Picking a fight
Picking a fight
Your room is either working with your speakers or against them, and most rooms are picking a fight.
I have visited hundreds of listening rooms over the decades, from purpose-built audiophile sanctuaries to converted garages and spare bedrooms. The single biggest variable between the great-sounding ones and the disappointing ones was not the electronics or the speakers. It was the room itself and what the owner had done, or failed to do, about its acoustics.
A modest system in a well-treated room will consistently outperform an expensive system in an untreated one. I have seen this play out so many times that I consider it a law of audio.
The reason is physics. Sound waves radiate from your speakers in all directions, not just toward your ears. They bounce off walls, floors, and ceilings, arriving at your listening position milliseconds after the direct sound. These reflections interfere with the original signal, causing comb filtering that smears the frequency response and muddies the stereo image. Bass waves are particularly problematic because they build up in corners and create standing waves that produce boomy peaks at some frequencies and complete cancellation at others. No speaker, regardless of price, can overcome a room that is working against it.
Where does treatment rank in the hierarchy of system priorities? In my experience, it belongs right near the top, after speakers and before most electronics upgrades. I would rather listen to a good pair of speakers in a treated room through a modest amplifier than hear the finest amplifier in the world driving those same speakers in a bare, reflective box. The electronics are reproducing the signal faithfully, but the room is destroying it before it reaches your ears. Fix the room first and suddenly every component in your chain sounds better because you can finally hear what they are actually doing.
If you have been upgrading cables, swapping DACs, and chasing the next amplifier hoping for a breakthrough, take an honest look at your room.
The biggest improvement you have not made yet might be a few diffuser panels or a well placed bookshelf.
Your speakers will thank you, and so will your ears.
Picking a fight
Picking a fight
