Physical |
| Unit Weight | 22 lbs [9.97 kg] |
| Unit Dimensions | 17” x 14” x 4” [ 36cm x 43cm x 10cm] |
| Shipping Weight | 31 lbs [14 kg] |
| Shipping Dimensions | 20.5”x 24” x 10” [52cm x 61cm x 25cm] |
Power requirements |
| Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
| Power Consumption | 60W |
Audio inputs |
| Coaxial RCA single ended XLR Balanced |
5 5 |
| Input Impedance Unbalanced (RCA) Balanced (XLR) |
33KΩ minimum 66KΩ minimum |
| Sensitivity | Unbalanced 1.3V/33KΩ Balanced 1.3V/66KΩ |
Audio Outputs |
2 2 |
Analog Audio Output |
| Output level | 4.0 Vrms |
| Output Impedance | <100Ω |
| Frequency Response 20-20KHz |
+/- 0.1dB |
| THD&IM @ 1KHz (full scale) | <0.03% |
| Bandwidth | -3dB 0.1Hz - 200kHz |
DC Triggers |
| +12V | 2 |
Headphone Performance |
| Output Power 300Ω 16Ω > |
>200mW 4.0 Watts |
| S/N Ratio | >90dB (1KHz) |
| THD & IM 1 volt out | <0.02% |
| Output Impedance | <0.5Ω |
BHK Signature Preamplifier - Factory Certified
Note:
Design
Applications
Overview
Inside Story
The Build
Features
19 key featuresZERO-LOSS VACUUM TUBE INPUT STAGE
12V AND 6V TUBE SWITCH
COUPLED & BALANCED MOSFET OUTPUT STAGE
THROUGH-HOLE CONSTRUCTION
PRP RESISTORS IN SIGNAL PATH
5x RCA SINGLE ENDED INPUTS
5 XLR BALANCED INPUTS
SINGLE ENDED & BALANCED INPUTS
FULLY BALANCED INPUT TO OUTPUT
OVERSIZED POWER TRANSFORMER
BHK DESIGNED MOSFET VOLTAGE REGULATORS
BHK DESIGNED MOSFET HEADPHONE STAGE
REMOTE CONTROL
STANDBY BUTTON FOR VACUUM TUBE STAGE
-3dB > 200kHz
VOLUME & BALANCE THROUGH GAIN & ATTENUATION CONTROL
2x OUTPUT DC CONTROL TRIGGERS
EASY ACCESS TO TUBES FOR CUSTOMIZATION
EACH INPUT CAN BE SET TO HT BYPASS
Reviews
0 reviewsNo reviews yet for this product.
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
