| Physical | |
| Unit Weight | 22.5 lbs [10.2 kg] |
| Unit Dimensions | 17"W x 3"H x 12" D [43.18 cm x 7.62 cm x 30.48 cm] |
| Shipping Weight | 26 lbs [11.8 kg] |
| Shipping Dimensions | 22"W x 8"H x 17"D [55.88 cm x 20.32 cm x 43.18 cm] |
| Color Options | Black Silver |
| Power requirements | |
| Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
| Power Consumption | 25W |
| Digital audio inputs | |
| Inputs | I2S (2), Coax (2), Optical, USB |
| Sample Rates | I2S: 2 inputs - PCM 44.1KHz to 384Khz, DSD64, DSD128, DSD256 Coax: 2 inputs - PCM 44.1KHz - 192KHz Optical: 1 input - PCM 44.1kHZ - 192KHz USB: 1 input - PCM 44.1kHZ - 384KHz - DSD64, DSD128 (native) - DSD64, DSD128 (DoP) |
| Analog Audio Output | |
| Connector | RCA single ended, XLR balanced |
| Output Level High, Maximum | 4 VRMS Balanced 2 VRMS Single Ended |
| Output Impedance | 100Ω / 200Ω |
| Frequency Response | 20Hz-20kHz, +/- 0.1dB 10Hz-55kHz, -1dB |
| Max Output | 4V RMS Balanced, 2V RMS single-ended |
| THD+N @ 1KHz (full scale) | <0.003% at full output |
| IMD | <0.004%, CCIF, at full output |
| SNR | 110dB, referenced to 4V RMS |
| Data Handling | |
| Format | PCM or DSD |
| Sample Rate (PCM) | 44.1kHz, 48.0kHz, 88.2kHz, 96.0kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz |
| Word Length (PCM) | 16-32 bit |
| Data Rate (DSD) | Up to DSD256 (11.2MHz) Native |
| Digital Volume Control | Yes |
| Analog Conversion | ES9018K2M DAC Chip |
| I2S Digital Input | |
| Connector | HDMI |
| Format | PCM or DSD. DoP on all inputs as well as native DSD on |
| USB Digital Input | |
| Connector | USB "B" Type |
| Format | PCM, DoP v1.1 (DSD over PCM), or Native DSD |
| Transfer Mode | Asynchronous |
Stellar DAC - Factory Certified
Note:
Design
Applications
Overview
The DAC
An inside look
Features
13 key featuresCLASS A BALANCED ANALOG OUTPUT STAGE
FULL FUNCTION DAC
FIXED OR VARIABLE DAC MODE
HYBRID DESIGN
BALANCED XLR OUTPUT
DIGITAL LENS TECHNOLOGY
THREE SELECTABLE DIGITAL FILTERS
CPLD (FPGA) INPUT
HIGH-CURRENT OVERSIZED ANALOG POWER SUPPLY
LATEST ESS HYPERSTREAM
NO CAPACITORS IN OUTPUT SIGNAL PATH
SINGLE AND DOUBLE RATE DSD
DSD DIRECT THROUGH I2S
Reviews
0 reviewsNo reviews yet for this product.
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
