Reflections
Reflections
We all know how direct sound works—speaker fires, you hear it. But the real challenge in any room comes from reflected sound. Especially the first bounce off the side wall.
That’s called the point of first reflection, and it’s one of the biggest factors in how clean your stereo image sounds.
When sound bounces off the side wall and into your ear just milliseconds after the direct wave, it interferes. Not in an echo-y, big hall kind of way—but subtly. It arrives just late enough to blur detail, especially in the upper midrange and low treble. That’s where your brain gets its spatial cues—location, separation, and presence.
When those cues get smeared, the whole soundstage collapses inward. Imaging gets fuzzy. The space between instruments fills in like fog rolling over a field.
So how do you fix it?
Simple: scatter or absorb that first reflection (my preference is always to scatter).
Bookshelves work great. Not neatly organized rows of books, but messy, mixed-depth books and objects. The goal is to break up the wave, not just soak it up. Irregularity is your friend.
Heavy curtains can help too, especially if they’ve got some folds or texture. So can thick wall hangings, acoustic panels, or even a strategically placed piece of furniture.
The key is to find the spot where that reflection is happening. Sit in your listening chair and have a friend move a mirror along the side wall. When you see the speaker in the mirror, that’s the point of first reflection. That’s where you treat.
You don’t have to go full studio. Just a bit of texture, mass, or irregularity in the right spot can clear the air between you and the music.
Reflections
Reflections
