Physical |
| Unit Weight | 2.9 lbs [1.3 kg] |
| Unit Dimensions | Width 6.2", Height 1.9", Depth 8.2" (chassis only, not including knobs) or 9.2” (including connectors and knobs) |
| Shipping Weight | 5lbs [2.2 kg] |
| Shipping Dimensions | Width 10.5", Height 5", Depth 14" |
Power requirements |
| Voltage Options | 100-240 VAC, 50-60Hz, Auto-Detect |
| Power Consumption | 280W Maximum |
| Mains Power Input | IEC C14 |
Phono Audio Input |
| Connector | 1 Stereo Pair, Phono RCA |
| Cartridge type | Moving Magnet |
| Cartridge Output | 3mV-10mV (5mV recommended) |
| Cartridge Loading | 47KΩ (100pF) |
| EQ Type | RIAA |
| Gain | +40dB |
| S/N ratio | >84dB A-weighted (analog output) |
Analog Audio Inputs |
| Connector | 1 Stereo Pair, Line Level RCA |
| Maximum Input level | 2.1VRMS (+6.44dBV) |
| Input impedance | 10KΩ |
Analog Audio Output |
| Output level, maximum | 3.0VRMS (+9.5dBV) |
| Output Max Gain (using Analog Inputs) | 8.45dB |
| S/N ratio | >105dB (3VRMS ref) |
| THD (Analog) | <0.01% (1VRMS, 1KHz) |
S/PDIF Digital Input |
| Connector | Optical (Toslink) |
| Format | PCM (96KHz max), 24 bits |
USB Input |
| Connector | USB “B” Type |
| Format | PCM (384KHz max), 24 bits, DSD64 (DoP), DSD128 (DoP) |
| Transfer mode | Asynchronous |
Bluetooth |
| Antenna | Built in |
| DAC | Uses Sprout's built in asynchronous DAC over S/PDIF (ESS Sabre 9016 DAC) |
Stereo Power Amplifier Output |
| 8Ω loudspeakers connected | 50 watts per channel, both channels driven |
| 4Ω loudspeakers connected | 100 watts per channel, both channels driven |
| THD (Speaker Output) | <0.01% (1W, 1KHz into 4Ω) |
| Frequency Response | +/- 1dB (1VRMS out, 20Hz – 20Khz into 4-8Ω) |
| Signal to Noise | >100dB at max power into 4Ω |
Headphone Output |
| 32Ω headphones connected | 500mW |
| 300Ω headphones connected | 125mW |
| THD | <0.01% (1KHz, 50mW into 32 Ω) |
| Signal to Noise | >105dB at max power into 300Ω |
Sprout100 - Factory Certified
Note:
Design
Applications
Overview
Inputs
Power
Features
23 key featuresFULL FEATURED INTEGRATED AMP
100 WATTS PER CHANNEL POWER AMP
DRIVES ANY SIZED LOUD SPEAKER
ALUMINUM REMOTE CONTROL
RCA ANALOG INPUTS
DAC SUPPORTS 384/24 OR DOUBLE RATE DSD
PASSIVE EQ MOVING MAGNET PHONO PREAMP
LOW OUTPUT HEADPHONE AMP
TOSLINK DIGITAL INPUT
USB INPUT
BUILT-IN BLUETOOTH RECEIVER
MANUAL INPUT SELECTOR
32Ω: 500mW HEADPHONE OUTPUT
300Ω: 125mW HEADPHONE OUTPUT
OPTIONAL BASS BOOST
SIGNAL TO NOISE RATIO 100dB AT 4Ω
THD <0.01% (1W, 1kHz into 4 ohms)
INDICATOR LIGHT
6ft REGIONAL POWER CORD
4x BANANA ADAPTERS
2x SPROUT DECALS
OWNER'S MANUAL
DIMENSIONS: 6.2″W x 8.2″L x 1.9″H
Reviews
0 reviewsNo reviews yet for this product.
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
