Imagine that
Imagine that
When I started this journey over 50 years ago, the audiophile gold standard wasn’t imaging—it was tonal balance.
Back then, we didn’t talk much about soundstage depth or disappearing speakers. The conversation centered on frequency response. Was the bass extended? Were the highs rolled off? Did it sound warm, bright, full, thin?
Tonal accuracy was the Holy Grail. Imaging, if it came up at all, was more of a curiosity than a priority.
It took years of writing, demonstrating, and relentless listening to help shift that focus. Not just my own efforts, but the work of others in the field who shared the same belief: that great sound isn’t just about tone—it’s about space. The moment a system stops sounding like it’s coming from boxes and starts sounding like it’s coming from a room behind the speakers, that’s when you know something special is happening.
And let me tell you, that idea didn’t land easily. I can’t count how many battles I’ve had to fight trying to convince folks that the goal isn’t to make the speakers sound good—it’s to make them go away entirely. And when someone hears that for the first time, when the music blooms in the air instead of firing at them from a driver, they get it.
The resistance disappears along with the hardware.
The beautiful part is, these two elements—tonal balance and imaging—aren’t separate. They’re linked. In fact, one depends on the other.
If the tonal balance is off, so is the imaging. It’s not a maybe—it’s a rule.
Our brains use tonal cues to localize sound. If there’s too much energy in one region—say, a hot upper midrange—it pulls the image forward or off-center. If there’s a dip, the soundstage collapses. You can’t fix imaging unless tone is right first.
But the opposite isn’t true. A system can be tonally accurate and still fall short on spatial performance—because imaging also depends on timing, phase alignment, room setup, and driver integration. Getting all of that right is what makes the speakers vanish.
So yes, it’s been a long road shifting the conversation from just frequency charts to full immersion. But every “aha” moment I’ve seen on a listener’s face makes it worth the effort. Because once you’ve heard the magic of a system that’s both tonally true and spatially invisible, there’s no going back.
That’s when the gear steps aside and the music takes center stage—exactly where it belongs.
Imagine that
Imagine that
