The floor
The floor
Most of us spend a lot of time thinking about the back wall, the front wall, the ceiling. But one of the most underrated parts of the listening space is right under your feet.
If you’ve got hardwood, tile, or concrete, and not much on top of it, you’re living with one of the biggest reflection surfaces in the room. Sound, especially in the upper mids and lower treble, bounces right off that hard surface and heads straight into your ears—just milliseconds behind the direct sound. That time gap is enough to blur details, especially from vocals, strings, and cymbals.
Now, if your speakers are on stands or have elevated tweeters, that bounce is even stronger. You're getting a delayed copy of every transient arriving from below, and your brain starts blending the two into a single, fuzzier image.
The solution? A rug.
Doesn’t have to be fancy. Doesn’t have to be thick enough to lose a shoe in. But it should cover the space between your speakers and your seat. Ideally, with some texture—pile, fringe, anything that helps scatter and absorb.
Sit and listen to a favorite track. Then toss down a folded blanket between you and the speakers and listen again. You’ll hear it: tighter vocals, sharper edges, more presence. It’s one of the cheapest upgrades you can make—and one of the most obvious once you know what to listen for.
Floors are great for lots of things, but stereo imaging isn't one of them.
The floor
The floor
