Issue 37 • Free Online Magazine
Issue 37 FEATURED
Controversy Corner ?
Part One:  Past 50? Is your hearing still good enough to worry about your system’s sound quality?
I’ll never forget these intertwined events. It was in the early 1980s. I was recording the Alabama Symphony for the Birmingham National Public Radio affiliate.
Several leading union musicians (from the Symphony tape committee) and the conductor would visit my shop one night each month. I’d play back the master recordings that I had recently made of concerts that were to be broadcast. Their job was to pick the best performance. Then I would prepare the broadcast master from my 30 I.P.S. analog master.
I came to know and to spend some time around the conductor. I’d say he was in his late ‘60s-to-early-‘70s at that time. In our informal meetings, he’d have a problem with discrimination, which is common for older folks. In this case, discrimination is the term for being able to listen to someone and understand him while others are talking at the same time.  This was especially noticeable in a crowded restaurant.
However, before I tell you my main point, you need to know one more thing:
It’s REALLY LOUD on stage with a full orchestra when it’s playing power music. I once went out onstage while doing a test recording during a dress rehearsal for Gustav Holst’s The Planets. As luck would have it, it was during “Uranus,” one of the loudest sections.
I had measured the peak sound pressure levels in the audience. I knew they were at least 95 dB. But up on stage, standing next to the conductor, with all the brass and percussion wailing away, I was shocked at how loud it was! It felt like my hair was being blown back like that old Maxell tape ad!
Of course, someone who has been exposed to these incredible sound levels for nearly 50 years is most likely to have some significant hearing damage. Add to that the age factor, and this man should have been lucky to hear an ambulance siren!
In spite of his age, and extended exposure to loud sounds, during our listening sessions at my shop, he always picked up on problems, often before the much younger musicians (with theoretically far better hearing capability).
Once, in the middle of a Beethoven Symphony #6 rehearsal, I saw him tell a second violinist several rows back to retune. On more than one occasion in various rehearsals, he’d have to call somebody on a blown entrance when the full orchestra was wailing away!
It always amazed me that he could hear so precisely during the playback sessions and during the rehearsals (and obviously during the performances), especially when he was noticeably affected hearing-wise by noisy people who were talking nearby in a restaurant!
My point is that age, and even exposure to lifelong loud levels, seems not to be the only indicator as to whether a trained listener can still hear. For example, I often sit with younger men and women, teaching them about sound, or just kicking back listening to music. I’m past 60, but I can reliably hear things that they miss entirely.
FWIW – It’s also why I think that middle-aged & older audio reviewers do not need to publish an audiologist’s hearing exam.  What will that tell us, if they can reliably pick up on things that a less experienced younger person (with technically better hearing) cannot?
So don’t worry if you’re past 50. It just means that you’re experienced!
Part Two: The one thing that your system must have to be Musically Satisfying
If Copper had a Controversy Corner, that’s where I would place this tip. But I can’t find it, so I put it here:
In my years of experience in voicing systems to rooms, I’ve found that a system must have a flat-to-slightly-elevated response curve in the critical octave from approximately 192 Hz to 384 Hz. Yes, I said it could be slightly elevated – much preferred over a similar amplitude dip in this critical region.
Of course, if a system covers the area properly, there’s no need to be concerned. But not all do.
In fact, there is a famous loudspeaker manufacturer who routinely has a slight depression in this frequency response for most of its models.  Some audiophiles admire its ‘precision’ while others find the sound musically uninspiring.
As mentioned above, this range is from one-half octave below middle C—(when the scale is 256 Hz)—to one-half octave above it. Therefore, the area between approximately 192 Hz and 384 Hz is the musical octave in question.
When a speaker (or electronic component or cable) seems to be lean in this area, the sound will usually prove to be boring musically. Amazingly, components that are lean in this area are often admiringly described as highly resolved, precise, articulate, etc. My description? BORING…
But when this region is either flat, or perhaps even elevated by a very slight amount, the music is infinitely more involving. Strings have more body. Brass will have more “weight,” and a more “burnished” tone.
Orchestral music will have a balance (and subjective power response) more akin to live sound in a concert hall
Vocals will have much more palpable presence. That “reach out and touch it” impression.
The sound will be lusher. Guitars will ring out with a beauty that almost touches your soul. In short, you’ll find yourself affected by the music.
Aside from addressing smooth bass in the 25–300 Hz region, this octave is probably the most important frequency response area that a component or system must get right for ultimate satisfaction (a big IMO goes here, of course). For example, if a system is exceptionally detailed or has powerful bass, but it doesn’t get this octave right, it’ll be fatiguing to listen to over a period of time.
Other than checking bass performance in the “boundary dependent region,” this is the only other instance where I might recommend using a Real Time Analyzer. If you suspect a slight problem, it’s often useful to determine if perhaps there’s a subtle dip in response in this frequency range at your listening seat.
If so, I’d experiment with seating position, or maybe speaker positioning. A slight reduction in stereo separation can often add the needed touch-up to offset system problems in this area.
My ultimate—long term—recommendation would be to replace any components that fall into this category. But I’d wait until virtually everything else related to voicing the system to the room has been done. You wouldn’t want to arrive at a wrong conclusion, needlessly spending money on a new amplifier, and still find a similar problem.
I’ve observed this phenomenon for many years. I wish I could tell you why it’s so, but I don’t know. I just know it is. For me, it’s foundational for ultimate musical satisfaction.
I have often thought that if I were a designer of electronics, I might even consider introducing about a 0.25 dB–0.50 dB gentle rise in the frequency response for this octave. Especially for those precise (but thin) sounding electronics out there (you know who they are).
Seriously!
These comments are edited & excerpted from Get Better Sound, and used with the author’s permission. 🙂
You can also read Jim’s work at his website, www.getbettersound.com .
More from Issue 37
View All Articles in Issue 37
#231 Piano Prodigy Jude Kofie Releases His Debut Album On Octave Records by Frank Doris Jun 01, 2026 #231 Underappreciated Artists, Part Two: City Boy by Rich Isaacs Jun 01, 2026 #231 Music and the Art of Creation: Talking With Saxophonist Rob Scheps by Joe Caplan Jun 01, 2026 #231 How to Play in a Rock Band, 24: Further Adventures at the 2026 Montauk Music Festival by Frank Doris Jun 01, 2026 #231 Courtney Barnett: Creature of Habit by Wayne Robins Jun 01, 2026 #231 Angine de Poitrine: Interstellar Guitar Rock Saviors Headed for Late-Night TV Pop Stardom? by Mark Lepage Jun 01, 2026 #231 My Impressions of AXPONA 2026, Part One by Frank Doris Jun 01, 2026 #231 2026 La Jolla Concours d'Elegance: Another Aesthetic Feast by B. Jan Montana Jun 01, 2026 #231 Country Music Icon Jo Dee Messina’s Bridges: A New Beginning by Ray Chelstowski Jun 01, 2026 #231 The Luxury Dispatch Hosts a Video Podcast With Ken Kessler by Ken Kessler Jun 01, 2026 #231 The Vinyl Beat: Tracking in the Motor City by Rudy Radelic Jun 01, 2026 #231 Lots of Fun With DSP: The Ferrum Audio WANDLA DAC and Its Tube Mode by Frank Doris Jun 01, 2026 #231 From The Audiophile's Guide: Digital Source Components and Streaming Audio by Paul McGowan Jun 01, 2026 #231 Onkyo’s Monster M-510 power amplifier by The Staff at Just Audio Jun 01, 2026 #231 PS Audio in the News by PS Audio Staff Jun 01, 2026 #231 Naming Convention by Peter Xeni Jun 01, 2026 #231 Les Invisibles by Frank Doris Jun 01, 2026 #231 Wildlife Scene by James Schrimpf Jun 01, 2026 #230 Camaraderie by B. Jan Montana May 04, 2026 #230 AXPONA 2026: A Family Gathering by Paul McGowan May 04, 2026 #230 Pianist Ryan Benthall Explores Jazz Realms and Far Beyond With Divine Sky by Frank Doris May 04, 2026 #230 The Vinyl Beat in AXPONA-Land by Rudy Radelic May 04, 2026 #230 Teddy Thompson’s Musical Growth Deepens With Never Be the Same by Ray Chelstowski May 04, 2026 #230 More Fun in the Sun: Florida Audio Expo, Part Two by Frank Doris May 04, 2026 #230 CanJam NYC 2026 Show Report: Heady Sound, Part Two by Frank Doris and Harris Fogel May 04, 2026 #230 Sonic Youth On Murray Street by Wayne Robins May 04, 2026 #230 Graffeo Coffee: A Symphony of Sensory Experience by Joe Caplan May 04, 2026 #230 The Saul Authority: The Story of Hi-Fi Pioneer Saul Marantz by Olivier Meunier-Plante May 04, 2026 #230 How to Play in a Rock Band, 23: Encounters With Famous Musicians, Part Two by Frank Doris May 04, 2026 #230 An Outlier in the Rack: A Vintage BIC Beam Box by The Staff at Just Audio May 04, 2026 #230 PS Audio in the News by PS Audio Staff May 04, 2026 #230 A Cautionary Tale by Rich Isaacs May 04, 2026 #230 Reel-to-Reel Roots, Part 33 (Revised): Ken Kessler Reports On the 2026 (British) AudioJumble by Ken Kessler May 04, 2026 #230 Text Messaging by Frank Doris May 04, 2026 #230 The Audiophile Rat Race by Peter Xeni May 04, 2026 #230 On the Rocks by Rich Isaacs May 04, 2026 #229 The Earliest Stars of Country Music, Part Three by Jeff Weiner Apr 06, 2026 #229 The Healing Power of Music and Sound at the Omega Institute by Joe Caplan Apr 06, 2026 #229 CanJam NYC 2026 Show Report: Heady Sound, Part One by Frank Doris Apr 06, 2026 #229 Florida Audio Expo 2026: Warming Up to High-End Audio, Part One by Frank Doris Apr 06, 2026 #229 Quick Takes: Anne Bisson, Sam Morrison, The Velvet Underground, and the Stooges by Frank Doris Apr 06, 2026 #229 The Vinyl Beat: New Arrivals, and Old Audio Show Demo Scores to Settle by Rudy Radelic Apr 06, 2026 #229 Harvard Gets a High-End Audio Education by Frank Doris Apr 06, 2026 #229 No Country for Old Knees by B. Jan Montana Apr 06, 2026 #229 How To Play in A Rock Band, 22: Encounters With Famous Musicians, Part 1 by Frank Doris Apr 06, 2026 #229 The Soulful Grooves of Guinea-Bissau by Steve Kindig Apr 06, 2026 #229 Four-Hand Piano Performance at Its Finest by Stephan Haberthür Apr 06, 2026
Seriously!
