Ears
Ears
No two people hear the same music from the same system, because no two people have the same ears.
This is one of those facts that the audio industry conveniently ignores. We spend fortunes on room treatment, speaker placement, and component matching, all to deliver the most accurate signal possible to the listening position. But the final and most variable link in the chain is the listener's own hearing, and it is different for every single person. A fifty-year-old with a gentle high-frequency rolloff starting at eight kilohertz is hearing a fundamentally different presentation than a twenty-five-year-old with flat response to sixteen kilohertz. Same speakers, same room, completely different experience.
The idea of personalizing a system to compensate for individual hearing loss is not new, but it has always been impractical. Hearing aids are designed for speech intelligibility, not musical fidelity. They compress dynamics, apply noise reduction algorithms, and generally mangle the signal in ways that would make any serious listener cringe. The few music-focused hearing aid programs available today are better, but they are still compromised by the tiny drivers and processing limitations of devices designed to fit inside an ear canal.
What intrigues me is the concept of a dedicated hardware device in the signal chain that applies a personalized correction filter based on an individual hearing assessment. You would take a comprehensive hearing test, generate a correction curve, and load it into a small box sitting between your preamp and power amp. The device would boost the specific frequencies you are personally deficient in, symmetrically or asymmetrically between ears, without touching anything else. No compression, no noise reduction, no speech optimization. Just a transparent, linear correction tailored to your biology.
I am not sure the market is ready for this, but it's worth thinking about. And then, as long as we're dreaming, what about the ability through DSP to remaster tracks of music and memorize those changes so that every track you play, whether old and awful or new and wonderful get corrected to your likes and dislikes.
Science fiction? Maybe.
Or maybe not. :)
Ears
Ears
Or maybe not. :)
