Physical |
| Unit Weight | 30.3 lbs (13.7kg) |
| Unit Dimensions | 14 3/4” x 17 1/2” x 4 3/8” (with feet) 375 mm x 445 mm x 112 mm (with feet) |
| Shipping Weight | 40.5 lbs (18.4 kg) |
| Shipping Dimensions | 20 1/2” x 24” x 10” 521 mm x 610 mm x 254 mm |
| Color Options | Black Silver |
Power Requirements |
| Input Power | 120VAC or 230VAC 50 or 60Hz |
| Power Consumption | 25W |
Media |
| Optical discs | SACD/CD/CD-R/CD-RW/ DVD-R*/-RW*/+R*/+RW* (*Audio data file only) |
| USB Drive | USB Flash Drive with audio files |
| Supported File Formats | MP3/WMA/AAC (~48kHz/320bps) WAV/FLAC/AIFF (~192kHz/24bit) ALAC (~96kHz/24bit) DSD (~5.6MHz) |
Outputs |
| I2S | 1 I2S output for PCM and DSD (raw) |
| Coax | 1 output for PCM and DoP |
| BNC | 2 outputs for PCM and DoP
Use in tandem for double-rate DoP |
| XLR Balanced | 2 outputs for PCM and DoP
PMG Signature SACD Transport
Receive up to $3,000 when you trade in your PerfectWave SACD Transport.
Design
Application
Overview
Galvanic Isolation
DSD Master Layer
Features
18 key featuresSACD/CD/CD-R/CD-RW/DVD-R*/-RW*/+R*/+RW* (*Audio data file only)
PLAYS MP3, WMA, AAC, WAV, FLAC, AIFF, DSD, 2xDSD, AND ALAC FROM DISCS OR USB INPUT
2x BNC (COAX) OUTPUT FOR PCM AND DOP. USE IN TANDEM FOR DOUBLE-RATE DOP
USB DATA INPUT FOR STORED DIGITAL MEDIA
SACS DSD LAYER AVAILABLE THROUGH I2S OUTPUT
ADVANCED DIGITAL LENS TECHNOLOGY
I2S OUTPUT FOR PCM AND DSD (RAW)
2x XLR OUTPUT FOR PCM AND DOP. USE IN TANDEM FOR DOUBLE-RATE DOP
MEMORY PLAYER TRANSPORT
GALVANICALLY ISOLATED OUTPUT STAGE
1x RCA (COAX) OUTPUT FOR PCM AND DOP
LARGE ANALOG POWER SUPPLY
SEPARATE POWER REGULATORS
FPGA SIGNAL PROCESSING
NEAR-FIELD LATCH PLACEMENT
ZERO SETUP, JUST PLUG AND PLAY
CHASSIS WITHIN A CHASSIS FOR THE QUIETEST PERFORMANCE
REMOTE CONTROL
Reviews
2 reviewsI have about 100 hours on the PMG SACD - I2S to MKII. It’s opened up nicely. Vocal/Instruments float solidly in a black background. Voices more natural sounding. Ted Nugent’s Strangle Hold has super Wide sound stage. Nuge’s Gibson Birdland hollow body is growling and nasty as I expected. Tasty for sure. Chuck Mangione’s flugelhorn is smooth with a tad bit of grit. Stanley Clarke’s I want to play for you album is outstanding. PMG SACD blows the PWT away! easily!
I received my Transport yesterday (exquisitely packaged by the way) and got it installed. I am blown away! The debut SACD was Steely Dan’s “Aja” by Analogue Productions and it has never sounded better. Superb product and a very pleased customer!
Read full review →Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
