency response.  These dips detract from the music’s intended impact and definitely diminish its intended dynamics, and sadly, sometimes in a major fashion.
I have heard too many systems that – depending on the frequency – were almost missing some bass notes, while other notes were booming away. Both bass anomalies detract from the music’s dynamic contrasts, with a potentially far greater effect than those that may occur elsewhere in the midrange and treble.
Please understand that we are not considering uneven speaker response.  We are concentrating on the room resonances that all rooms have, based on the room’s dimensions.  Peaks in bass frequency response are additive resonances and dips are subtractive.  Even though we are talking about subwoofers, we are still intensely concerned with all bass anomalies, in the boundary dependent region from 25-250 Hz.
Since all rooms suffer from these issues, how can we overcome them?  While some may wish to immediately employ electronic EQ and Room Correction (another upcoming topic in this series), I have found that it’s always best to first smooth out the bass response in an organic fashion (meaning working with the room rather than against it), rather than immediately resorting to using electronic EQ and/or Room Correction.
And since I’m up against my word limit, we’ll explore how to successfully accomplish our goal in the next issue.  Hint – it’s probably not what you’ve heard.  🙂
Still to come:
More on – Finding the anchor point for the best Dynamics, Presence & Tone
Part 4 – Why a RTA (Real Time Analyzer) is useful, even if you are not technical – and how to get a good one nearly free
Part 5 – Sub set-up info you probably haven’t seen (but you should)
Part 6 – X-over freq. vs. level; location, location, location
Part 7 – The role of EQ and Room Correction when working with subs
Part 8 – A true story about the musical impact of bass – with a good outcome and lots of documentation
More from Issue 14
View All Articles in Issue 14
#225 Capital Audiofest 2025: Must-See Stereo, Part One by Frank Doris Dec 01, 2025 #225 Otis Taylor and the Electrics Delivers a Powerful Set of Hypnotic Modern Blues by Frank Doris Dec 01, 2025 #225 A Christmas Miracle by B. Jan Montana Dec 01, 2025 #225 T.H.E. Show New York 2025, Part Two: Plenty to See, Hear, and Enjoy by Frank Doris Dec 01, 2025 #225 Underappreciated Artists, Part One: Martin Briley by Rich Isaacs Dec 01, 2025 #225 Rock and Roll is Here to Stay by Wayne Robins Dec 01, 2025 #225 A Lifetime of Holiday Record (and CD) Listening by Rudy Radelic Dec 01, 2025 #225 Little Feat: Not Saying Goodbye, Not Yet by Ray Chelstowski Dec 01, 2025 #225 How to Play in a Rock Band, Part 18: Dealing With Burnout by Frank Doris Dec 01, 2025 #225 The People Who Make Audio Happen: CanJam SoCal 2025 by Harris Fogel Dec 01, 2025 #225 Chicago’s Sonic Sanctuaries: Four Hi‑Fi Listening Bars Channeling the Jazz‑Kissa Spirit by Olivier Meunier-Plante Dec 01, 2025 #225 From The Audiophile’s Guide: Controlling Bass Frequencies Through Membrane Absorbers (and How to Build Your Own) by Paul McGowan Dec 01, 2025 #225 Your Editor’s Tips for Attending Audio Shows by Frank Doris Dec 01, 2025 #225 PS Audio in the News by Frank Doris Dec 01, 2025 #225 Back to My Reel-to-Reel Roots, Part 24 by Ken Kessler Dec 01, 2025 #225 Holiday Music by Frank Doris Dec 01, 2025 #225 Puppy Prognostication by Peter Xeni Dec 01, 2025 #225 How to Post Comments on Copper by Frank Doris Dec 01, 2025 #225 Living Color by Rudy Radelic Dec 01, 2025 #224 T.H.E. Show New York 2025, Part One: A New Beginning by Frank Doris Nov 03, 2025 #224 Fool’s Leap of Faith is the Extraordinary Octave Records Debut from Singer/Songwriter Tyler Burba and Visit by Frank Doris Nov 03, 2025 #224 The Beatles’ “Aeolian Cadences.” What? by Wayne Robins Nov 03, 2025 #224 Persona Non Grata by B. Jan Montana Nov 03, 2025 #224 Talking With Recording Engineer Barry Diament of Soundkeeper Recordings, Part Two by Frank Doris Nov 03, 2025 #224 B Sides, B Movies, and Beware of Zombies by Rudy Radelic Nov 03, 2025 #224 The Burn-In Chronicles: 1,000 Hours to Sonic Salvation by Olivier Meunier-Plante Nov 03, 2025 #224 A Conversation With Mat Weisfeld of VPI Industries by Joe Caplan Nov 03, 2025 #224 Blues-Rocker Kenny Wayne Shepherd Celebrates 30 Years of Ledbetter Heights by Ray Chelstowski Nov 03, 2025 #224 Playing in a Rock Band, 17: When Good Gigs Go Bad, Part Two by Frank Doris Nov 03, 2025 #224 From The Audiophile’s Guide: Dealing with Odd-Shaped Rooms by Paul McGowan Nov 03, 2025 #224 TEAC’s TN-3B-SE Turntable Plays Bob Dylan by Howard Kneller Nov 03, 2025 #224 PS Audio in the News by Frank Doris Nov 03, 2025 #224 Lost in Translation by Peter Xeni Nov 03, 2025 #224 Reel-to-Reel Roots, Part 23: Better Than Rice Krispies by Ken Kessler Nov 03, 2025 #224 I Bring Joy! by Frank Doris Nov 03, 2025 #224 Screen Test by Rich Isaacs Nov 03, 2025 #224 How to Post Comments on Copper by Frank Doris Nov 03, 2025 #132 Dr. Patrick Gleeson: The Interview, Part Two by Rich Isaacs Oct 07, 2025 #223 World Fusion Meets Flamenco in Gratitude from Steve Mullins and Rim of the Well by Frank Doris Oct 06, 2025 #223 Judging Albums by Their Covers by Rich Isaacs Oct 06, 2025 #223 Recent Arrivals and 12-inch Royalty by Rudy Radelic Oct 06, 2025 #223 Summer of Creem, Part Two by Wayne Robins Oct 06, 2025 #223 Recording Engineer Barry Diament of Soundkeeper Recordings: Striving for Natural Sound by Frank Doris Oct 06, 2025 #223 Tea on the Terrace by B. Jan Montana Oct 06, 2025 #223 How Good Can Car Audio Get? by Joe Caplan Oct 06, 2025 #223 The Advantages of a Dedicated Listening Room by Paul McGowan Oct 06, 2025 #223 1! 2! 3! 4! Surrounded by the Ramones in Dolby Atmos! by Frank Doris Oct 06, 2025
Still to come:
