Physical |
| Unit Weight | 13.5 lbs [6.1 kg] |
| Unit Dimensions | 17” x 12” x 3” |
| Shipping Weight | 17 lbs [7.7 kg] |
| Shipping Dimensions | 23”x 18” x 9” |
Power requirements |
| Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
| Power Consumption | 20W |
| Mains Power Input | IEC C14 |
| Fuses | 100V T250V-2.0AH (2A Slow Blow) 120V T250V-1.6AH (1.6A Slow Blow) 230V T250V-1.0AH (1.0A Slow Blow) |
| Accessories included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS1363) (230V version) |
Analog inputs |
| RCA XLR |
3 stereo pair 1 stereo pair |
Digital audio inputs |
| I2S | 1 PCM (384KHz max) DSD64 DSD128 Compatible with DirectStream Transport SACD handshake for DSD playback |
| Coax | 2 PCM (192KHz max) |
| Optical | 1 PCM (96KHz max) |
| USB | PCM (384KHz max) DSD64 (DoP) DSD128 (DoP) |
| Format | PCM, DSD |
Analog Audio Outputs |
| RCA XLR Headphones |
(Analog Unbalanced) 1 stereo pair (Analog Balanced) 1 stereo pair One 1/4" headphone connector front panel |
Analog Performance |
| Gain Maximum output Sensitivity |
12dB +/-0.5dB 20 Vrms 5.3Vrms |
| Input Impedance | 47KΩ single ended RCA 100KΩ Balanced XLR |
| Output Impedance | 100Ω single ended RCA 200Ω balanced XLR |
| Frequency Response | 20Hz – 20KHz +0/- 0.25dB 10Hz – 100KHz +0.1/-3.0dB |
| Noise | 20-20KHz <-90dBV |
| S/N Ratio | 1KHz >110dB (max output) |
| Channel separation | 1KHz >90dB |
| Input separation | 1KHz >90dB |
| THD&IM | 1KHz < 0.025% 20-20KHz < 0.05% |
Headphone performance |
| Output power @1% THD | 300Ω 300mW 16Ω 3.25W |
| S/N Ratio 1kHz Noise |
>95dB (max output) <-80dBV |
| THD & IM 1Vrms out | 300Ω <0.05% 16Ω <0.06% |
| Output impedance | <4 Ω |
Features |
| Volume Control | 0-100 (1/2 and 1dB steps, 80dB total range) |
| Balance Control | 24dB each direction in 1/2dB steps |
| Home Theater Mode | Assignable to any analog input Adjustable (in setup) to any level |
| Polarity (phase) Control | Digital sources only |
| Filter Control | 3 selectable digital filters (PCM digital sources only) |
| Trigger output | (3.5mm 5-15VDC) 2 |
| Remote Control | Yes. Infra Red |
GainCell DAC - Factory Certified
Note:
Design
Applications
Overview
The preamp
The DAC
Features
16 key featuresCLASS A BALANCED ANALOG PREAMPLIFIER
FULL FUNCTION DAC
CLASS A HEADPHONE OUTPUT
FIXED OR VARIABLE DAC MODE
ANALOG GAIN CELL STAGE
BALANCED XLR OUTPUT
HOME THEATER BYPASS
DIGITAL LENS TECHNOLOGY
THREE SELECTABLE DIGITAL FILTERS
CPLD (FPGA) INPUT
HIGH-CURRENT OVERSIZED ANALOG POWER SUPPLY
ESS HYPERSTREAM
NO CAPACITORS IN OUTPUT SIGNAL PATH
HIGH CURRENT CLASS A HYBRID OUTPUT STAGE
SINGLE AND DOUBLE RATE DSD
DSD DIRECT THROUGH I2S
Reviews
0 reviewsNo reviews yet for this product.
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
