| Unit Weight | 56.2 lbs / 25.5 kg |
| Unit Dimensions | 16 in L × 17.5 in W × 8 in H (406.4 × 444.5 × 203.2 mm) With feet & binding posts: 16.75 in L × 17.5 in W × 8.75 in H |
| Shipping Weight | 68 lbs |
| Shipping Dimensions | 23.5 × 23 × 15 in / 596.9 × 584.2 × 381 mm |
| Input Power | Auto Voltage: 120VAC or 230VAC, 50 or 60 Hz |
| Power Consumption | Standby (Ready): <2W | Idle: 180W | 25W/4Ω: 360W |
| Fuses | No user serviceable fuses |
| Audio Inputs | RCA (Single-ended): 1 pair | XLR (Balanced): 1 pair |
| Speaker Outputs | Silver Plated Binding Posts: 4 pair |
| Trigger | Input: 3.5mm, 5–15VDC | Output: 3.5mm, 12VDC |
| Gain | 26.2 dB |
| Sensitivity | 1.4V |
| Power Output | 100W/ch into 8Ω, 200W/ch into 4Ω (1kHz, <1% THD) |
| Class A Power Output | 10W/ch into 8Ω |
| Frequency Response | <10Hz – 80kHz (±0.25dB) |
| Input Impedance | 100kΩ Single-ended | 200kΩ Balanced |
| Bandwidth | >500kHz |
| THD | <0.002% typical (20Hz–20kHz, 1W/8Ω) |
| Damping Factor | >240 at 8Ω (20Hz–1kHz) |
| Crosstalk | >90dB at 1kHz |
Call: 1-800-PSAUDIO (772-8346)
Email: support@psaudio.com
Hours: Monday–Friday, 8:30 AM to 5 PM (MST)
