PMG SIGNATURE PHONO PREAMPLIFIER |
| Unit Weight | 30 lbs / 13.6 kg |
| Unit Dimensions |
14 3/4” x 17 1/2” x 4 3/8” (with feet) |
| Shipping Weight | 34 lbs (15.4 kg) |
| Shipping Dimensions |
20 1/2” x 24” x 10” |
| Color Options | Black Silver |
| Voltage Options (Factory set only) |
Auto Voltage: 120VAC or 230VAC 50 or 60Hz |
| Fuses | 120V: T250V-1.6AH (1.6A Slow Blow) 230V: T250V-1AH (1A Slow Blow) |
| Accessories Included | US (NEMA 5-15P) (100V/120V versions) Schuko (CEE7/7) (230V version) UK (BS1363) (230V version) Remote Control |
| Audio Inputs |
MM or MC: XLR or RCA |
| Audio Outputs | RCA (Unbalanced) 1 Stereo Pair XLR (Balanced) 1 Stereo Pair |
| DC Trigger |
Input: 3.5mm (2) 5-15VDC |
Performance |
All measurements are with both channels operating, gain set to low, and balanced outputs. Input frequency is 1kHz. |
| Input Loading | 47K, 1K, 470, 320, 200, 140, 100, 67, 40, 30, 16, 12 |
PMG Signature · Phono preamplifier
PMG Signature Phono Preamplifier
Our finest phono preamplifier in the company's 50-year history.
$8,999
Receive up to $3,000 when you trade in your Stellar Phono.
Options
Coming soon
Leave your email and we'll let you know the moment it's available.
Buy or audition near you
All dealersExclusive 60-day in-home trial
The Gold Home Experience
Live with it in your own room for 60 days. If it isn't right, you get a full refund and return shipping is on us.
How it works
- Zero risk. Full refund guaranteed.
- Full experience. Plenty of time for proper setup and break-in.
- Total comfort. Decide from the best seat in the house.
- Outside the US? Find your local dealer
Designed for a reference turntable and cartridge
- Connections Two tonearm inputs, balanced XLR output
- Cartridges Moving magnet and moving coil, fixed and variable loading
- Circuit Zero feedback, Class A, Diamond buffers
- Gain 70 dB, for cartridges down to 0.15 mV
Why choose it
The most from a great cartridge
Choose it if you own a high-end moving-coil cartridge. Its transimpedance input is built for moving-coil, with zero feedback from input to output.
Where it fits
The PMG Signature Phono Preamplifier is the ultimate companion to the finest tonearms, cartridges, and turntables in the world. Designed as a true reference component, it redefines what’s possible in analog playback—delivering unmatched transparency, explosive dynamics, and a vanishingly low noise floor. Whether you're using a low-output moving coil or a high-output moving magnet cartridge, the PMG Signature brings out the full character of your setup with effortlessness and authority.
Read more
Its revolutionary transimpedance input gives cartridges a direct, uncolored path to amplification, eliminating loading concerns and revealing detail, texture, and space that conventional designs leave behind. For a more traditional approach, the voltage input offers adjustable gain and loading, all controlled remotely—so you can fine-tune your system from the listening chair.
With dual inputs for two tonearms, fully discrete zero-feedback circuitry, and precision control at every stage, the PMG Signature is not just another phono preamp—it’s the current state of the art, regardless of price. Use it in the highest-end analog systems on the planet and experience what’s been hiding in your vinyl all along. This is a revolution in analog performance.
Design
How it's built
Phono preamplifiers—even at the highest levels—are often compromised by cost-cutting decisions: integrated circuits, shared power supplies, limited headroom, and simplified signal paths. The PMG Signature Phono Preamplifier throws all of that out the window.
Read the full design story
Phono preamplifiers—even at the highest levels—are often compromised by cost-cutting decisions: integrated circuits, shared power supplies, limited headroom, and simplified signal paths. The PMG Signature Phono Preamplifier throws all of that out the window. From the beginning, this was a no-compromise design, built with a singular goal: to create the finest phono stage in the world, regardless of price.
There’s not a single op-amp or integrated circuit in the signal path. Instead, every stage is constructed from hand-selected, discrete FETs and BJTs, operating in pure Class A. The topology is fully complementary and direct-coupled—chosen not for cost, but for its ability to deliver the lowest distortion, the highest resolution, and a complete absence of sonic fingerprint. The result is astonishing headroom, ultra-low noise, and lightning-fast transient response, capable of reproducing the most delicate nuances and the most explosive dynamics with equal ease.
While not inexpensive, the PMG Signature Phono Preamplifier is built to stand the test of time and stands head and shoulders above anything else we—or anyone—have ever built. If you're ready to hear just how far vinyl playback can truly go, you're ready for the PMG Signature.
- 70 dB
- of ultra-low-noise gain
- 0.15 mV
- cartridges supported
- 2
- tonearm inputs
Features
At a glance
- Class A balanced analog output stage
- Zero feedback folded cascodes
- Fixed and variable loading
- Balanced XLR output
- 70 dB of ultra-low-noise gain, for cartridges down to 0.15 mV
- Two inputs, for two tonearms
- Transimpedance input
- High-current oversized analog power supply
- Discrete FET design
- No capacitors in output signal path
- Class A analog circuitry
- Diamond buffers throughout
Specifications
Full specifications
| PMG SIGNATURE PHONO PREAMPLIFIER | |
| Unit Dimensions | 14 3/4” x 17 1/2” x 4 3/8” (with feet) 375 mm x 445 mm x 112 mm (with feet) |
| Shipping Dimensions | 20 1/2” x 24” x 10” 521 mm x 610 mm x 254 mm |
| Voltage Options (Factory set only) | Auto Voltage: 120VAC or 230VAC 50 or 60Hz |
| Audio Inputs | MM or MC: XLR or RCA TZ: XLR or RCA |
| DC Trigger | Input: 3.5mm (2) 5-15VDC |
| Performance | All measurements are with both channels operating, gain set to low, and balanced outputs. Input frequency is 1kHz. |
Compare
How it compares
| PMG Preamp | StellarGold Pre | PMG PhonoThis one | Stellar Phono | |
| Price | $8,999 | $3,999 | $8,999 | $2,999 |
| Connections | Balanced XLR inputs and output | 4 XLR and 4 RCA inputs, XLR and RCA outputs | Two tonearm inputs, balanced XLR output | Two tonearm inputs, balanced and single-ended |
| Volume | Precision stepped attenuator | Precision stepped attenuator, with balance | — | — |
| Circuit | Pure Class A, zero-feedback Diamond buffers | Class A, fully balanced, discrete | Zero feedback, Class A, Diamond buffers | All analog, discrete FET, Class A |
| Family | PMG Signature, designed by Darren Myers | Stellar, designed by Darren Myers | — | — |
| Cartridges | — | — | Moving magnet and moving coil, fixed and variable loading | Moving magnet and moving coil, adjustable loading |
| Gain | — | — | 70 dB, for cartridges down to 0.15 mV | Up to 70 dB, for cartridges down to 0.15 mV |
Build your system
What it pairs with
Trade Up and Save
Receive up to $3,000 for your Stellar Phono
Your old gear is worth more than you think. PS Audio credits the full original retail value of what you trade, up to the limit, straight off your new purchase.
- Tell us what you have. Press Start your trade-in and list your gear. Nearly any working hi-fi component counts, from any brand.
- Pay the adjusted price. At checkout you are charged only the price after your credit. Our sales team reviews every trade within 48 hours.
- Send yours back. We email a return label number. You have 30 days to ship your trade.
The fine print
What we accept. Nearly any hi-fi make and model at component level: a preamplifier, power amplifier, DAC, phono stage, loudspeaker pair, turntable, headphones or CD transport. It must work and be in respectable cosmetic condition.
What we don't. Broken or non-working products, and most accessories, phono cartridges, power cables and interconnects. Exceptions can be made based on value.
Several items? Yes. Trade as many as you like, up to the credit cap. Use "Add another" on the Trade Up form.
Not sure it qualifies? Call 800-PSAUDIO (800-772-8346) or email sales@psaudio.com, and a real person will answer.
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialistOutside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Find your local dealerHear it in your own room
$8,999
- 60-day in-home trialThe Gold Home Experience. Return shipping is on us.
- Receive up to $3,000 when you trade in your Stellar PhonoCredit comes off the price at checkout.
Release date TBD.
Preamplifier
At home
Where it disappears into the music.
Overview
A revolutionary new design
An inside look
Trade up to it
You do not have to have bought from us before, and it does not have to be ours. Trade in almost any component from any brand and we credit its full original retail value against this one — up to a per-component cap that appears the moment you start a trade. See what yours is worth.
Hear it first
This piece comes with a 60-day in-home trial, with return shipping on us.
Not for sale
We build these in Boulder, Colorado, and we are glad to show our work. Paul answers questions on video most weekdays, and the factory is open to visitors.
Design
Application
Overview
An inside look
Features
12 key featuresCLASS A BALANCED ANALOG OUTPUT STAGE
ZERO FEEDBACK FOLDED CASCODES
FIXED AND VARIABLE LOADING
BALANCED XLR OUTPUT
70dB ULTRA LOW NOISE GAIN .15mv CARTRIDGES
2x INPUTS FOR 2x TONEARMS
TRANSIMPEDANCE INPUT
HIGH-CURRENT OVERSIZED ANALOG POWER SUPPLY
DISCRETE FET DESIGN
NO CAPACITORS IN OUTPUT SIGNAL PATH
CLASS 'A' ANALOG CIRCUITRY
DIAMOND BUFFERS THROUGHOUT
Reviews
0 reviewsNo reviews yet for this product.
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
