Copper Magazine · Issue 225 · A free PS Audio publication
Issue 225 Paul's Place
From The Audiophile’s Guide: Controlling Bass Frequencies Through Membrane Absorbers (and How to Build Your Own)
When it comes to controlling bass frequencies in a room, it’s important to remember that most bass problems can be solved through careful placement of both your listening position and speakers. As we cover elsewhere in The Audiophile’s Guide, finding the right spot in your room – typically avoiding the halfway points and keeping about 38 percent away from walls – can dramatically improve bass response. Adding a properly placed subwoofer (or two) can further help smooth out room modes and create more even bass throughout the listening area.
However, even with optimal placement and good subwoofers, some rooms still suffer from stubborn bass problems. This is where membrane absorbers come into play as one of our most powerful tools. Unlike porous absorbers (like foam or fiberglass) that work well for mid and high frequencies, membrane absorbers specifically target those troublesome low frequencies that can make bass sound boomy or uneven.
Think of a membrane absorber like a drum head that’s been engineered not to resonate. It typically consists of a flexible panel (like plywood, MDF, or even heavy vinyl) mounted a specific distance from a rigid wall, creating an air cavity behind it. When low-frequency sound waves hit this panel, they cause it to flex slightly. This movement converts acoustic energy into heat through friction, effectively absorbing those problematic bass frequencies.
We can tune the absorbers to specific frequencies. The resonant frequency of the absorber depends on three main factors: the mass of the panel, the depth of the air cavity behind it, and the panel’s stiffness. By adjusting these parameters, we can target specific problem frequencies in our rooms.
Before diving into DIY solutions, let’s look at some commercial options. Companies like RPG, Primacoustic, and GIK Acoustics offer excellent membrane absorbers that are professionally built and tested. RPG’s Modex Plate is particularly effective for low-frequency absorption below 100 Hz. GIK’s SofFit Trap combines membrane absorption with additional diffusion properties. Primacoustic’s MaxTrap combines a membrane absorber with a precision-tuned Helmholtz resonator.
These commercial solutions offer several advantages: they’re precisely engineered, tested for specific frequency responses, and usually come with detailed placement recommendations. They also typically include fire-retardant materials and professional finishing that can be challenging to achieve in DIY projects.
A Primacoustic GoTrap bass trap.
But for those interested in building their own, let’s understand how membrane absorbers work and how to construct them effectively. The basic principle is surprisingly simple: when low-frequency sound waves hit a flexible panel mounted in front of an air cavity, they cause the panel to vibrate. This vibration converts acoustic energy into heat through friction, effectively absorbing those problematic bass frequencies.
Here’s a basic DIY design that’s proven effective. Materials needed:
  • 1/4-inch or 1/2-inch MDF or plywood for the panel
  • 2 x 4s for the frame
  • Rigid fiberglass or mineral wool (4 inches thick)
  • Fabric for covering
  • Wood screws and staples
  • Acoustic caulk
The construction process involves building a frame that’s typically 2 feet wide by 4 feet tall, with a depth of 4 to 6 inches. The depth of the air cavity crucially determines which frequencies the absorber will target. A deeper cavity shifts absorption to lower frequencies. The flexible panel (MDF or plywood) is mounted to the front of the frame, and the cavity is partially filled with absorption material.
The key to effectiveness lies in the panel’s ability to flex. It shouldn’t be too rigid (which would reflect bass) or too loose (which would be ineffective). The absorption material behind the panel provides damping to prevent the panel from resonating at its natural frequency.
For optimal tuning, use this basic formula for resonant frequency:
F = 60 * √(d/md)
Where F = resonant frequency in Hz, d = depth of air cavity in inches, and m = surface density of the panel in lbs./sq.ft. This lets you calculate the cavity depth needed to target specific problematic frequencies in your room. For most home listening rooms, targeting the 50 – 80 Hz range is most beneficial.
The frame construction is critical. While 2 x 4s are common, using 2 x 6s gives you more flexibility in tuning because you can adjust the cavity depth. Build your frame like a shallow box, but here’s a crucial detail often overlooked: add additional cross-bracing every 16 inches. This prevents the frame itself from resonating and keeps the panel’s movement controlled and predictable.
The panel material choice dramatically affects performance. Here’s what we’ve found works best:
  • 1/2-inch MDF for targeting 60 – 80 Hz
  • 1/4-inch MDF for 40 – 60 Hz
  • 1/8-inch hardboard (like Masonite) for frequencies above 80 Hz
A critical detail: don’t screw the panel directly to the frame. Instead, create a small lip around the frame’s edge using 1x2 strips, then secure the panel to this lip. This allows for more controlled movement of the panel’s center area, where most of the absorption occurs.
The absorption material inside the cavity is crucial for proper operation. Without it, you’ve basically built a bass drum. Here’s the proper layering from back to front:
  • Line the back wall with 1-inch rigid fiberglass
  • Leave an air gap
  • Add a 2-inch layer of semi-rigid mineral wool
  • Leave another small air gap before the panel
This layering creates progressive damping of the panel’s movement, providing broader frequency absorption rather than a sharp resonant peak.
Here’s something I learned through trial and error: you can fine-tune the absorber’s frequency response after construction. Add small weights to the panel’s center to lower the resonant frequency, or increase panel stiffness with cross-bracing to raise it. Keep track of changes with measurements if possible.
A secret weapon in tuning: use mass-loaded vinyl (MLV) between the panel and frame. This helps control edge resonances and can shift the absorption range lower in frequency. Membrane absorbers work best in corners where bass energy concentrates. But here’s a less obvious placement tip: stack them. By placing two absorbers tuned to slightly different frequencies in the same corner, you can broaden the absorption range significantly. For maximum effectiveness, aim to cover about 15 – 20 percent of your total wall surface area with membrane absorption. But don’t go overboard – too much absorption can make the room sound lifeless.
The real test comes in measuring the results. Here’s a simple test method:
  • Play a sine wave sweep from 30 – 120 Hz
  • Record the room response with and without the absorber
  • Look for a reduction in level at your target frequencies
If you have access to measurement equipment like a calibrated microphone and software (REW is excellent and free), you can precisely measure the absorber’s effectiveness.
Common mistakes to avoid include:
  • Over-damping the cavity: too much absorption material actually reduces effectiveness
  • Under-bracing the frame: a resonating frame creates unwanted colorations
  • Mounting too rigidly: the panel needs to move to absorb energy
  • Ignoring air-tightness: seal all frame joints with acoustic caulk
Now let’s talk about how to effectively integrate membrane absorbers into a complete room treatment strategy. This is where many people go wrong – they’ll add membrane absorbers without considering how they work with other acoustic elements in the room.
First, let’s understand the hierarchy of room treatment. Start with bass management through proper speaker and listening position placement. Then add subwoofers if needed. Only after these fundamental steps are optimized should you begin adding membrane absorbers. Think of it like seasoning a dish; you want to taste the food first before adding salt.
Here’s how to integrate membrane absorbers effectively:
In most rooms, start with tri-corner bass traps (where walls meet the ceiling). These locations typically need broad‐ band absorption, a combination of membrane absorbers for low frequencies and porous absorption for higher frequencies. A practical solution is to build or buy corner units that combine both technologies. The membrane absorber handles below 100 Hz, while the porous material manages everything above.
When placing membrane absorbers on walls, consider their interaction with first-reflection point treatment. A common mistake is placing membrane absorbers at first reflection points where you actually need broadband absorption and diffusion. Instead, position membrane absorbers between or below these critical points.
Modern rooms often have large windows or doors that can’t be covered. Here’s a practical tip we’ve discovered: use freestanding membrane absorbers that can be moved. These can be disguised as room dividers or decorative panels, and their position can be adjusted based on listening tests. One effective strategy is the “layer cake” approach:
  • Bottom layer: Membrane absorbers for low frequencies
  • Middle layer: Broadband absorption for mids
  • Top layer: Diffusion for highs
This creates a complete treatment solution that maintains room liveliness while controlling problematic frequencies.
Here’s something we’ve learned through experience: the best acoustic treatment is the one that actually stays in the room. Work with your room’s aesthetics. Membrane absorbers can be covered with the same fabric as other room treatments, creating a cohesive look. They can even be designed to match furniture or architectural features.
More from Issue 225
View All Articles in Issue 225
Favorites From T.H.E. Show SoCal 2026 by Cam Martin Oct 05, 2026 #235 Singer/Songwriter John David Schrader: On the Need to Create, Part Two by Joe Caplan Oct 05, 2026 #235 A Life in High-End Audio: The Roy Hall Interview, Part Two by Frank Doris Oct 05, 2026 #235 Grammy-Winning Producer, Songwriter, and Guitarist John Leventhal Goes Instrumental With National Drift by Ray Chelstowski Oct 05, 2026 #235 From Swimming Pool to New Listening Room—to Founding an Accidental Audio Company by Gilles Laferrière Oct 05, 2026 #235 The Vinyl Beat’s Size Matters Edition by Rudy Radelic Oct 05, 2026 #235 The Sublime Complexities of Nature by B. Jan Montana Oct 05, 2026 #235 How to Play In a Rock Band, 28: Growing Older and Dealing With It by Frank Doris Oct 05, 2026 #235 Young Rascals: From Bar Band to Stardom by Wayne Robins Oct 05, 2026 #235 Duncan Sheik: In Memoriam by Ray Chelstowski Oct 05, 2026 #235 From The Listening Chair: The Meze Audio 105 Silva Headphones by Howard Kneller Oct 05, 2026 #235 Checking Out Some NOLA Loudspeakers – and Some Thoughts About Audio Writing by Frank Doris Oct 05, 2026 #235 The Kanazawa Phonograph Museum: Music from a Time Capsule by Sebastian Polcyn Oct 05, 2026 #235 PS Audio in the News by PS Audio Staff Oct 05, 2026 #235 From The Audiophile’s Guide: Making the Most Critical Choice by Paul McGowan Oct 05, 2026 #235 Evolutionary Growth by Frank Doris Oct 05, 2026 #235 Speed Racer by Peter Xeni Oct 05, 2026 #235 Happy Halloween! by James Schrimpf Oct 05, 2026 #234 A Life in High-End Audio: The Roy Hall Interview, Part One by Frank Doris Sep 07, 2026 #234 Jason Greenlaw Offers His Personal Perspective on Jazz Guitar in Vantage Point by Frank Doris Sep 07, 2026 #234 Transcendent Phoenix: Lucina Yue Brings the Ancient Konghou Into Modern Times by Frank Doris Sep 07, 2026 #234 We Must All Follow Our Bliss by B. Jan Montana Sep 07, 2026 #234 How to Play in a Rock Band, 27: Leveling Up by Frank Doris Sep 07, 2026 #234 Ross Valory: Traveling Into New Musical Territory With All of the Above by Ray Chelstowski Sep 07, 2026 #234 Singer/Songwriter John David Schrader: On the Need to Create by Joe Caplan Sep 07, 2026 #234 The People Who Make Audio Happen: More From T.H.E. Show SoCal 2026 by Harris Fogel Sep 07, 2026 #234 The Vinyl Beat Digs Into the Gadget Box by Rudy Radelic Sep 07, 2026 #234 The Rolling Stones: Foreign Tongues Spoken Loud by Wayne Robins Sep 07, 2026 #234 Musical Moments by Rich Isaacs Sep 07, 2026 #234 Rags for Solo Piano and a Dog: David Chesky's Ragtime Music for the Modern Age by Frankly Speaking Sep 07, 2026 #234 HIGH END 2026, Vienna: Here to Stay by Carsten Barnbeck Sep 07, 2026 #234 From The Audiophile’s Guide: The Two Main Types of Loudpeakers – Box and Panel by Paul McGowan Sep 07, 2026 #234 Letting it Slide by Frank Doris Sep 07, 2026 #234 PS Audio in the News by PS Audio Staff Sep 07, 2026 #234 Long Playing by Peter Xeni Sep 07, 2026 #234 La Mer by B. Jan Montana Sep 07, 2026 #233 A Report From The Total Hi-Fi Experience Show SoCal 2026 by B. Jan Montana Aug 03, 2026 #233 Bluegrass Meets Country, Folk, Jazz and More in All That We Carried by The Squid City Slingers by Frank Doris Aug 03, 2026 #233 Corey Glover and One Tribe Nation: A Variegated Musical Collective by Ray Chelstowski Aug 03, 2026 #233 Excursions with Clive: The Late Clive Davis, A Personal History by Wayne Robins Aug 03, 2026 #233 AI, Art, and Music: A Conversation With Synthography Art by Joe Caplan Aug 03, 2026 #233 New American Symphonies: A Rediscovered Gem and a Vital Contemporary Work by Frank Doris Aug 03, 2026 #233 The Vinyl Beat: Genesis, the Dave Clark Five, Antonio Carlos Jobim and More by Rudy Radelic Aug 03, 2026 #233 How to Play in a Rock Band, 26: When It's Time to Record Your Music by Frank Doris Aug 03, 2026 #233 More From T.H.E. Show 2026, and the People Who Made it Happen by Harris Fogel Aug 03, 2026 #233 Underappreciated Artists, Part Three: Icehouse by Rich Isaacs Aug 03, 2026 #233 The Surprisingly Rich and Varied Music of Somalia by Steve Kindig Aug 03, 2026
From <em>The Audiophile’s Guide:</em> Controlling Bass Frequencies Through Membrane Absorbers (and How to Build Your Own)
  • Acoustic caulk
F = 60 * √(d/md)
  • Leave an air gap
