Copper Magazine · Issue 224 · A free PS Audio publication
Issue 224 Paul's Place
From The Audiophile’s Guide: Dealing with Odd-Shaped Rooms
The perfect listening room might be rectangular in the textbooks, but real life rarely gives us textbook situations. Many of us face challenging spaces: L-shaped rooms, rooms with alcoves, sloped ceilings, or odd angles. While these irregular shapes can seem like obstacles, they sometimes offer unexpected advantages for sound reproduction.
Let’s start with a common challenge – the L-shaped room. These spaces often result from open floor plans where living and dining areas merge. The main challenge here is that sound waves don’t know where to bounce. In a rectangular room, sound reflections are predictable; they bounce back and forth between parallel walls. But in an L- shaped space, some sound energy disappears around the corner while other waves create complex patterns where the two sections meet.
This isn’t always bad. That corner section can actually help break up standing waves, those pesky bass resonances that plague perfectly rectangular rooms. Think of it like throwing a rock in a square pool versus one with an irregular shape. In the square pool, waves bounce back and forth in a regular pattern. In the irregular pool, the waves scatter more randomly, which can actually help reduce problematic resonances.
Sloped ceilings present another common challenge (or benefit). Whether it’s an attic conversion or modern architecture, these angled surfaces change how sound reflects in the room. The good news is that sloped ceilings tend to direct first reflections away from the listening position, which can actually improve clarity. The challenge comes from the changing room volume – the ceiling height difference between the front and back of the room can create uneven bass response.
Rooms with alcoves or bump-outs (like bay windows or fireplace enclosures) create their own special problems. These spaces can act like Helmholtz resonators; think of blowing across the top of an empty bottle. Each alcove can resonate at specific frequencies, creating boomy spots in the bass response. But here’s the silver lining – we can use these spaces strategically. A deep alcove behind the listening position, for instance, can be turned into an effective bass trap with proper treatment.
The key to handling irregular rooms is to work with their quirks rather than against them. For example, if you have an L-shaped room, consider placing the listening position in the main section, using the secondary space as a natural diffusion area. With sloped ceilings, try positioning the speakers so the ceiling angles help direct first reflections away from the listening position.
Modern homes often feature open floor plans that flow into kitchen or dining areas. These spaces can be particularly tricky because sound energy essentially leaks into these adjacent areas. The solution often lies in creating acoustic zones within the larger space. This doesn’t mean building walls; strategic furniture placement and area rugs can help defne the listening area without closing off the room.
One of the most challenging scenarios is the asymmetrical room, where one side differs from the other. Maybe there’s a large window on one wall and a solid wall on the other, or perhaps a door on one side creates an opening. These differences affect how sound reflects on each side of the room, potentially skewing the stereo image. The solution often involves using different acoustic treatments on each wall to balance the reflections, creating a symmetrical acoustic space within an asymmetrical physical space.
One of the most powerful tools in dealing with irregular rooms is speaker placement. Unlike rectangular rooms where the traditional “Golden Ratio” rules apply, irregular spaces require a more experimental approach. The good news is that these spaces often have sweet spots that work even better than traditional rooms – we just have to find them.
Take that challenging L-shaped room we discussed earlier. While conventional wisdom suggests keeping speakers away from corners, the shorter leg of an L can sometimes create an ideal bass loading situation. I’ve found that placing a speaker near where the L’s segments meet can actually help control bass response, using the corner to naturally augment low frequencies without creating the boomy effect we typically associate with corner placement.
Some of the finest listening rooms I’ve experienced had anything but conventional flat ceilings. Two stand out in my memory as perfect examples of how “imperfect” ceiling designs can create magical acoustic spaces. The first was at Infinity Systems’ founder Arnie Nudell’s home in Colorado. Arnie, one of the pioneers of high-end audio, had a listening room with dramatic cathedral ceilings. The pitched angles created an expansive soundstage that seemed to extend forever. What made this room special wasn’t just its size; it was how the angled ceiling surfaces prevented the formation of strong standing waves that typically plague rooms with parallel surfaces. The music seemed to float in space, unbound by the room’s physical boundaries.
Another remarkable space was the original Stereophile listening room in Santa Fe, New Mexico. Built in traditional Santa Fe style, it featured exposed vigas – those beautiful round ceiling beams typical of Southwest architecture. What might appear as acoustic complications actually served as nearly perfect natural diffusors. The rough-hewn beams broke up sound reflections in ways that even expensive commercial diffusors struggle to achieve. The result was a room that managed to be both live and controlled, maintaining the energy of the music while preventing any harsh reflections.
These experiences taught me something crucial about ceiling design: what might seem like acoustic challenges often turn out to be blessings in disguise. Those exposed beams that contractors want to cover up? They’re natural diffusors that break up standing waves and create a more natural sound field. The irregular surfaces of a cathedral ceiling? They prevent the parallel-surface reflections that can make music sound artificial and constrained.
When working with high or irregular ceilings, the key is to position your listening area to take advantage of these features. In rooms with cathedral ceilings, for instance, the varying height creates different reflection patterns across the room. By experimenting with speaker and listening position placement, you can often find spots where the ceiling’s geometry naturally creates an immersive soundstage.
I’ve found that rooms with high, irregular ceilings often solve one of the most common problems in home audio: that cramped, boxy sound that makes you feel like you’re listening to music in a small box. The extra height and irregular surfaces help recreate the natural sense of space you experience in a concert hall, where sound doesn’t just come at you from the front but seems to envelope you naturally from all directions.
The lesson here is clear: don’t assume that architectural features that deviate from the “perfect rectangular box” are problems to be solved. Often, they’re opportunities to create something special. Those ceiling beams, whether they’re rough-hewn vigas or modern exposed trusses, can create the kind of natural diffusion that audio engineers spend thousands trying to recreate with artificial devices.
Windows are often seen as acoustic weak points, but they don’t have to be. Yes, they reflect high frequencies and let in outside noise, but they can also prevent the room from becoming too dead. The trick is balance. If you have a large window on one wall, don’t automatically cover it with heavy drapes. Instead, consider matching its reflective properties on the opposite wall with a strategically placed piece of art glass or a framed print under glass.
A carefully-constructed listening room with a balance of different surfaces. Courtesy of Pixabay.com/minhloi.
Bookshelves are one of the most powerful and overlooked tools in room acoustics. They’re not just furniture; they’re highly effective acoustic devices hiding in plain sight. What makes them so special is their natural ability to break up sound waves in ways that expensive acoustic treatments try to replicate. When setting up my own listening room back in the late 1990s, I invaded the local Goodwill and Salvation Army stores on the hunt for books. For less than the cost of a single commercial diffusor panel, I filled my car with hundreds of hardcover books of different sizes. The key wasn’t their content –it was their varying dimensions.
Think about what a wall of books really is: it’s essentially a randomized diffusor array. Each book creates a different depth, each spine a different surface, each size a different reflection point. When you arrange books of varying sizes – some thin paperbacks, some thick encyclopedias, some tall art books, some small novels –you’re creating exactly the kind of irregular surface that acoustic engineers try to achieve with expensive diffusor panels.
The beauty of using books for acoustic treatment lies in their dual purpose. Unlike dedicated acoustic panels that scream “recording studio,” bookshelves make a room feel like a home. They add character, warmth, and intellectual appeal while secretly working as sophisticated acoustic devices. Your guests see a beautiful library; your ears enjoy professional-grade acoustic treatment.
The magic of bookshelves as acoustic treatment really shines in irregular rooms. When you’re dealing with challenging spaces, traditional acoustic treatments often struggle to address complex reflection patterns. But bookshelves can be configured to work with almost any room geometry. You can angle them, wrap them around corners, or use them to create acoustic zones within larger spaces.
Bookshelves make excellent sound diffusers. Courtesy of Pexels.com/Element5 Digital.
Making Asymmetry Work
When we talk about asymmetrical rooms in audio, we’re describing spaces where the left and right sides of the listening environment aren’t mirror images of each other. This is far more common than you might think. Asymmetry shows up in many forms: a window on one wall with a solid wall opposite, a fireplace on one side and an open doorway on the other, built-in cabinets that only exist on one wall, or even different wall materials from one side to the other.
These asymmetries create unique acoustic challenges because sound waves behave differently when bouncing off different surfaces. A hard, flat wall reflects sound waves like a mirror reflects light – predictably and with most of the energy intact. A window, on the other hand, lets some sound pass through while reflecting the rest. An irregular stone surface scatters sound in multiple directions. When these different surfaces appear on opposite walls, they create uneven sound refection patterns that can distort the stereo image and change the tonal balance of your system.
Think of it like throwing two different balls against two different walls. A smooth wall returns the ball predictably, while a rough wall causes it to bounce in random directions. Sound waves behave similarly, and when your left and right walls treat sound differently, it affects what you hear at the listening position.
Let’s say you have a room with large windows on one side and a solid wall on the other. Instead of completely covering the windows to match the solid wall (which would create a dead, lifeless space), you can use adjustable window treatments to tune the reflectivity. Blinds or drapes that can be partially opened or closed give you control over how much sound is reflected or absorbed. By carefully adjusting these treatments, you can balance the room’s acoustic properties without trying to make both walls identical.
In situations with dramatically different surfaces – like a stone fireplace wall opposite a standard drywall surface – the goal is to create complementary acoustic environments. The stone surface naturally diffuses sound, breaking up reflections into smaller, scattered waves. Rather than trying to recreate this effect on the opposite wall (which would be nearly impossible), you can use a combination of diffusive and absorptive treatments to achieve a balanced sound field.
When we stop thinking about making walls match and start thinking about making their acoustic effects complement each other, we improve our chances for success. Sometimes this means using different treatments on different walls. You might need more absorption on a hard, reflective wall and more diffusion on a naturally absorbent one. The goal is to create a balanced acoustic space at the listening position, not identical acoustic properties on each wall.
This approach often leads to some counterintuitive solutions. For example, in a room with a large opening on one side (like an archway into another room), you might actually want more reflective surfaces on the opposite wall to compensate for the energy lost through the opening. Or in a room with built-in cabinets on one side, you might arrange your books and decorative objects to create diffusion patterns that complement, rather than match, the opposite wall.
Finally, don’t underestimate the acoustic impact of furniture. A well-placed sofa or cabinet can act as an effective bass trap. Tall bookshelves can create beneficial diffusion. Even the orientation of chairs can affect how sound moves through a space. The key is thinking of furniture as acoustic elements, not just functional pieces.
The Television Dilemma
One of the most common challenges in modern listening rooms isn’t acoustic treatment or room dimensions; it’s the big black rectangle hanging between your speakers. The television has become a central fixture in most living rooms, and for the sake of marital harmony and practical living arrangements, it often winds up exactly where we don’t want it: on the front wall between our carefully positioned speakers.
This creates several problems for sound reproduction. A conventional TV mounted on a bracket typically protrudes 4 to 6 inches from the wall, creating an irregular reflecting surface right in the critical area between your speakers. Sound waves bouncing off this protruding surface can create early reflections that blur imaging and affect the coherency of the soundstage. Think of it like placing a small wall at an odd angle between your speakers, because that’s essentially what a protruding television does. The problem becomes even more complex when you consider that a TV’s surface is usually highly reflective. Unlike the absorptive or diffusive surfaces we typically want in a listening room, a television screen acts almost like a mirror for sound waves. This can create focused reflections that affect the clarity and precision of your stereo image.
But there’s good news. Television manufacturers have started recognizing that their products need to integrate better with living spaces. Samsung’s The Frame TV, for instance, represents a significant step forward for audio enthusiasts who must compromise with a television in their listening room. The Frame mounts completely flush with the wall, virtually eliminating the problematic protruding surface that traditional TV mounts create. When not in use, it displays artwork, helping it blend visually with your room’s aesthetics.
If a new television isn’t in the budget, there are other solutions to minimize its acoustic impact. One approach is to create a slight recess in the wall where the TV mounts, allowing it to sit flush with the wall surface. While this requires some construction work, it can dramatically improve the acoustic properties of your front wall.
Another solution I’ve seen work well is to treat the areas immediately surrounding the television. By adding thin absorption or diffusion panels around the TV, you can help control the reflections from its surface without creating an aesthetic nightmare. These panels can be designed to complement your room’s decor while providing valuable acoustic benefits.
Some audiophiles have found success with motorized TV mounts that allow the television to be moved out of the way during serious listening sessions. While this might seem extreme, it can be an elegant solution that maintains domestic harmony while allowing for optimal sound reproduction when needed. If you’re designing a new listening room from scratch, consider positioning the television on a side wall, away from the primary speaker array. This arrangement requires more careful planning for furniture placement but can result in better sound without compromising video viewing angles.
One often-overlooked solution is to mount the television slightly higher than usual, above the primary reflection points between your speakers. While this isn’t ideal for video viewing, it can be a workable compromise in rooms where the listening position is fairly distant from the front wall. The key is to ensure the TV doesn’t create reflections that interfere with the critical midrange and high frequencies at ear level.
More from Issue 224
View All Articles in Issue 224
#236 Magic Boy: The Jimi Hendrix Experience, Live and Rediscovered by Frank Doris Nov 02, 2026 #236 The Great Rhythmic Divide: Composer David Chesky Asks, Why Doesn't the Symphony Orchestra Groove? by David Chesky Nov 02, 2026 #236 More Record Reviews: Roni Eytan’s Microtonal Harmonica, Jane Ira Bloom, and a Frank Zappa Freak Out by Frank Doris Nov 02, 2026 #236 An Album of Inviting Beauty: Goodnight Moon from Acoustic Eidolon, And an Interview With the Artists Who Created it by Frank Doris Nov 02, 2026 #236 Never Ignore Your Inner Voice by B. Jan Montana Nov 02, 2026 #236 Composer Joseph Bertolozzi Uses Bridges, Structures and the World as Musical Instruments, Part One by Joe Caplan Nov 02, 2026 #236 Transmission: A Powerful Horn-Loaded Album from the Huntertones by Ray Chelstowski Nov 02, 2026 #236 Les Quatre Saisons du Québec: a New “Four Seasons” on Tour and on ATMA Classique by Robert Schryer Nov 02, 2026 #236 From The Audiophile's Guide: A Glossary of Terms for Today's Audio Systems, A – M by Paul McGowan Nov 02, 2026 #236 From The Listening Chair: An Introduction to Audiophile Tweaks by Howard Kneller Nov 02, 2026 #236 The Vinyl Beat Grew Two Inches Since October! by Rudy Radelic Nov 02, 2026 #236 How to Play in a Rock Band, Part 29: Figuring Out How to Play the Songs by Frank Doris Nov 02, 2026 #236 The Return of the Residents: Eskimo is On the Road by Wayne Robins Nov 02, 2026 #236 PS Audio in the News by PS Audio Staff Nov 02, 2026 #236 The People Who Make Audio Happen – Fun In Las Vegas at…CES 2026? by Harris Fogel Nov 02, 2026 #236 The Forms of Things Unknown by Frank Doris Nov 02, 2026 #236 Prophetic by Peter Xeni Nov 02, 2026 #236 Here's Looking at You, Kid by Rich Isaacs Nov 02, 2026 Favorites From T.H.E. Show SoCal 2026 by Cam Martin Oct 05, 2026 #235 Singer/Songwriter John David Schrader: On the Need to Create, Part Two by Joe Caplan Oct 05, 2026 #235 A Life in High-End Audio: The Roy Hall Interview, Part Two by Frank Doris Oct 05, 2026 #235 Grammy-Winning Producer, Songwriter, and Guitarist John Leventhal Goes Instrumental With National Drift by Ray Chelstowski Oct 05, 2026 #235 From Swimming Pool to New Listening Room—to Founding an Accidental Audio Company by Gilles Laferrière Oct 05, 2026 #235 The Vinyl Beat’s Size Matters Edition by Rudy Radelic Oct 05, 2026 #235 The Sublime Complexities of Nature by B. Jan Montana Oct 05, 2026 #235 How to Play In a Rock Band, 28: Growing Older and Dealing With It by Frank Doris Oct 05, 2026 #235 Young Rascals: From Bar Band to Stardom by Wayne Robins Oct 05, 2026 #235 Duncan Sheik: In Memoriam by Ray Chelstowski Oct 05, 2026 #235 From The Listening Chair: The Meze Audio 105 Silva Headphones by Howard Kneller Oct 05, 2026 #235 Checking Out Some NOLA Loudspeakers – and Some Thoughts About Audio Writing by Frank Doris Oct 05, 2026 #235 The Kanazawa Phonograph Museum: Music from a Time Capsule by Sebastian Polcyn Oct 05, 2026 #235 PS Audio in the News by PS Audio Staff Oct 05, 2026 #235 From The Audiophile’s Guide: Making the Most Critical Choice by Paul McGowan Oct 05, 2026 #235 Evolutionary Growth by Frank Doris Oct 05, 2026 #235 Speed Racer by Peter Xeni Oct 05, 2026 #235 Happy Halloween! by James Schrimpf Oct 05, 2026 #234 A Life in High-End Audio: The Roy Hall Interview, Part One by Frank Doris Sep 07, 2026 #234 Jason Greenlaw Offers His Personal Perspective on Jazz Guitar in Vantage Point by Frank Doris Sep 07, 2026 #234 Transcendent Phoenix: Lucina Yue Brings the Ancient Konghou Into Modern Times by Frank Doris Sep 07, 2026 #234 We Must All Follow Our Bliss by B. Jan Montana Sep 07, 2026 #234 How to Play in a Rock Band, 27: Leveling Up by Frank Doris Sep 07, 2026 #234 Ross Valory: Traveling Into New Musical Territory With All of the Above by Ray Chelstowski Sep 07, 2026 #234 Singer/Songwriter John David Schrader: On the Need to Create by Joe Caplan Sep 07, 2026 #234 The People Who Make Audio Happen: More From T.H.E. Show SoCal 2026 by Harris Fogel Sep 07, 2026 #234 The Vinyl Beat Digs Into the Gadget Box by Rudy Radelic Sep 07, 2026 #234 The Rolling Stones: Foreign Tongues Spoken Loud by Wayne Robins Sep 07, 2026 #234 Musical Moments by Rich Isaacs Sep 07, 2026
From <em>The Audiophile’s Guide:</em> Dealing with Odd-Shaped Rooms
