| Color Options | Satin White, Satin Black |
| Enclosure Type | Passive radiator (three 6x9” oval rear-firing) |
| High Frequency Transducer | 2.5” planar magnetic with Teonex diaphragm |
| Mid Frequency Transducer | 8” planar magnetic with Teonex diaphragm |
| Low Frequency Transducer | 2 x 6.5” woofers, cast frame, non-woven carbon fiber PMI foam sandwich cone, advanced magnet structure |
| Crossover Frequency | 550 Hz, 1750 Hz - Linkwitz-Riley 4th order acoustic |
| Sensitivity (2.83V @ 1M) | 86.5 dB |
| Nominal Impedance | 4 ohm (3.3 ohm minimum impedance) |
| Recommended Amplifier Power | 50-200W |
| Frequency Response | 32 Hz-20 kHz (-6dB) half space, 25 Hz (-6 dB) in-room |
| Dimensions (HxWxD) |
41.5” x 11.75” x 16.25” with base (8” width not including base) |
| Net Weight | 75 lbs (34.1 kg) |
Aspen · Floorstanding loudspeaker
Aspen® FR10
Full, room-filling sound, and easy to place in any room.
$9,999 / pair
Save up to $2,499 with a trade-in.
Options
Buy or audition near you
All dealers30-day in-home trial
The PS Audio Home Experience
Try it risk-free for 30 days in your own system. Love it or return it.
- Outside the US? Find your local dealer
Designed for typical living rooms
- Size (H × W × D) 41.5" × 11.75" × 16.25"
- Weight 75 lb each
- Deep bass Down to 25 Hz in-room
- Drivers Ribbon tweeter, 8" ribbon midrange, two 6.5" woofers
What reviewers say
…a big-hearted, ebullient and hugely enjoyable performance across the board.
Extremely low & tight bass. Well-blended, smooth & silky treble
A stupendous spatial impression is given right from the start.
Why choose it
Full sound, easy to place
A ribbon tweeter and 8-inch ribbon midrange, with two 6.5-inch woofers and three passive radiators taking the bass to 25 Hz in-room. Compact enough for a typical living room.
Where it fits
Loudspeakers are part of the family. With their presence, they grace our homes and living areas by bringing the joy of music into our lives. Unlike the electronics that drive them, to perform their best most loudspeakers depend on proper placement and optimized room parameters.
Read more
Loudspeakers are part of the family. With their presence, they grace our homes and living areas by bringing the joy of music into our lives. Unlike the electronics that drive them, to perform their best most loudspeakers depend on proper placement and optimized room parameters. The Aspen FR10, however, is designed to more easily fit into any living environment and perform at their best with a minimum of setup hassles and a maximum of options. While the FR10, like all high-performance speakers, appreciates some breathing room between them and the front wall, placement in the room for best performance is a snap. Using the included step-by-step guide and CD, setup, from unboxing to playing music, happens easily in a few short hours.
Design
How it's built
The FR10 joins the ranks of a rare handful of true full-range speakers that can honestly cover the frequency range of 30Hz to beyond 20kHz with grace, dynamics, slam, and low distortion—and work in any small to medium-sized room. Within moments of installing your new Aspen FR10 loudspeakers, you'll instantly be transported to a new level of musical ecstacy.
Read the full design story
The FR10 joins the ranks of a rare handful of true full-range speakers that can honestly cover the frequency range of 30Hz to beyond 20kHz with grace, dynamics, slam, and low distortion—and work in any small to medium-sized room. Within moments of installing your new Aspen FR10 loudspeakers, you'll instantly be transported to a new level of musical ecstacy. What's captured on the disc is exactly what you'll hear with a greater resolution than most have ever experienced. Grace, beauty, PRaT, power, and a musicality that is rare amongst 6 figure offerings from other manufacturers await owners of the Aspen FR10. That this speaker is financially within reach of many makes it a miracle.
- 86.5 dB
- sensitivity
- 8-inch
- planar ribbon midrange
- 3-way
- full range
01
Overview
By far the most important piece in the HiFi chain is the loudspeaker. If the speaker cannot reproduce what it is fed from the electronic chain, the missing musical information is forever lost.
Read more
By far the most important piece in the HiFi chain is the loudspeaker. If the speaker cannot reproduce what it is fed from the electronic chain, the missing musical information is forever lost. To achieve all that music demands, over the years, loudspeaker designers have tried to leverage every trick in the book: electrostats for details, conventional drivers for dynamics, planars for transparency, ribbons, domes, horns, open baffles, bipoles, dipoles. The list is endless and the choices and their inevitable sonic compromises daunting. With close to 50 years under our collective belts, we at PS Audio determined to design the perfect loudspeaker for every application, room size, and budgets. In the Aspen series we start with the FR30, then move to the FR20 and then the FR10. Each is a full range state-of-the-art loudspeaker that covers the range of possibilities from small to large rooms and to meet every budget need. The FR10 will fit into every small to medium sized room and provide room-shaking bass down to 30Hz. For the upper end, the FR10 employs the same Aspen planar tweeter as found in both the FR20 and FR30. For our legendary open midrange, the FR10 relies upon the same planar technology as found in its bigger counterparts. Without question, the Aspen FR10 is the perfect loudspeaker for any room and budget.
02
The Drivers
The heart and soul of any loudspeaker are its drivers, the transducers that in response to the amplifier's demands pressurize the air and generate the music. Each driver must be optimized for the task at hand.
Read more
The heart and soul of any loudspeaker are its drivers, the transducers that in response to the amplifier's demands pressurize the air and generate the music. Each driver must be optimized for the task at hand. In the FR10, it quickly became apparent we could not source from even the most advanced driver manufacturers in the world the ultra-low-distortion high-dynamic output drivers we would need to build the FR10. We started with our tweeter and midrange for here are the two most difficult drivers to perfect. Moving air at high frequencies without colorations or distortion is a daunting task. On the FR10 we chose to go with a technology that has the speed of an electrostat with the dynamics of a cone. Planar Magnetics. These ultra-low distortion drivers are equally driven with front and rear magnetic structures that offer inherent linearity through symmetrical “push-pull” neodymium motor structures and directly driven ultra-low mass diaphragms with none of the cone or dome breakup, inductance modulation, or hysteresis distortion that plagues traditional drivers. For the low end, we crafted long-throw high-excursion 6.5" woofers that match the effortlessness and transparency of the planar magnetic drivers. To lower distortion, we employed a unique split magnetic gap and a double Faraday ring for low, linear inductance and wide bandwidth, coupled with a single progressive Nomex spider with stitched-in lead wires. The woofer cones are a low-mass Rohacell foam core. Lastly, to achieve maximum linearity and extended deep bass extension without the compression and distortion of ports, we implemented 3 rear-mounted high-compliance passive radiators. Together, these elements create a stunning presentation of music in your home.
03
The Enclosure
Loudspeakers have an honored place in our homes. They often are the focal point of our living rooms and, in that capacity, must proudly make a statement of fitting elegance.
Read more
Loudspeakers have an honored place in our homes. They often are the focal point of our living rooms and, in that capacity, must proudly make a statement of fitting elegance. The Aspen FR10 enclosure design starts with the internal structure necessary for great sound and then lovingly sculpted into a work of art befitting our homes. With industrial design by famed Studio 63, the FR10's elegant look and smaller form factor complements every decor. Internally, the FR10 is an extensively braced enclosure designed to minimize external vibrations that have the potential of coloring the sound. Externally, the enclosures are lovingly finished with 20 coats of hand-rubbed high-grade lacquer. While the main body and baffling structure are built with MDF, the sculpted front baffle is formed from a dense, rigid and well-damped high-tech thermoset fiberglass resin composite material with integrated high-frequency acoustic waveguides. The speakers look to be almost floating as its curved bottom rests upon its sturdy aluminum base featuring large milled brass spikes with removable tips and integrated plastic feet for hard surfaces (and to aid in speaker placement). A masterpiece of design and love, crafted by those of us that care deeply about music and its reproduction in the home.
Features
At a glance
- Full-range 3-way system
- 86.5 dB sensitivity
- One 2.5" planar ribbon tweeter
- 8" planar ribbon midrange
- Two 6.5" low distortion high excursion woofers
- Three 6x9” high excursion passive radiators
- Non-woven carbon fiber skin on roacell foam core woofer cones
- Thermoset fiberglass resin front baffles
- Smooth and full off axis response
- One piece cabinet for easy setup
- Soft rubber feet with removable stainless steel spikes and milled aluminum top cap nut
- Easy to position for best performance
- Heavy internal bracing for low cabinet vibration
- Custom film capacitors & premium air-core inductors
Compare
How it compares
| FR30 | FR20 | FR10This one | FR5 | F12 | |
| Price | $34,999 / pair | $22,999 / pair | $9,999 / pair | From $3,499 / pair | From $2,749 / each |
| Size (H × W × D) | 60.5" × 16" × 25.75" | 50.5" × 16" × 18.75" | 41.5" × 11.75" × 16.25" | 14.5" × 8" × 13" (stand 28.25" tall) | 16.75" × 14.75" × 17.5" |
| Weight | 230 lb each | 133 lb each | 75 lb each | 26.6 lb each | 77 lb each |
| Room | Large rooms | Medium to large rooms | Typical living rooms | Small to medium rooms | Any room. Stackable |
| Deep bass | Down to 20 Hz in-room | Down to 20 Hz in-room | Down to 25 Hz in-room | Down to 30 Hz in-room | Flat to below 20 Hz in-room |
| Drivers | Two ribbon tweeters, 10" ribbon midrange, four 8" woofers | Ribbon tweeter, 10" ribbon midrange, two 8" woofers | Ribbon tweeter, 8" ribbon midrange, two 6.5" woofers | Ribbon tweeter, 6.5" woofer | Sealed 12" driver |
| Amp power | 100–600 W | 50–300 W | 50–200 W | 50–150 W | Built in: 1,000 W |
Build your system
What it pairs with
Amplifiers in its power range (50–200 W)
PMG Signature S400 Stereo$9,999Floorstanders, typical roomsView detailsAmplifiers in its power range (50–200 W)
PMG Signature S200 Stereo$7,999Bookshelf or efficient speakers, smaller roomsView detailsAmplifiers in its power range (50–200 W)
Stellar S300 Stereo$1,999Bookshelf speakers, smaller roomsView detailsTrade Up and Save
Save up to $2,499 on your Aspen FR10
Your old gear is worth more than you think. PS Audio credits the full original retail value of what you trade, up to the limit, straight off your new purchase.
- Tell us what you have. Press Start your trade-in and list your gear. Nearly any working hi-fi component counts, from any brand.
- Pay the adjusted price. At checkout you are charged only the price after your credit. Our sales team reviews every trade within 48 hours.
- Send yours back. We email a return label number. You have 30 days to ship your trade.
The fine print
What we accept. Nearly any hi-fi make and model at component level: a preamplifier, power amplifier, DAC, phono stage, loudspeaker pair, turntable, headphones or CD transport. It must work and be in respectable cosmetic condition.
What we don't. Broken or non-working products, and most accessories, phono cartridges, power cables and interconnects. Exceptions can be made based on value.
Several items? Yes. Trade as many as you like, up to the credit cap. Use "Add another" on the Trade Up form.
Not sure it qualifies? Call 800-PSAUDIO (800-772-8346) or email sales@psaudio.com, and a real person will answer.
Reviews
More reviews
The PS Audio Aspen FR10 hits a sweet spot in its segment.
It’s compact enough to integrate easily into a family room, living room, or dedicated listening space, yet plays well above its physical size...Combine that with the planar magnetic tweeter and midrange and a perfectly-sized bass array, and the FR10 is a true all-around performer –...
Even the dispersion behavior is fantastic, and the ease of reproduction reminds one of pure planar speakers.
The scope, imagination, broad gesture – isn’t this the idea of American sound? Here it becomes real.
The speakers are extraordinary, and I can’t wait for the monitor
Two things I noticed about this speaker, consistently, …is the mid-base and lower mid-range transition area … there’s a lot of strong upper mid-base punch that I really appreciated.
… The other thing I liked…is the sound stage width …there’s a good wide sound stage but the instruments and the layering and the precision of objects within the sound stage are very well defined
The FR 10s have a charming openness and spatiality.” They generate “an impressive feeling of scale and authority from a soundstage that’s typically ‘grand’.” In the summary verdict section of the review, the FR 10s are described as providing “a big-hearted, ebullient and hugely enjoyable performance across the board.” With careful setup, they offer “a scale and level of authority that belies their compact dimensions.
The PS Audio Aspen FR10 loudspeaker is a great-looking and serious audiophile speaker, capable of delivering wonderfully immersive aural experiences.
Whether you're into vinyl, streaming, digital file playback, or enjoying an HD show or movie over your Hifi system, the FR10s render it wondrously.
Read all 7 reviews
Full specifications
| Dimensions (HxWxD) | 41.5” x 11.75” x 16.25” with base (8” width not including base) |
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialistOutside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Find your local dealerHear it in your own room
Aspen FR10
$9,999 / pair
- 30-day in-home trialThe PS Audio Home Experience. Love it or return it.
- Save up to $2,499 with a trade-inCredit comes off the price at checkout.
Aspen FR10 Loudspeaker
Free UPS Ground shipping, free trade-in shipping, and free returns (continental US only)
Save up to $2,499 with your trade-in. Click "Trade Up and Save" below!
Aspen loudspeakers
Floorstanding scale without taking over the room.
Closer looks
Overview
The Drivers
The Enclosure
A no compromise affordable loudspeaker
What owners and reviewers say
The PS Audio Aspen FR10 hits a sweet spot in its segment. It’s compact enough to integrate easily into a family room, living room, or dedicated listening space, yet plays well above its physical size...Combine that with the planar magnetic tweeter and midrange and a perfectly-sized bass array, an...
A stupendous spatial impression is given right from the start. Even the dispersion behavior is fantastic, and the ease of reproduction reminds one of pure planar speakers.
The scope, imagination, broad gesture – isn’t this the idea of American sound? Here it becomes real. The speakers are extraordinary, and I can’t wait for the monitor
Two things I noticed about this speaker, consistently, …is the mid-base and lower mid-range transition area … there’s a lot of strong upper mid-base punch that I really appreciated. … The other thing I liked…is the sound stage width …there’s a good wide sound stage but the instruments and the lay...
The FR 10s have a charming openness and spatiality.” They generate “an impressive feeling of scale and authority from a soundstage that’s typically ‘grand’.” In the summary verdict section of the review, the FR 10s are described as providing “a big-hearted, ebullient and hugely enjoyable performa...
The PS Audio Aspen FR10 loudspeaker is a great-looking and serious audiophile speaker, capable of delivering wonderfully immersive aural experiences. Whether you're into vinyl, streaming, digital file playback, or enjoying an HD show or movie over your Hifi system, the FR10s render it wondrously.
Trade up to it
You do not have to have bought from us before, and it does not have to be ours. Trade in almost any component from any brand and we credit its full original retail value against this one — up to a per-component cap that appears the moment you start a trade. See what yours is worth.
Hear it first
Every piece comes with a 30-day in-home trial. PMG Signature pieces get 60 days, with return shipping on us.
Not for sale
Aspen loudspeakers are designed in Boulder, Colorado, and we are glad to show our work.Paul answers questions on video most weekdays, and the factory is open to visitors.
Design
Application
Overview
The Drivers
The Enclosure
Features
16 key featuresFULL-RANGE 3-WAY SYSTEM
86.5 dB SENSITIVITY
ONE 2.5" PLANAR RIBBON TWEETER
8" PLANAR RIBBON MIDRANGE
TWO 6.5" LOW DISTORTION HIGH EXCURSION WOOFERS
THREE 6X9” HIGH EXCURSION PASSIVE RADIATORS
NON-WOVEN CARBON FIBER SKIN ON ROACELL FOAM CORE WOOFER CONES
THERMOSET FIBERGLASS RESIN FRONT BAFFLES
SMOOTH AND FULL OFF AXIS RESPONSE
ONE PIECE CABINET FOR EASY SETUP
SOFT RUBBER FEET WITH REMOVABLE STAINLESS STEEL SPIKES AND MILLED ALUMINUM TOP CAP NUT
EASY TO POSITION FOR BEST PERFORMANCE
HEAVY INTERNAL BRACING FOR LOW CABINET VIBRATION
CUSTOM FILM CAPACITORS & PREMIUM AIR-CORE INDUCTORS
MAGNETICALLY ATTACHED GRILLES
MILLED, GRAINED AND ANODIZED ALUMINUM BASE
Reviews
7 reviews
The PS Audio Aspen FR10 hits a sweet spot in its segment. It’s compact enough to integrate easily into a family room, living room, or dedicated listening space, yet plays well above its physical size...Combine that with the planar magnetic tweeter and midrange and a perfectly-sized bass array, and the FR10 is a true all-around performer – and an easy speaker to live with.
Read full review →
Read full review →
Read full review →Two things I noticed about this speaker, consistently, …is the mid-base and lower mid-range transition area … there’s a lot of strong upper mid-base punch that I really appreciated. … The other thing I liked…is the sound stage width …there’s a good wide sound stage but the instruments and the layering and the precision of objects within the sound stage are very well defined
Read full review →
Read full review →
Read full review →
Read full review →Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
Specifications
