Skip to product information
PMG Signature 512 DAC
href="/products/pmg-signature-512-dac?variant=49805279887650" class="link" >PMG Signature 512 DAC
<strong>Meet the all new PMG Signature 512 DAC powered by PureStream DSD.</strong>
Digital audio was born in 1982 with the launch of the first CD player, and PS Audio didn’t miss a beat—we introduced the world’s first high-performance standalone D-to-A converter and never looked back.
Now, after decades of innovation, we proudly unveil the PMG Signature 512 DAC.
At its core is the PureStream DSD512 engine, converting any form of digital audio into a pure 8X DSD stream—no PCM, no decimation, no compromise. That stream feeds our SpectraWave 64-Tap Sequencer, lowering noise and distortion while perfectly time-aligning the signal. From there, it flows into a state-of-the-art, direct-coupled analog output stage.
The result is breathtaking—fluid, natural, and as analog as it gets. With a built-in high-end streamer for seamless access to your music, the 512 is our best DAC ever.
For the first time in PS Audio’s history, our founder’s name graces a DAC. Yes, it’s that good. And this time, it’s personal.
$8,999.00
Design
Designing the PMG Signature 512 DAC was never about meeting expectations—it was about redefining what a digital source could be. This is a radical departure not only from traditional PCM-based architectures but also from conventional DSD implementations and off-the-shelf chip solutions. At its core is our all-new PureStream DSD512 engine, a proprietary design that upsamples every input—PCM or DSD—to a native 8X DSD stream. That stream is then refined by our SpectraWave 64-Tap Sequencer, a precision digital filter engineered to eliminate jitter, reduce noise, and preserve every nuance of the music. The result is pure sonic truth, passed into a fully balanced, direct-coupled analog output stage. With galvanically isolated inputs, a built-in high-performance streamer, and precision analog volume control, the PMG 512 is not just a DAC—it’s the heart of a no-compromise reference system.
Application
The PMG Signature 512 DAC is as versatile as it is revolutionary—and a major step above even the finest DACs we’ve ever built. Use it as a standalone directly into your power amplifier, thanks to its ultra-precise analog volume control, and experience purity, dynamics, and realism like never before. At its heart is PS Audio’s latest high-definition streaming module, fully galvanically isolated to eliminate noise and preserve absolute musical integrity. Whether paired with the PMG Signature Preamplifier for the ultimate reference system or run solo into your amp, the 512 delivers sound that is breathtakingly clear, natural, and alive. This isn’t just high-end performance. This is a whole new benchmark. The PMG Signature 512 DAC is music, uncompromised.
Overview
Think of the PMG Signature 512 DAC as the ultimate destination in digital audio—a no-compromise centerpiece for the most revealing high-performance systems. Whether your setup is purely digital or a hybrid of analog and digital sources, the 512 redefines what’s possible from a DAC. Built around our PureStream DSD512 engine and SpectraWave 64-Tap Sequencer, and featuring a fully balanced, direct-coupled analog output stage, the PMG 512 delivers sound with breathtaking realism, depth, and musicality. It supports I²S for a perfect connection to our top transport, and includes a world-class galvanically isolated streamer. Replace your DAC, your streamer—or even your preamplifier—and prepare to be stunned by the transformation. Rich. Pure. Effortless. The PMG Signature 512 DAC is the product of over fifty years of innovation and the first to carry the name of our founder. It’s not just the best DAC we’ve ever built—it’s the best DAC we know how to imagine.
At the heart of the PMG Signature 512 DAC is a breakthrough in digital audio: our PureStream DSD512 engine. Architected by engineer Doug Goldberg and realized through the exacting execution of chief engineer Bob Stadtherr, PureStream runs at a blazing 22MHz, upsampling any incoming PCM or DSD signal to a native 8X DSD stream—far beyond standard formats and completely free from PCM conversion or decimation.
This ultra-high-resolution DSD stream is then passed through our SpectraWave 64-Tap Sequencer, which time-aligns and refines the signal with surgical precision, lowering noise and distortion while preserving every musical nuance. From there, it flows directly into a simple, elegant analog low-pass filter—no complex conversion stages, just pure music.
The PMG Signature 512 doesn’t rely on off-the-shelf DAC chips. This is a custom-designed platform built from the ground up to achieve what no other DAC has: sonic transparency with SINAD better than -100dB and vanishingly low output noise. Multiple ultra-stable reclocking circuits, galvanic isolation between all digital inputs, and full separation between digital and analog sections ensure jitter-free, noise-immune performance.
And yes, the PMG Signature 512 also features our renowned Digital Lens technology, ensuring that incoming digital data is perfectly reorganized and reclocked before ever reaching the PureStream engine. Every effort in its design—from input to output—is focused on preserving imaging, tonal richness, and musical truth.
One listen, and you’ll know: this is unlike anything you’ve heard before.
The PMG Signature 512 DAC is not just a component—it’s a revolution in digital audio.
An inside look
The SpectraWave 64-Tap Sequencer is a groundbreaking solution within the PMG Signature 512 DAC—unlike anything used in traditional digital filters. Conceived and architected by engineer Doug Goldberg, and brought to life through the meticulous execution of chief engineer Bob Stadtherr, SpectraWave represents a fundamental rethinking of how digital audio should be handled.
Engineered as a fully discrete, patent-pending FIR architecture, SpectraWave operates at the same extreme 22MHz sample rate as our PureStream DSD512 engine. Designed from the ground up to handle ultra-high-speed data streams, its 64 precisely tuned taps work in real time to align musical transients with absolute accuracy, ensuring perfect phase coherence and eliminating timing smear.
Where typical filters introduce artifacts like pre-ringing or harmonic distortion, SpectraWave maintains the purity of the signal without compromise. It preserves the natural shape and timing of every note, creating a spacious, uncolored soundstage with lifelike presence. Instruments bloom into three-dimensional space. Transients arrive exactly when they should. Nothing is exaggerated. Nothing is lost.
Following the sequencer, the signal flows seamlessly into the PMG Signature’s fully balanced, direct-coupled analog output stage. This minimal-feedback circuit—carefully refined by Bob Stadtherr for speed, transparency, and control—features ultra-low output impedance and high current drive, effortlessly powering even the most demanding downstream components. There are no transformers, no coloration, and no filters to blur the truth—just a clean, open window into the soul of the music.
This isn’t just a better DAC.
It’s a complete rethinking of what digital audio can be—from inspired architecture to uncompromising execution.
Features
13 key features
CLASS A BALANCED ANALOG OUTPUT STAGE
FULL FUNCTION DAC
FIXED OR VARIABLE DAC MODE
ANALOG VOLUME CONTROL
BALANCED XLR OUTPUT
DIGITAL LENS TECHNOLOGY
PURESTREAM DSD 8X ENGINE
SPECTRAWAVE 64-TAP SEQUENCER
HIGH-CURRENT OVERSIZED ANALOG POWER SUPPLY
SINAD EXCEEDING -100DB
NO TRANSFORMER IN OUTPUT SIGNAL PATH
QUAD RATE DSD
DSD DIRECT THROUGH I2S
Reviews
8 reviews
Jay's Iyagi - Youtube
Whether I play poorly recorded music or really well recorded music, the musicality enhancement is quite real.
Read full review →
Lowell G
But the resolution that I am now able to hear without effort is more than mind-bending. You and your team have knocked this one out of the park! I am hearing acoustic environments and timbres that I was simply not aware of.
Jonathan
"I was awestruck. Stability, imaging, clarity, soundstage width and depth, silence between notes, dynamic range, bass reproduction, and "musicality" were consistently outstanding. I own a very good DAC -- the ****** Designs' M21. I would say the new PS Audio PMG DAC is at least its match and perhaps even its better. Bottom line: if you are in the market for a new DAC , you must seriously consider the PS Audio PMG DAC
Flenser55
Maybe flabbergasted is too strong a word to describe what I heard, but I think it’ll do. There are no nuances. Everything is obvious, and better, and not in a small way. Instruments are precisely placed, not only across the soundstage but also front-to-back. I didn’t realize my DSD was smearing the size and placement and the actual sound of the sound until I heard the same pieces via the PMG. It’s as though there was always cloud of chaff, but I never noticed it until it was gone.
Dr. Pain
Vocals on the PMG 512 were clearer, more defined in space, and even more natural and human in tone and presence. Cymbals were less smeared, more refined and delicate, the soundstage was wider and dimensional. Now, despite my old man hearing, I can hear more distinct, intelligible vocals. The background singers and instruments that I previously had strained to hear. It has been very rewarding listening to the new PMG series.
Denny
I am using the PMG dac without a preamp, couldn’t do that with the MKII. The upgrade is fantastic. Go with the dac.
Chris
Chris
I am simply amazed at how much the PMG 512 DAC contributes to the wondrous gestalt of my system. I hadn’t realized just how capably and synergistically these components could function as a whole without having had a musical source as extraordinary, to me, as this DAC. I don’t need new speakers, or new amplification, or new cables, because now I know what my system had been missing.
Want to leave your own review?
Specifications
Technical details
Physical
Unit Weight 30.3 lbs [13.61 kg]
Unit Dimensions 14 3/4” x 17 1/2” x 4 3/8” (with feet)
375 mm x 445 mm x 112 mm (with feet)
Shipping Weight 40.3 lbs [18.3 kg]
Shipping Dimensions 20 1/2” x 24” x 10”
521 mm x 610 mm x 254 mm
Color Options Black
Silver
Power requirements
Input Power Auto Voltage: 120VAC or 230VAC 50 or 60Hz
Power Consumption 30W
Digital audio inputs
Inputs I2S (2), Coax (2), XLR Balanced (2), Optical, USB
Sample Rates Optical (TOSLink): PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz and 96kHz
S/PDIF (Coax and XLR): PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz and 192kHz; DoP64
I2S:  PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256
USB:  PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256.
Analog Audio Output
Connector RCA single ended or balanced, XLR balanced
Output Level High, Maximum 4 VRMS Balanced
2 VRMS Single Ended
Output Impedance < 100Ω / 200Ω
Frequency Response 20-20KHz +/- 0.25dB
THD+N @ 1KHz (full scale)
<0.001%
Output Stage High-speed op-amp with discrete buffers.
Data Handling
Format PCM or DSD
PCM Input
Up to 768KHz 32 bits
DSD Input Up to DSD512
DSD Output DSD128, DSD256, DSD512 (user selectable)
Analog Conversion method 64-bit FIR filter to low pass analog filter
I2S Digital Input
Connector HDMI
Format PCM or DSD. DoP on all inputs as well as raw DSD on I2S inputs
USB Digital Input
Connector USB "B" Type
Format PCM, DoP v1.1 (DSD over PCM), or Native DSD
Transfer Mode Asynchronous
Streamer
Connectivity
Roon Ready
Tidal via Roon
Qobuz Connect
Spotify Premium
DLNA/UPnP
ShairPort
Network Support
WiFi: IEEE 802.11 b/g/n/ac (2.4 & 5GHz dual band)
10/100/1000 Ethernet
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
