BHK Signature 250 Stereo and BHK Signature 300 Mono |
| Unit Weight | 83 lbs [37.6 kg] |
| Unit Dimensions | 17.1” x 8.7” x 14” Chassis only. 15" deep including connectors. |
| Shipping Weight | 92 lbs [41.7 kg] |
| Shipping Dimensions | 21”x 13” x 19” |
| Color Options | Black Silver |
| Voltage Options Factory set only |
Japan 100V North America 120V Europe/Asia/Australia/New Zealand 230V |
| Mains Power Inputs | IEC C14 |
| Fuse Compliment all Countries | 4 - 10 amp fast blow H-Rated 5x20mm Rail Fuses |
| Fuse Compliment Mains |
100vac Countries 1 - 2 amp slow blow H-rated 5x20mm 1 - 12 amp slow blow H-rated 5x20mm 120vac Countries 1 - 2 amp slow blow H-rated 5x20mm 1 - 10 amp slow blow H-rated 5x20mm 230vac Countries 1 - 1.6 amp slow blow H-rated 5x20mm 1 - 5 amp slow blow H-rated 5x20mm |
| Accessories Included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS 1363) (230V version) |
| Audio Inputs | RCA (Unbalanced) XLR (Balanced) |
| Speaker Outputs Signature 250 | Gold plated copper binding posts (2 pair per channel) |
| Speaker Outputs Signature 300 | Gold plated copper binding posts (2 pair) |
| Other | DC Trigger Input 3.5mm 5-15VDC |
| Warranty | 3 years parts and labor on unit 1 year on vacuum tube |
Power Consumption |
| @Ready | 75 Watts |
| @Idle | 175 Watts |
| @Rated power 8Ω | 850 Watts |
| @Rated power 4Ω | 1600 Watts |
Signal |
| Gain | 30.5dB +/-0.5dB |
| Sensitivity for rated output power of 250 watts into 8Ω | 1.3V |
| Noise | 100-20KHz <-85dBV |
| Input impedance Signature 250 stereo | Unbalanced 100KΩ Balanced 200KΩ |
| Input impedance Signature 300 mono | Unbalanced 50KΩ Balanced 100KΩ |
| Output Impedance | 50Hz, 2.8VRMS <0.1Ω |
| Frequency Response | @2.8VRMS 10Hz – 20KHz +/- 0.1dB 10Hz – 200KHz +0.1/-3.0dB |
THD&IM |
| 1KHz, 1W/8Ω | <0.01% |
| 20-20KHz, 1W/8Ω | <0.1% |
| 1KHz, 200W/8Ω | < 0.1% (120VAC Mains input) |
| 1KHz, 400W/4Ω | < 0.1% (120VAC Mains input) |
Signature 250 Stereo Amplifier |
Output Power |
Both channels driven 120vac mains, 1kHz, 1% THD |
| 8Ω | 250W minimum |
| 4Ω | 500W minimum |
| 2Ω | Stable for musical transients |
Signature 300 Mono Amplifier |
Output Power |
| 8Ω | 300W minimum |
| 4Ω | 600W minimum |
| 2Ω | 1000W |
BHK Signature 250 Amplifier - Factory Certified
Note:
Discontinued from new production in 2025
Design
Applications
Overview
Input Stage
Output stage
Features
16 key featuresZERO LOSS INPUT TUBE
POWERFUL MOSFET OUTPUT STAGE
THROUGH-HOLE CONSTRUCTION
RCA SINGLE-ENDED INPUT
XLR "TRUE" BALANCED INPUT
250 WATTS PER CHANNEL 8Ω
500 WATTS PER CHANNEL 4Ω
2Ω STABLE
-3dB > 200khz
< 0.1% THD 20Hz - 20kHz AT RATED POWER
DAMPING FACTOR = 100
FRONT PANEL STANDBY BUTTON
BALANCED INPUT TO OUTPUT
DUAL, COPPER, PLATED, OUTPUT BINDING POSTS
83 LBS.
INPUT 12 VOLT TRIGGER
Reviews
0 reviewsNo reviews yet for this product.
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
