Factory Certified
Aspen · Floorstanding loudspeaker
Aspen® FR10
Full, room-filling sound, and easy to place in any room.
$7,499 / pair $9,999
Options
Join the waiting list
Factory Certified units come back in small numbers. Leave your email and we'll let you know when one is ready.
Buy or audition near you
All dealers
Factory Certified
Tested in Boulder by the people who built it
14-day in-home evaluation. One-year factory warranty when registered. Each unit is fully factory tested in Boulder; some may show light cosmetic blemishes.
Factory Certified units are already priced well below new, so they can't be combined with Trade-Up credit or other discounts.
Designed for typical living rooms
  • Size (H × W × D) 41.5" × 11.75" × 16.25"
  • Weight 75 lb each
  • Deep bass Down to 25 Hz in-room
  • Drivers Ribbon tweeter, 8" ribbon midrange, two 6.5" woofers
The Absolute Sound 2027 Editors’ Choice
Stand-mount & floorstanding loudspeakers
What reviewers say
…a big-hearted, ebullient and hugely enjoyable performance across the board.
HHi-Fi News2024
Extremely low & tight bass. Well-blended, smooth & silky treble
TThe Absolute SoundAdrian Alexander, 2024
A stupendous spatial impression is given right from the start.
77ReviewChristian Bayer, 2025
Why choose it
Full sound, easy to place
A ribbon tweeter and 8-inch ribbon midrange, with two 6.5-inch woofers and three passive radiators taking the bass to 25 Hz in-room. Compact enough for a typical living room.
Where it fits
Loudspeakers are part of the family. With their presence, they grace our homes and living areas by bringing the joy of music into our lives. Unlike the electronics that drive them, to perform their best most loudspeakers depend on proper placement and optimized room parameters.
Read more
Loudspeakers are part of the family. With their presence, they grace our homes and living areas by bringing the joy of music into our lives. Unlike the electronics that drive them, to perform their best most loudspeakers depend on proper placement and optimized room parameters. The Aspen FR10, however, is designed to more easily fit into any living environment and perform at their best with a minimum of setup hassles and a maximum of options. While the FR10, like all high-performance speakers, appreciates some breathing room between them and the front wall, placement in the room for best performance is a snap. Using the included step-by-step guide and CD, setup, from unboxing to playing music, happens easily in a few short hours.
Design
How it's built
The FR10 joins the ranks of a rare handful of true full-range speakers that can honestly cover the frequency range of 30Hz to beyond 20kHz with grace, dynamics, slam, and low distortion—and work in any small to medium-sized room. Within moments of installing your new Aspen FR10 loudspeakers, you'll instantly be transported to a new level of musical ecstacy.
Read the full design story
The FR10 joins the ranks of a rare handful of true full-range speakers that can honestly cover the frequency range of 30Hz to beyond 20kHz with grace, dynamics, slam, and low distortion—and work in any small to medium-sized room. Within moments of installing your new Aspen FR10 loudspeakers, you'll instantly be transported to a new level of musical ecstacy. What's captured on the disc is exactly what you'll hear with a greater resolution than most have ever experienced. Grace, beauty, PRaT, power, and a musicality that is rare amongst 6 figure offerings from other manufacturers await owners of the Aspen FR10. That this speaker is financially within reach of many makes it a miracle.
86.5 dB
sensitivity
8-inch
planar ribbon midrange
3-way
full range
01
Overview
By far the most important piece in the HiFi chain is the loudspeaker. If the speaker cannot reproduce what it is fed from the electronic chain, the missing musical information is forever lost.
Read more
By far the most important piece in the HiFi chain is the loudspeaker. If the speaker cannot reproduce what it is fed from the electronic chain, the missing musical information is forever lost. To achieve all that music demands, over the years, loudspeaker designers have tried to leverage every trick in the book: electrostats for details, conventional drivers for dynamics, planars for transparency, ribbons, domes, horns, open baffles, bipoles, dipoles. The list is endless and the choices and their inevitable sonic compromises daunting. With close to 50 years under our collective belts, we at PS Audio determined to design the perfect loudspeaker for every application, room size, and budgets. In the Aspen series we start with the FR30, then move to the FR20 and then the FR10. Each is a full range state-of-the-art loudspeaker that covers the range of possibilities from small to large rooms and to meet every budget need. The FR10 will fit into every small to medium sized room and provide room-shaking bass down to 30Hz. For the upper end, the FR10 employs the same Aspen planar tweeter as found in both the FR20 and FR30. For our legendary open midrange, the FR10 relies upon the same planar technology as found in its bigger counterparts. Without question, the Aspen FR10 is the perfect loudspeaker for any room and budget.
02
The Drivers
The heart and soul of any loudspeaker are its drivers, the transducers that in response to the amplifier's demands pressurize the air and generate the music. Each driver must be optimized for the task at hand.
Read more
The heart and soul of any loudspeaker are its drivers, the transducers that in response to the amplifier's demands pressurize the air and generate the music. Each driver must be optimized for the task at hand. In the FR10, it quickly became apparent we could not source from even the most advanced driver manufacturers in the world the ultra-low-distortion high-dynamic output drivers we would need to build the FR10. We started with our tweeter and midrange for here are the two most difficult drivers to perfect. Moving air at high frequencies without colorations or distortion is a daunting task. On the FR10 we chose to go with a technology that has the speed of an electrostat with the dynamics of a cone. Planar Magnetics. These ultra-low distortion drivers are equally driven with front and rear magnetic structures that offer inherent linearity through symmetrical “push-pull” neodymium motor structures and directly driven ultra-low mass diaphragms with none of the cone or dome breakup, inductance modulation, or hysteresis distortion that plagues traditional drivers. For the low end, we crafted long-throw high-excursion 6.5" woofers that match the effortlessness and transparency of the planar magnetic drivers. To lower distortion, we employed a unique split magnetic gap and a double Faraday ring for low, linear inductance and wide bandwidth, coupled with a single progressive Nomex spider with stitched-in lead wires. The woofer cones are a low-mass Rohacell foam core. Lastly, to achieve maximum linearity and extended deep bass extension without the compression and distortion of ports, we implemented 3 rear-mounted high-compliance passive radiators. Together, these elements create a stunning presentation of music in your home.
03
The Enclosure
Loudspeakers have an honored place in our homes. They often are the focal point of our living rooms and, in that capacity, must proudly make a statement of fitting elegance.
Read more
Loudspeakers have an honored place in our homes. They often are the focal point of our living rooms and, in that capacity, must proudly make a statement of fitting elegance. The Aspen FR10 enclosure design starts with the internal structure necessary for great sound and then lovingly sculpted into a work of art befitting our homes. With industrial design by famed Studio 63, the FR10's elegant look and smaller form factor complements every decor. Internally, the FR10 is an extensively braced enclosure designed to minimize external vibrations that have the potential of coloring the sound. Externally, the enclosures are lovingly finished with 20 coats of hand-rubbed high-grade lacquer. While the main body and baffling structure are built with MDF, the sculpted front baffle is formed from a dense, rigid and well-damped high-tech thermoset fiberglass resin composite material with integrated high-frequency acoustic waveguides. The speakers look to be almost floating as its curved bottom rests upon its sturdy aluminum base featuring large milled brass spikes with removable tips and integrated plastic feet for hard surfaces (and to aid in speaker placement). A masterpiece of design and love, crafted by those of us that care deeply about music and its reproduction in the home.
Features
At a glance
  • Full-range 3-way system
  • 86.5 dB sensitivity
  • One 2.5" planar ribbon tweeter
  • 8" planar ribbon midrange
  • Two 6.5" low distortion high excursion woofers
  • Three 6x9” high excursion passive radiators
  • Non-woven carbon fiber skin on roacell foam core woofer cones
  • Thermoset fiberglass resin front baffles
  • Smooth and full off axis response
  • One piece cabinet for easy setup
  • Soft rubber feet with removable stainless steel spikes and milled aluminum top cap nut
  • Easy to position for best performance
  • Heavy internal bracing for low cabinet vibration
  • Custom film capacitors & premium air-core inductors
Specifications
Full specifications
Color OptionsSatin White, Satin Black
Enclosure TypePassive radiator (three 6x9” oval rear-firing)
High Frequency Transducer2.5” planar magnetic with Teonex diaphragm
Mid Frequency Transducer8” planar magnetic with Teonex diaphragm
Low Frequency Transducer2 x 6.5” woofers, cast frame, non-woven carbon fiber PMI foam sandwich cone, advanced magnet structure
Crossover Frequency550 Hz, 1750 Hz - Linkwitz-Riley 4th order acoustic
Sensitivity (2.83V @ 1M)86.5 dB
Nominal Impedance4 ohm (3.3 ohm minimum impedance)
Recommended Amplifier Power50-200W
Frequency Response32 Hz-20 kHz (-6dB) half space, 25 Hz (-6 dB) in-room
Dimensions (HxWxD)41.5” x 11.75” x 16.25” with base (8” width not including base)
Net Weight75 lbs (34.1 kg)
Compare
How it compares
FR30FR20FR10This oneFR5F12
Price$34,999 / pair$22,999 / pair$9,999 / pairFrom $3,499 / pairFrom $2,749 / each
Size (H × W × D)60.5" × 16" × 25.75"50.5" × 16" × 18.75"41.5" × 11.75" × 16.25"14.5" × 8" × 13" (stand 28.25" tall)16.75" × 14.75" × 17.5"
Weight230 lb each133 lb each75 lb each26.6 lb each77 lb each
RoomLarge roomsMedium to large roomsTypical living roomsSmall to medium roomsAny room. Stackable
Deep bassDown to 20 Hz in-roomDown to 20 Hz in-roomDown to 25 Hz in-roomDown to 30 Hz in-roomFlat to below 20 Hz in-room
DriversTwo ribbon tweeters, 10" ribbon midrange, four 8" woofersRibbon tweeter, 10" ribbon midrange, two 8" woofersRibbon tweeter, 8" ribbon midrange, two 6.5" woofersRibbon tweeter, 6.5" wooferSealed 12" driver
Amp power100–600 W50–300 W50–200 W50–150 WBuilt in: 1,000 W
Build your system
What it pairs with
Reviews
More reviews
The PS Audio Aspen FR10 hits a sweet spot in its segment.
It’s compact enough to integrate easily into a family room, living room, or dedicated listening space, yet plays well above its physical size...Combine that with the planar magnetic tweeter and midrange and a perfectly-sized bass array, and the FR10 is a true all-around performer –...
GGreg Handy - Future Audiophile2026
Read the full review
Even the dispersion behavior is fantastic, and the ease of reproduction reminds one of pure planar speakers.
CChristian Bayer 7Review2025
The scope, imagination, broad gesture – isn’t this the idea of ​​American sound? Here it becomes real.
The speakers are extraordinary, and I can’t wait for the monitor
MMaciej Stryjecki Hifi and Music2025
Two things I noticed about this speaker, consistently, …is the mid-base and lower mid-range transition area … there’s a lot of strong upper mid-base punch that I really appreciated.
… The other thing I liked…is the sound stage width …there’s a good wide sound stage but the instruments and the layering and the precision of objects within the sound stage are very well defined
EErin’s Audio Corner2024
The FR 10s have a charming openness and spatiality.” They generate “an impressive feeling of scale and authority from a soundstage that’s typically ‘grand’.” In the summary verdict section of the review, the FR 10s are described as providing “a big-hearted, ebullient and hugely enjoyable performance across the board.” With careful setup, they offer “a scale and level of authority that belies their compact dimensions.
HHi-Fi News2024
The PS Audio Aspen FR10 loudspeaker is a great-looking and serious audiophile speaker, capable of delivering wonderfully immersive aural experiences.
Whether you're into vinyl, streaming, digital file playback, or enjoying an HD show or movie over your Hifi system, the FR10s render it wondrously.
PPositive Feedback2024
Read all 7 reviews
AAdrian Alexander, The Absolute Sound2024
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialist
Outside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Find your local dealer
Satin White Pair
Skip to product information
Satin White Pair
href="/products/aspen-fr10-loudspeaker-refurbished?variant=49560768512290" class="link" >Aspen FR10 Loudspeaker - Factory Certified
<p>Each speaker has been inspected, tested and has been brought to a “like new” sonic state. Refurbished units may have slight cosmetic imperfections. Cosmetic issues cannot warrant a return. All refurbished units have a 14 day return policy. To learn more about refurbished units please see our <a href="/pages/warranty-and-returns" target="_blank">warranty and return policy</a>.</p>The perfect size loudspeaker for any room.<br /><p style="font-weight: bold;">Hi-Fi News says the Aspen FR10 sets the $10k standard. Check out the rest of the review <a href="https://cdn.shopify.com/s/files/1/0672/2283/1394/files/Hi-Fi_News_April_2024_PS_Audio_aspen_FR10_with_cover.pdf?v=1710969693" target="_blank">here</a>.</p>
The ground-breaking Aspen series of loudspeakers sets new standards for what is possible in home audio reproduction. Now, with the introduction of our most compact loudspeaker yet, the FR10, it is finally possible to bring the magic of Aspens into everyone’s home.
The Aspen loudspeaker series represents the culmination of 50 years of industry experience; learning in intimate detail what works and what does not; what it takes for a loudspeaker to disappear and leave only the magic of the music; designing a no-compromise phase-correct crossover; constructing a cabinet that does not color the sound; crafting a speaker that is easily driven with any decent power amplifier, and when not even the most advanced driver manufacturer’s products are good enough to meet our exacting standards, designing woofers, radiators, tweeters, and midranges from scratch. In all respects, the FR10 will transcend your expectations of what a small floor-standing loudspeaker can do.
No longer do you have to compromise.
Breathtaking to listen to, beautiful to behold, fits in any size room, with bass that will astound you, the Aspen FR10 is a dream come true.
Note:
Price is per pair.
Sale price  $7,499.00 Regular price  $9,999.00
Factory Certified 14-Day In-Home Evaluation Click for details
What Factory Certified means
These are PS Audio units that have come home to our factory in Boulder — trade-ins, demos, and returns — not off-the-shelf new production. Each one is fully tested on the same benches we use for new gear: performance, safety, and reliability before it ships again.
  • 14-day in-home evaluation — live with it in your own system before you decide.
  • One-year factory warranty from your purchase date when you register the serial (new products carry three years).
  • Honest cosmetics — function and measured performance meet factory standards; some units may show light blemishes.
Full Factory Certified warranty and evaluation terms
Overview
The Drivers
The Enclosure
What owners and reviewers say
The PS Audio Aspen FR10 hits a sweet spot in its segment. It’s compact enough to integrate easily into a family room, living room, or dedicated listening space, yet plays well above its physical size...Combine that with the planar magnetic tweeter and midrange and a perfectly-sized bass array, an...
Greg Handy - Future Audiophile · Read full review
A stupendous spatial impression is given right from the start. Even the dispersion behavior is fantastic, and the ease of reproduction reminds one of pure planar speakers.
Christian Bayer 7Review · Read full review
The scope, imagination, broad gesture – isn’t this the idea of ​​American sound? Here it becomes real. The speakers are extraordinary, and I can’t wait for the monitor
Maciej Stryjecki Hifi and Music · Read full review
Two things I noticed about this speaker, consistently, …is the mid-base and lower mid-range transition area … there’s a lot of strong upper mid-base punch that I really appreciated. … The other thing I liked…is the sound stage width …there’s a good wide sound stage but the instruments and the lay...
Erin’s Audio Corner · Read full review
The FR 10s have a charming openness and spatiality.” They generate “an impressive feeling of scale and authority from a soundstage that’s typically ‘grand’.” In the summary verdict section of the review, the FR 10s are described as providing “a big-hearted, ebullient and hugely enjoyable performa...
Hi-Fi News · Read full review
The PS Audio Aspen FR10 loudspeaker is a great-looking and serious audiophile speaker, capable of delivering wonderfully immersive aural experiences. Whether you're into vinyl, streaming, digital file playback, or enjoying an HD show or movie over your Hifi system, the FR10s render it wondrously.
Positive Feedback · Read full review
Adrian Alexander, The Absolute Sound · Read full review
This is not the 30-day new-product trial — it is the Factory Certified evaluation period. How it works, or read the full warranty and returns policy.
Not for sale
We build these in Boulder, Colorado, and we are glad to show our work. Paul answers questions on video most weekdays, and the factory is open to visitors.
At home
Where it disappears into the music.
14-day in-home evaluation $7,499.00 the pair
Add to cart
Call
TALK TO A HI-FI SPECIALIST
Design
Applications
Overview
The Drivers
The Enclosure
Product Videos
Features
16 key features
FULL-RANGE 3-WAY SYSTEM
86.5 dB SENSITIVITY
ONE 2.5" PLANAR RIBBON TWEETER
8" PLANAR RIBBON MIDRANGE
TWO 6.5" LOW DISTORTION HIGH EXCURSION WOOFERS
THREE 6X9” HIGH EXCURSION PASSIVE RADIATORS
NON-WOVEN CARBON FIBER SKIN ON ROACELL FOAM CORE WOOFER CONES
THERMOSET FIBERGLASS RESIN FRONT BAFFLES
SMOOTH AND FULL OFF AXIS RESPONSE
ONE PIECE CABINET FOR EASY SETUP
SOFT RUBBER FEET WITH REMOVABLE STAINLESS STEEL SPIKES AND MILLED ALUMINUM TOP CAP NUT
EASY TO POSITION FOR BEST PERFORMANCE
HEAVY INTERNAL BRACING FOR LOW CABINET VIBRATION
CUSTOM FILM CAPACITORS & PREMIUM AIR-CORE INDUCTORS
MAGNETICALLY ATTACHED GRILLES
MILLED, GRAINED AND ANODIZED ALUMINUM BASE
Reviews
7 reviews
The PS Audio Aspen FR10 hits a sweet spot in its segment. It’s compact enough to integrate easily into a family room, living room, or dedicated listening space, yet plays well above its physical size...Combine that with the planar magnetic tweeter and midrange and a perfectly-sized bass array, and the FR10 is a true all-around performer – and an easy speaker to live with.
Read full review →
Read full review →
Read full review →
Erin’s Audio Corner
Two things I noticed about this speaker, consistently, …is the mid-base and lower mid-range transition area … there’s a lot of strong upper mid-base punch that I really appreciated. … The other thing I liked…is the sound stage width …there’s a good wide sound stage but the instruments and the layering and the precision of objects within the sound stage are very well defined
Read full review →
Hi-Fi News
Hi-Fi News
Read full review →
Positive Feedback
Positive Feedback
Read full review →
Read full review →
Want to leave your own review?
Specifications
Technical details
Color Options Satin White, Satin Black
Enclosure Type Passive radiator (three 6x9” oval rear-firing)
High Frequency Transducer 2.5” planar magnetic with Teonex diaphragm
Mid Frequency Transducer 8” planar magnetic with Teonex diaphragm
Low Frequency Transducer 2 x 6.5” woofers, cast frame, non-woven carbon fiber PMI foam sandwich cone, advanced magnet structure
Crossover Frequency 550 Hz, 1750 Hz - Linkwitz-Riley 4th order acoustic
Sensitivity (2.83V @ 1M) 86.5 dB
Nominal Impedance 4 ohm (3.3 ohm minimum impedance)
Recommended Amplifier Power 50-200W
Frequency Response 32 Hz-20 kHz (-6dB) half space, 25 Hz (-6 dB) in-room
Dimensions (HxWxD)
Net Weight 75 lbs (34.1 kg)
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
Specifications
Dimensions (HxWxD)
Recommended products
