Million dollar babies
Million-dollar loudspeakers are becoming more commonplace.
The same could be said for a few thousand-dollar ones that make people happy for decades.
The question isn't whether ultra-expensive gear is better. Some of it absolutely is — better drivers, better cabinets, better crossover parts, years of voicing in a room that actually listens. Chris Brunhaver doesn't design an Aspen speaker in an afternoon. The work is in there.
The question is what you're paying for when the number gets silly.
At some point you're not buying better sound per dollar.
You're buying better sound, period — and the last ten percent of anything hard costs more than the first ninety.
Diminishing returns aren't a myth. They're the law.
A well-set-up modest system in a good room will embarrass a neglected expensive one every time. Placement matters. Synergy matters. Recordings matter. Half the problems people blame on price are really setup problems wearing a tuxedo.
And yet.
There is a floor below which you're mostly paying for packaging. And there is a ceiling above which you're paying for the pursuit of something fewer and fewer companies are still willing to chase.
The price tag tells you what something cost to build.
It doesn't tell you what it will do in your room.
Listen first.
Then do the math.
And yet.
Listen first.
Then do the math.
