GIGO
GIGO
"Garbage in, garbage out" gets repeated so often in audio circles it's become furniture. And it's true — I'm not here to argue otherwise. But there's a more important truth that doesn't get nearly enough attention: it doesn't matter how pristine your source is if your speakers can't tell the truth about it.
Speakers are the only component in your system that makes physical contact with the real world. Everything upstream — your DAC, your preamp, your amplifier — operates in the clean, controlled domain of electrical signals. Speakers have to convert all of that into actual air movement, in an actual room, with all the acoustic complexity that entails. That's an enormously harder job, and the margin for error is vastly wider.
Think about what a loudspeaker has to do. It has to reproduce frequencies spanning ten octaves simultaneously. It has to do it with vanishingly low distortion across a dynamic range that can swing from a whisper to a full orchestra. It has to image convincingly, disappear into the room, convey micro-dynamic shadings, and do all of this while interacting with a room that's fighting it at every low frequency.
No other component faces anything remotely like that challenge.
Swap a great source into a mediocre speaker system and you'll hear an improvement. Swap great speakers into a system with a good-but-not-great source and the transformation is immediate and dramatic. The speakers set the ceiling for everything. A resolving, honest loudspeaker will reveal just how good your source already is. And often, it's better than you thought.
The source matters. Get a good one and stop worrying about it. Then put your serious money and serious attention where the music actually meets the air.
That's where the magic either happens or it doesn't.
GIGO
GIGO
