Foundry · Subwoofer
Foundry F12 Subwoofer
Bass with the authority to move air, and you.
$2,749 / each
Options
Buy or audition near you
All dealers
Exclusive 60-day in-home trial
The Gold Home Experience
Live with it in your own room for 60 days. If it isn't right, you get a full refund and return shipping is on us.
How it works
  • Zero risk. Full refund guaranteed.
  • Full experience. Plenty of time for proper setup and break-in.
  • Total comfort. Decide from the best seat in the house.
Designed for any room, with any speakers
  • Size (H × W × D) 16.75" × 14.75" × 17.5"
  • Weight 77 lb each
  • Deep bass Flat to below 20 Hz in-room
  • Drivers Sealed 12" driver
What owners say
Adding two Foundry F12 subwoofers transformed my system.
SStraightwireOwner · PS Audio forum · 2026
This is the first subwoofer that I owned that is truly musical.
RRichardOwner · PS Audio forum · 2026
The thing that surprised is how the subs affect the highs and mids in a very positive way.
JJoe S.Owner · PS Audio forum · 2026
Why choose it
Fast bass that fits your room
A sealed cabinet and a custom 12-inch long-throw driver keep bass tight, and built-in room EQ tunes it to your space. Flat below 20 Hz in-room, and stackable for more output.
Where it fits
No system is complete without subwoofers. Below 200 Hz, the room—not the speaker—controls what you hear, creating peaks, nulls, and uneven bass. Even the best full-range speakers are placed where bass works worst.
Read more
Properly designed subwoofers are essential. They smooth room response, restore the missing foundation, and allow the entire system to lock into place. When bass is right, timing, scale, and realism return.
The Foundry series was engineered as music-first subwoofers that integrate seamlessly and disappear into the system—whether used singly, in multiples, stacked, wired, or wireless.
A great system doesn’t just play bass. It needs it.
The foundation your system has been missing.
Design
How it's built
Most subwoofers call attention to themselves. Truly musical ones disappear.
Read the full design story
Most subwoofers call attention to themselves. Truly musical ones disappear. When bass is right, you hear only weight, scale, and realism—not the subwoofer.
The Foundry F12 belongs to that rare class. Its custom driver, sealed enclosure, powerful amplification, and advanced DSP work together to deliver deep bass with speed, control, and exceptionally low distortion. Notes start and stop exactly when they should.
Designed to solve the room, the F12 integrates effortlessly into any system and any placement strategy. What you get is not more bass—but better music.
1,000 W
amplifier
12-inch
ultra-long-throw driver
<20 Hz
flat in-room response
01
Overview
Bass is the most misunderstood element in any audio system. Below 200 Hz, the room—not the speaker—controls what you hear, creating peaks, nulls, and uneven bass no speaker can fix alone.
Read more
After decades of experience, we know accurate bass requires a dedicated solution designed to work with real rooms. The Foundry F12 is that solution—delivering fast, controlled, musical low frequencies with the power to disappear into the system while restoring scale and realism.
Why accept compromised bass? Build the foundation your system deserves.
02
The Driver
The heart and soul of any subwoofer is its driver—the transducer responsible for moving air with absolute precision while remaining faithful to the music. For the Foundry F12, it became immediately clear that no off-the-shelf driver could deliver the combination of ultra-low distortion, extreme output, and musical accuracy we demanded.
Read more
The heart and soul of any subwoofer is its driver—the transducer responsible for moving air with absolute precision while remaining faithful to the music. For the Foundry F12, it became immediately clear that no off-the-shelf driver could deliver the combination of ultra-low distortion, extreme output, and musical accuracy we demanded. So we designed our own from the ground up.
At the core of the F12 is a state-of-the-art 12-inch long-throw driver engineered specifically for sealed-box operation and real-room performance. With massive linear excursion capability, the F12 driver moves extraordinary volumes of air while maintaining strict control and linearity across its entire operating range. This is critical: bass is not just about power, but about precision—starting and stopping exactly when the music commands, without overhang, compression, or coloration.
Low distortion was the primary design goal. Using advanced finite element analysis, the motor structure was optimized to maintain a constant magnetic field throughout the driver’s full stroke. Dual shorting rings, an undercut pole piece, and a carefully engineered voice-coil geometry work together to minimize inductance variation and flux modulation—the root causes of distortion in conventional subwoofer drivers. The result is clean, articulate bass that retains texture and pitch even at high output levels.
The cone itself is a custom composite design chosen for its ideal balance of stiffness, internal damping, and low mass, allowing the driver to remain pistonic under extreme demands. A large-diameter Nomex spider and carefully tuned suspension geometry ensure linear mechanical behavior across the driver’s full excursion, preserving musicality even when the F12 is called upon to deliver deep, room-energizing bass.
The result is a driver that does more than produce low frequencies—it conveys the emotion, rhythm, and nuance of the music. Tight and articulate when the recording demands subtlety, powerful and visceral when impact is required, the Foundry F12 driver is engineered to disappear, leaving only the foundation of the performance behind.
03
The Room
Even the finest full-range loudspeakers cannot escape the realities of the listening room. Below roughly 200 Hz, bass behavior is dominated not by the speaker, but by the room itself.
Read more
Even the finest full-range loudspeakers cannot escape the realities of the listening room. Below roughly 200 Hz, bass behavior is dominated not by the speaker, but by the room itself. Standing waves create peaks and nulls that exaggerate some notes while erasing others entirely. Ironically, the physical locations where main speakers must live—placed for imaging, symmetry, and aesthetics—are often the worst possible places for accurate bass reproduction.
This is where subwoofers become essential—not as an add-on, but as a solution. Properly designed and properly placed subwoofers fill in room modes, smooth response, and restore the missing foundation that even large, expensive speakers cannot reliably deliver on their own. When bass is correct, everything above it improves: clarity, timing, scale, and realism.
The Foundry series was created to solve this problem once and for all. Designed from the ground up as music-first subwoofers, Foundry subs integrate seamlessly with full-range speakers, extending their performance while freeing them from the impossible task of fighting room acoustics alone. Whether used as a single sub, a carefully placed pair, or a multi-sub system distributed throughout the room—or even stacked for maximum output—the Foundry series delivers coherent, authoritative bass without latency, smearing, or delay.
Equally important, Foundry subwoofers are designed to work where acoustics demand, not where convenience dictates. Compact, flexible, and available in wired or wireless configurations, they can be positioned strategically around the room to average out peaks and nulls, achieving smooth, natural bass that simply sounds right. No gimmicks. No compromise. Just realism restored.
A classic problem has finally met its match. The room is no longer the enemy—it’s part of the solution.
Features
At a glance
  • Music-first, reference-grade bass
  • Custom 12-inch ultra-long-throw driver
  • Sealed enclosure for fast, accurate transients
  • 1000-watt high-current amplification
  • Extreme linear excursion for low distortion
  • Flat in-room response below 20 hz
  • Advanced dsp with room eq and delay control
  • Multiple input options for any system
  • Wired or wireless integration via wisa
  • Compact footprint for acoustically correct placement
  • Designed for multi-sub configurations
  • Stackable for increased output and headroom
Specifications
Full specifications
Color OptionsSatin White, Satin Black
Enclosure TypeSealed Box
Maximum Output113 dB @ 2m ground plane
Input Impedance50kΩ (RCA), 100kΩ (XLR)
Power Requirements120/230 VAC, 50/60 Hz (auto-sensing)
Idle Consumption40W
Driver Excursion60mm Xmax p-p / 80mm Xmech p-p
Amplifier Power1000W continuous (1800W power supply)
Frequency Response-6 dB @ 20 Hz anechoic (ground plane), flat to below 20 Hz in-room with room gain; ±0.5 dB to 500 Hz
Dimensions (HxWxD)14.75"W × 16.75"H × 17.5"D (18.125" with grille)
Net Weight77 lbs (35 kg)
Shipped Dimensions (HxWxD)17"W x 20"H x 22"D
Shipped Weight83 lbs (37.7 kg)
Compare
How it compares
FR30FR20FR10FR5F12This one
Price$34,999 / pair$22,999 / pair$9,999 / pairFrom $3,499 / pairFrom $2,749 / each
Size (H × W × D)60.5" × 16" × 25.75"50.5" × 16" × 18.75"41.5" × 11.75" × 16.25"14.5" × 8" × 13" (stand 28.25" tall)16.75" × 14.75" × 17.5"
Weight230 lb each133 lb each75 lb each26.6 lb each77 lb each
RoomLarge roomsMedium to large roomsTypical living roomsSmall to medium roomsAny room. Stackable
Deep bassDown to 20 Hz in-roomDown to 20 Hz in-roomDown to 25 Hz in-roomDown to 30 Hz in-roomFlat to below 20 Hz in-room
DriversTwo ribbon tweeters, 10" ribbon midrange, four 8" woofersRibbon tweeter, 10" ribbon midrange, two 8" woofersRibbon tweeter, 8" ribbon midrange, two 6.5" woofersRibbon tweeter, 6.5" wooferSealed 12" driver
Amp power100–600 W50–300 W50–200 W50–150 WBuilt in: 1,000 W
Build your system
What it pairs with
Reviews
More reviews
I'm very happy the Foundry F12.
This is the first subwoofer that I owned that is truly musical. The quality of the unit is top notch. It added so much depth to my music. A definite compliment to my tower speakers.
RRichard2026
100% agree with Chris, the DSP and flexible adjustments on the F12’s are critical.
The new SVS 17 Ultra is highly rated, but it can’t compare with the sound of the F12 and its ability to better match the room which is the main factor in getting the bass to sound right.
KKim Eccles2026
Foundry impressions.
Great look and finish, tight fast bass, one in each diagonal corner is a good start for balancing room modes. The app, with actual delay options and slope changes is a plus. I will be ordering a third F12 today to replace my large SVS...
FForum memberOwner · PS Audio forum · 2026
Read the full post
Soundstage is massive, wall to wall. And imaging is more precise. This is a significant improvement for me. Thanks Chris for great SW.
JJoe S.2026
“Adding two Foundry F12 subwoofers transformed my system.
Properly placed and dialed in, they’re a seamless extension of my main speakers — never drawing attention to themselves, only speaking when asked. The last octave may not hold a lot of notes, but it carries enormous weight and emotion— tighter midbass, clearer placement of...
SStraightwire2026
Questions for a specialist?
We're happy to help with system matching and upgrades. Talk to a real person at 800-PSAUDIO, Monday to Friday, 8:30 to 5 Mountain Time, or email sales@psaudio.com.
Contact a specialist
Outside the US?
Buy or audition through an authorized PS Audio dealer in your country. Can't find one near you? Contact us directly.
Find your local dealer
Hear it in your own room
From $2,749 / each
  • 60-day in-home trialThe Gold Home Experience. Return shipping is on us.
  • Talk to a real person800-PSAUDIO, Monday to Friday.
Add to cart
Skip to product information
href="/products/foundry-f12-subwoofer?variant=50779531804962" class="link" >Foundry F12 Subwoofer
<i>“Bass without compromise—power and precision in perfect balance”</i>
The Foundry series of subwoofers redefines what is possible in low-frequency reproduction. With the introduction of the Foundry F12, reference-grade bass is no longer limited by room size, placement constraints, or compromise. Designed to integrate effortlessly with any high-performance system, the F12 brings true full-range performance to real listening rooms—where physics, not speakers, has always been the limiting factor.
The Foundry F12 represents the culmination of decades of experience in understanding how bass behaves in real spaces; learning why room acoustics dominate below 200 Hz; why most subwoofers sacrifice musicality for output; why ports, shortcuts, and off-the-shelf drivers fail when accuracy matters most. Every element of the F12—from its ultra-linear long-throw driver, to its sealed enclosure, to its high-power amplifier and intelligent DSP—was engineered from the ground up to deliver bass that is fast, controlled, and musically honest. When existing solutions fell short, we designed our own—without compromise.
No longer do you have to choose between power and precision.
Effortless to integrate, breathtaking in its impact, compact enough to place where acoustics demand, and capable of bass that is both visceral and nuanced, the Foundry F12 transforms your system from impressive to complete. Once you hear bass done right, there’s no going back.
$2,749.00
Optional Add-ons
Subwoofer
The bottom octave, back in the room.
Closer looks
Foundry F12 SubwooferFoundry F12 SubwooferFoundry F12 SubwooferFoundry F12 SubwooferFoundry F12 SubwooferFoundry F12 SubwooferFoundry F12 SubwooferFoundry F12 SubwooferFoundry F12 Subwoofer
Overview
The Driver
The Room
Chris Brunhaver on subwoofers
What owners and reviewers say
100% agree with Chris, the DSP and flexible adjustments on the F12’s are critical. The new SVS 17 Ultra is highly rated, but it can’t compare with the sound of the F12 and its ability to better match the room which is the main factor in getting the bass to sound right.
Kim Eccles
Foundry impressions. Great look and finish, tight fast bass, one in each diagonal corner is a good start for balancing room modes. The app, with actual delay options and slope changes is a plus. I will be ordering a third F12 today to replace my large SVS sub which my son has been interested in. ...
Kimeccles - PS Audio Forum · Read full review
The thing that surprised is how the subs affect the highs and mids in a very positive way. Soundstage is massive, wall to wall. And imaging is more precise. This is a significant improvement for me. Thanks Chris for great SW.
Joe S.
“Adding two Foundry F12 subwoofers transformed my system. Properly placed and dialed in, they’re a seamless extension of my main speakers — never drawing attention to themselves, only speaking when asked. The last octave may not hold a lot of notes, but it carries enormous weight and emotion— tig...
Straightwire
I'm very happy the Foundry F12. This is the first subwoofer that I owned that is truly musical. The quality of the unit is top notch. It added so much depth to my music. A definite compliment to my tower speakers.
Richard
Trade up to it
You do not have to have bought from us before, and it does not have to be ours. Trade in almost any component from any brand and we credit its full original retail value against this one — up to a per-component cap that appears the moment you start a trade. See what yours is worth.
Hear it first
Every piece comes with a 30-day in-home trial. PMG Signature pieces get 60 days, with return shipping on us.
Not for sale
The Foundry subwoofer is designed in Boulder, Colorado, and we are glad to show our work.Paul answers questions on video most weekdays, and the factory is open to visitors.
Try it at home $2,749.00
Take it home
Design
Application
Overview
The Driver
The Room
Power and Control
The power amplifier is the engine of a subwoofer, and like any great engine, its job is not simply to produce power—but to deliver it instantly, cleanly, and with absolute control. For the Foundry F12, that meant designing an amplifier capable of lightning-fast response, effortless dynamics, and precise command over every aspect of low-frequency reproduction. A powerful driver is only as good as the amplifier driving it, and the F12’s amplifier was engineered from the ground up to extract every ounce of performance the driver can deliver.
At the core of the F12 is a state-of-the-art 1,000-watt continuous power amplifier backed by a massive 1,800-watt power supply. This generous reserve is not about playing louder—it’s about headroom and authority. Transients in music are brief, sudden, and demanding. Drum strikes, orchestral crescendos, and even the subtle thump of a performer’s foot on a stage floor require instantaneous current delivery. The F12’s oversized power supply ensures the amplifier never starves for energy, allowing it to respond without compression, hesitation, or loss of control.
Speed is critical at low frequencies. Bass that lags behind the music destroys timing and realism. The F12’s amplifier is engineered for exceptional slew rate and current delivery, enabling the woofer to start and stop exactly when the signal commands. The result is bass that is tight, articulate, and rhythmically precise—preserving the snap of a kick drum and the natural decay of low-frequency instruments without overhang or smearing.
Just as important, the amplifier and driver were designed as a unified system governed by powerful, high-resolution DSP. This processing not only manages crossover behavior, but also provides full control over room interaction and tonal balance. From hand-tuned precision adjustments to automatic room measurement and EQ, the F12 gives the listener complete command of bass performance.
All of this power and control is accessed through the Foundry control app for iPhone and Android—one of the most sophisticated subwoofer tuning platforms available today. From fine-grain parametric EQ and delay adjustment to preset management and automatic calibration, the app allows the F12 to be precisely tailored from the listening position, where accuracy matters most.
The result is power that feels effortless and intelligent. The amplifier disappears along with the subwoofer itself, leaving behind bass that is fast, controlled, and emotionally convincing. This is not brute force for its own sake—it is refined power and precision, purpose-built to serve the music.
State of the Art
True musical bass demands more than power—it demands linearity. When a driver’s behavior changes as it moves, distortion replaces music. Notes lose pitch, transients smear, and bass takes on a character of its own. The Foundry F12 was engineered to avoid this entirely, delivering bass that remains clean, symmetrical, and musically honest even under extreme demands.
At the core of the F12’s performance is an ultra-linear motor and suspension system refined through extensive finite element analysis and validated with state-of-the-art Klippel measurement. These tools allow us to examine how motor force, suspension compliance, and voice-coil inductance behave throughout the driver’s full excursion—not just at rest. The F12’s driver remains remarkably linear and symmetrical across its operating range, maintaining consistent control and force as it moves in both directions. This level of linearity is the foundation of the F12’s exceptionally low distortion and natural musical presentation.
Extreme excursion is meaningless without control. The Foundry F12 combines massive linear travel with a precisely engineered suspension and motor structure that prevent compression, asymmetry, and dynamic nonlinearity. As a result, the driver produces deep bass that retains pitch accuracy, texture, and timing—whether reproducing subtle low-level detail or delivering full-scale impact.
What you hear is bass without coloration. No thickening, no overhang, no artificial weight—just clean, articulate low frequencies that integrate seamlessly with the rest of the system. The subwoofer does not call attention to itself because it adds nothing of its own.
This level of performance is the result of a design process typically reserved for the most advanced loudspeakers in the world. The Foundry F12’s measurements do not merely look impressive—they explain why it sounds the way it does. Linearity, symmetry, and control are not academic ideals; they are the reason the F12 disappears and leaves only the music behind.
Extraordinary Performance
This measurement shows the Foundry F12’s frequency response as captured on a Klippel Near-Field Scanner (NFS), one of the most advanced loudspeaker measurement systems available. The horizontal axis represents frequency, spanning from 10 Hz to 1,000 Hz, while the vertical axis shows output level. This measurement was taken with the crossover bypassed to reveal the subwoofer’s native behavior—unfiltered and uncorrected.
What makes this graph exceptional is not just how deep the F12 plays, but how controlled it remains across a very wide frequency range. The response follows a precisely engineered fourth-order alignment below 20 Hz, reaching –6 dB at 20 Hz, and remains smooth and predictable above that point. In practical terms, this means the F12 delivers true deep bass without artificial boosting or resonance, relying instead on natural room gain to produce flat, extended low-frequency response in real listening spaces.
Equally important—and far more rare—is what happens above the subwoofer’s intended operating range. The F12 remains exceptionally well behaved well into the upper bass and beyond. We intentionally show response out to 1,000 Hz because this behavior matters. Subwoofers that become irregular, resonant, or nonlinear above their crossover point are difficult to integrate cleanly. The Foundry F12’s controlled upper-frequency behavior allows it to blend seamlessly with virtually any main speaker and any crossover setting, preserving clarity and timing in the critical upper-bass region where many systems fall apart.
This level of linearity across both low and upper bass is a direct result of the F12’s ultra-linear driver, sealed enclosure, and carefully engineered motor and suspension system. There are no hidden resonances, no abrupt roll-offs, and no unwanted peaks waiting to intrude into the audible range. The response you see here is inherently smooth, requiring minimal correction and preserving musical integrity.
Why does this matter? Because bass is not just about depth—it is about control. When a subwoofer behaves predictably across and beyond its operating range, it integrates invisibly. Notes retain their pitch. Transients remain sharp. The bass foundation supports the music rather than calling attention to itself.
Performance like this is rare because it is difficult to achieve. It requires linear excursion under load, freedom from enclosure artifacts, and a system engineered as a whole. This graph is not just a measurement—it is visual proof of why the Foundry F12 sounds natural, musical, and effortlessly integrated into any serious system.
Features
12 key features
MUSIC-FIRST, REFERENCE-GRADE BASS
CUSTOM 12-INCH ULTRA-LONG-THROW DRIVER
SEALED ENCLOSURE FOR FAST, ACCURATE TRANSIENTS
1000-WATT HIGH-CURRENT AMPLIFICATION
EXTREME LINEAR EXCURSION FOR LOW DISTORTION
FLAT IN-ROOM RESPONSE BELOW 20 HZ
ADVANCED DSP WITH ROOM EQ AND DELAY CONTROL
MULTIPLE INPUT OPTIONS FOR ANY SYSTEM
WIRED OR WIRELESS INTEGRATION VIA WISA
COMPACT FOOTPRINT FOR ACOUSTICALLY CORRECT PLACEMENT
DESIGNED FOR MULTI-SUB CONFIGURATIONS
STACKABLE FOR INCREASED OUTPUT AND HEADROOM
Reviews
5 reviews
Kim Eccles
Foundry impressions. Great look and finish, tight fast bass, one in each diagonal corner is a good start for balancing room modes. The app, with actual delay options and slope changes is a plus. I will be ordering a third F12 today to replace my large SVS sub which my son has been interested in. Three subs really can reduce room modes significantly based on my REW simulations and they will look great.
Read full review →
Joe S.
Straightwire
“Adding two Foundry F12 subwoofers transformed my system. Properly placed and dialed in, they’re a seamless extension of my main speakers — never drawing attention to themselves, only speaking when asked. The last octave may not hold a lot of notes, but it carries enormous weight and emotion— tighter midbass, clearer placement of instruments, and a more immersive soundstage. The F12s don’t just add bass; they complete the system.”
Richard
Richard
Want to leave your own review?
Specifications
Technical details
Color Options Satin White, Satin Black
Enclosure Type Sealed Box
Maximum Output 113 dB @ 2m ground plane
Input Impedance 50kΩ (RCA), 100kΩ (XLR)
Power Requirements 120/230 VAC, 50/60 Hz (auto-sensing)
Idle Consumption 40W
Driver Excursion 60mm Xmax p-p / 80mm Xmech p-p
Amplifier Power 1000W continuous (1800W power supply)
Frequency Response -6 dB @ 20 Hz anechoic (ground plane), flat to below 20 Hz in-room with room gain; ±0.5 dB to 500 Hz
Dimensions (HxWxD)
Net Weight
77 lbs (35 kg)
17"W x 20"H x 22"D
Shipped Weight
83 lbs (37.7 kg)
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
Specifications
Dimensions (HxWxD)
Net Weight
77 lbs (35 kg)
17"W x 20"H x 22"D
Shipped Weight
83 lbs (37.7 kg)
Recommended products
