Starting from scratch
Few people ever get the chance to build a high-end audio system from the ground up.
Most systems evolve piece by piece. A new amplifier here, better speakers there, a cable upgrade when something sounds off. or the latest innovation tickles one's fancy But starting from zero—no gear, no constraints, a clean slate—is both a luxury and a challenge. Because the moment you have full freedom, you also carry full responsibility.
Every choice matters. There’s nowhere to hide. Nothing to blame.
The first question is always the same: where do you begin? Source, amp, speakers, room treatment? The answer depends on priorities. But one thing’s for sure: the room and speakers set the limits, and everything else serves them. You can’t build around weak foundations.
I’ve helped enough people build systems from scratch to know how easy it is to miscalculate. Components that work great in isolation don’t always gel together. That’s why synergy and voicing matter. You’re not assembling a spec sheet—you’re shaping a sonic identity.
It’s rare to have the opportunity to build without compromise. But when it happens, and you get it right, the reward is a system that doesn’t just sound good—it sounds intentional. Coherent. Whole.
