Scratchy sound
Scratchy sound
 A record can be factory fresh and still crackle like a campfire.
That's rarely your fault.
New vinyl arrives with surface noise baked in — clicks, hiss, rumble that has nothing to do with how carefully you lowered the needle or how clean your stylus is. Some pressings are whisper quiet.
Same label. Same artist.
Different outcome.
Pressing quality is the big one — how clean the stamper was, how the PVC behaved that day, whether the plant rushed a run to hit a deadline. Static loves fresh vinyl. So does debris from the sleeve. A record can leave the factory and arrive at your door already carrying a layer of trouble you didn't put there.
Your system isn't broken.
Your table isn't failing you.
And that's the part that drives us crazy — because we want vinyl to be the romantic medium, the one that rewards ritual, and sometimes the ritual is perfect and the artifact still fizzles through the quiet passages.
Clean what you can. Store it well. Upgrade the pressing when there's a better one.
But don't spend any time cursing the heavens above when the vinyl was noisy before you ever hit play.
Some records are quiet.
Some never were.
Scratchy sound
Scratchy sound
Different outcome.
Some never were.
