Skip to product information
Dectet AC Power Conditioner
href="/products/dectet-power-center?variant=43692171755810" class="link" >Dectet AC Power Conditioner
<strong>Power your entire system with the Dectet to clean, protect, and improve.</strong>
The Dectet is an active three zone, ten outlet power center that produces clean, unrestricted AC power for an entire high-end audio or video system. It is designed to power and fully protect your entire system with improved dynamics, increased harmonic integrity, and an open, spacious soundstage that can be breathtaking. Filtration is handled through large core high permeability magnetic devices wound with heavy gauge OFC providing both common mode and differential mode filtering you can both measure and hear. Protection is through both microprocessor controlled over/under voltage surge guard and MOV spike that will always make sure your equipment is fully protected.
Out of Stock
$749.00
Design
Application
Overview
The Dectet AC Power Conditioner is PS Audio's entry-level system power center that will provide protected and perfected AC power to your entire system. All ten receptacles of the Dectet, individually hand wired to the power input, are continually monitored by the device's internal voltage measurement system. Should the incoming voltage exceed 20% or fall 25% below your country's nominal voltage, the Dectet will automatically shut down, fully protecting everything connected to it. As soon as the power levels on your power line return to acceptable levels, the power on the Dectet is restored, thus protecting everything connected from potential damage. Using proprietary IsoZone technology, the Dectet provides independence and improved clarity between equipment when isolated through one of the three zones. Bring life back into your system and music back into your home with the Dectet Power Conditioner.
IsoZones
Isolation helps soundstage imaging by reducing the interaction between components, resulting in far better separation of instruments and voices. Because the Dectet's filtration is handled by our large-core, heavy-gauge, magnetic filtration devices, there is never any negative impact, such as dynamics or musical energy lost, when isolating equipment via the IsoZones. For source equipment the Dectet provides two isolated and filtered zones that provide both common mode as well as differential mode filtering. The high sensitivity to power line issues that most source equipment is prone to can be handled through one of these two source IsoZones. Because there are two identical double filtration IsoZones designed for sources we recommend you place all of your digital equipment into one and your analog products into the other for best performance. Dedicated star wiring, IsoZones, and our famous Power Port AC receptacles ensure the Dectet restores what's missing to your system.
Protection
An electrical surge, or spiked transient, is an intense, short-duration voltage increase that travels through electrical wiring in our homes. It can severely damage connected equipment. Shielding devices from these potential electrical problems is mandatory if we're to protect our investment and ensure the safety of our homes. These electrical transients are not the only potentially damaging problems faced by our sensitive audio systems. There are also sustained over-voltage conditions that many surge suppression devices will not be able to protect equipment from. Owners who have invested in a Dectet can rest assured their connected equipment will be safe from any power line event such as over voltage, surges, spikes and potentially threatening problems. The input voltage to the Dectet is fully protected by state-of-the-art clamping devices. The output of the Dectet will automatically shut off in the case of overvoltage conditions so even large voltage swings that would normally damage connected equipment are made safe.
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
