Too much oxygen
Too much oxygen
Oxidation is the silent thief of audio performance, and it is robbing you right now whether you know it or not.
Every metal contact in your audio system is slowly degrading. The moment you plug an RCA connector into a jack or tighten a binding post onto a spade lug, the exposed metal surfaces begin reacting with oxygen, moisture, and airborne contaminants. Over months and years, a thin layer of oxide builds up on those contact surfaces, and that oxide is a lousy conductor. It introduces micro-resistance at every junction, and while each individual connection might only add a fraction of an ohm, the cumulative effect across dozens of connections in a typical system is not trivial. It is like listening through a very thin dirty window.
I was reminded of this recently when a friend spring-cleaned every connection in his system with a quality contact cleaner for the first time in several years. The overall sound became more immediate and present. What had happened was so gradual over time that he never noticed the degradation until it was suddenly reversed.
The science here is straightforward. A clean metal-to-metal contact has low resistance and allows the signal to pass with minimal loss. An oxidized contact acts as a tiny resistor and can also behave as a crude diode junction at the molecular level, introducing nonlinear distortion. This is not audiophile voodoo. It is basic electrochemistry. Gold-plated connectors resist oxidation better than bare copper or nickel, which is exactly why they are used on quality components, but even gold-plated surfaces accumulate contaminants over time from handling, dust, and environmental exposure.
The fix is simple and inexpensive. A good contact cleaner like DeoxIT applied once or twice a year to every connection in your system will keep things in top shape. Unplug each cable, apply a small amount to both the plug and the jack, reconnect, and move on to the next one. The whole process takes maybe thirty minutes for a typical two-channel system. While you are at it, check that your binding posts are snug and your RCA connections seat firmly. A loose connection is even worse than a dirty one.
Think of it as maintenance rather than an upgrade.
Too much oxygen
Too much oxygen
