| Color Options | Pearl White, Sable Black |
| Enclosure Type | Passive radiator (two, 10” side-firing passive radiators) |
| High Frequency Transducer | 2.5” planar magnetic with Teonex diaphragm |
| Mid Frequency Transducer | 10” planar magnetic with Teonex diaphragm |
| Low Frequency Transducer | 2 x 8” woofers, cast frame, carbon fiber Rohacell sandwich cone, 12lb advanced magnet structure |
| Crossover Frequency | 400 Hz, 2500 Hz – Linkwitz-Riley 4th order acoustic |
| Sensitivity (2.83V @ 1M) | 87 dB |
| Nominal Impedance | 4 ohm (3.5 ohm minimum impedance) |
| Recommended Amplifier Power | 50-300W |
| Frequency Response | 23Hz-20kHz (-6dB) half space, 20 Hz (-6dB) in-room |
| Dimensions (HxWxD) | 50.5” x 16” x 18.75″ |
| Net Weight | 133 lbs (60.3 kg) |
Aspen FR20 Loudspeaker
Free threshold freight shipping.
Save up to 40% with your trade-in. Click "Trade Up and Save" below!
Design
Application
Reference performance for any room
Overview
The Drivers
The Enclosure
Features
16 key featuresFULL RANGE 3-WAY SYSTEM
87 dB SENSITIVITY
ONE 2.5" PLANAR RIBBON TWEETER
10" PLANAR RIBBON MIDRANGE
TWO 8" LOW DISTORTION HIGH EXCURSION WOOFERS
TWO 10" LOW DISTORTION HIGH EXCURSION BASS RADIATORS
ADVANCED CARBON FIBER PMI FOAM COMPOSITE WOOFER CONES
THERMOSET FIBERGLASS RESIN FRONT BAFFLES
FLAT IMPEDANCE CURVE FOR EASY AMPLIFIER LOAD
SMOOTH AND FULL OFF AXIS RESPONSE
IN-ROOM BASS RESPONSE TO 20hz @ -6db
ONE PIECE CABINET FOR EASY SETUP
ADJUSTABLE MILLED BRASS FEET
EASY TO POSITION FOR BEST PERFORMANCE
HEAVY INTERNAL BRACING FOR LOW CABINET VIBRATION
CUSTOM FILM CAPACITORS & PREMIUM AIR-CORE INDUCTORS
Reviews
6 reviewsI am hearing something close to wheat i heard in the concert hall. Turning up the volume and with really good recordings the sound is so very much like my memories of what I heard at Lincoln Center.The new equipment ups the ability of the system to a new level. And the PSAudio Aspen speakers, 30s in one system and 20s in the other are so good that they can easily display the improved signal coming from the new equipment.
PS Audio didn’t just dip their toes into loudspeaker design; they aimed for the stars and achieved something remarkable.
Read full review →
these mighty, musical and marvelous speakers set a new benchmark in their sector and, arguably, fix the standard even more ambitious designs now have to beat
Read full review →
A little more reduced, a little less massive, but at least as high a level – that is the definition of successful down-sizing. Or simply the description of the PS Audio Aspen FR20
Read full review →
The PS Audio Aspen FR20 is for the music lover who has done their homework, knows what they need, and doesn't follow the pack
Read full review →
The Aspen FR20 are simply excellent speakers that impress in every respect. High-quality, elegantly designed and easy to set up, they are suitable for listening rooms and living rooms alike. Despite their size, they do not require enormous power, they pack an energetic punch even with smaller amplifiers and always appear controlled. Ultimately, however, it is clearly their sound that makes them completely convincing. This level of precision, depth of detail, dynamics and simultaneous long-term
Read full review →Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
