Stellar S300 Stereo Amplifier |
| Unit Weight | 13 lbs [5.9 kg] |
| Unit Dimensions | 17”W x 3”H x 12”D (13"D w/connectors) |
| Shipping Weight | 16.5 lbs [7.5 kg] |
| Shipping Dimensions | 22”W x 8”H x 17”D |
| Color Options | Black Silver |
| Voltage Options (Factory set only) |
Japan 100V North America 120V Europe/Asia/Australia/New Zealand 230V |
| Mains Power Inputs | IEC C14 |
| Idle Power Consumption | 13W |
| Accessories Included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS 1363) (230V version) |
| Audio Inputs | RCA (Unbalanced) XLR (Balanced) |
| Speaker Outputs | Copper base nickel plated binding posts (2 pair per channel) |
| DC Trigger Input | 3.5mm 5-15VDC |
| Warranty | 3 years parts and labor |
Signal |
| Gain | 30.5dB +/-0.5dB |
| Sensitivity for rated output power | 1.01V |
| Noise | 1kHz@300 Watts < -100dB |
| Input impedance | Unbalanced 50KΩ Balanced 100KΩ |
| Output Impedance | 50Hz, 2.8VRMS <0.007Ω |
| Damping factor | 50Hz. 2.8VRMS 8Ω >1100 4Ω >550 |
| Frequency Response | 2.8VRMS into 4Ω 10Hz – 20KHz +/- 0.5dB 10Hz – 50KHz +0.1/-3.0dB |
THD&IM |
| 1KHz, 1W/4Ω | <0.02% |
| 10-20KHz, 1W/4Ω | <0.02% |
| 10-50KHz, 1W/4Ω | < 0.05% (90kHz BW) |
| 1KHz, 37.5W/4Ω | < 0.01% |
Output Power |
Both channels driven 120vac mains, 1kHz, 1% THD |
| 8Ω | 140W minimum |
| 4Ω | 300W minimum |
| 2Ω | Stable for musical transients |
S300 Amplifier
Design
Application
Overview
The Analog Cell
Output Stage
Features
16 key featuresSTEREO POWER AMPLIFIER
DUAL MONO WITH SEPARATE POWER SUPPLIES
POWERFUL MOSFET OUTPUT STAGE
RCA SINGLE-ENDED INPUT
XLR "TRUE" BALANCED INPUT
140 WATTS PER CHANNEL 8Ω
300 WATTS PER CHANNEL 4Ω
2Ω STABLE
VERY LITTLE HEAT PRODUCTION
< 0.1% THD 20Hz - 20kHz AT RATED POWER
DAMPING FACTOR > 550
FRONT PANEL STANDBY BUTTON
ZERO-LOSS INPUT
DUAL, COPPER, PLATED, OUTPUT BINDING POSTS
13 LBS.
INPUT 12 VOLT TRIGGER
Reviews
6 reviews
The PS Audio Stellar S300 stereo amplifier is a terrific performer and an affordable option for those wishing to upgrade from a receiver or integrated amplifier to separates. It's not often that an audio product exhibits such high-end performance at such an affordable price, but the S300 hits it out of the park on both counts and has high-end build quality to boot. It's the perfect amp for someone looking to enter the world of separates for two-channel playback in a small to medium-sized room
Read full review →
They sounded so good together I couldn't bring myself to try too many other speakers. The sound was rich with resolution to die for. Magnepan speakers aren't known for their deep bass punch, but here with the two Stellars the .7 speakers' low bass was kicking with "The Legendary Skatalites in Dub" reggae album with really low, feel-it-through-your-toes bass. Austin Wintory's orchestral score for "The Banner Saga" sounded downright huge, and the low bass drums definition was truly stellar!
Read full review →
Most vivid were dynamic contrasts from the micro level to the macro.
Read full review →
Folks, this is the future. We have heard vast improvements of Class D amplifiers during the last 10 years, and we are at or near the point where the technology is largely irrelevant to the final sound. The sound of audio components is more dependent on the implementation than on the underlying technology. The PS Audio Stellar S300 gets so close to perfection that the low purchase price is an out-of-this-world value. The PS Audio Stellar S300 adds nothing objectionable while delivering wonderful
Read full review →
The Stellar DAC/Pre-Amp/Power Amplifier filled my listening room with 3D sound, and they matched well with each of my speakers; the floor standing Audio Physic Tempos, the stand mounted Platinum Audio ST 1's and the low-to-the ground Mission 727s. I was surprised how different they made each sound and I spent a great deal of time swapping out my Parasound Halo 2.1 integrated amplifier, Bel Canto s300 integrated amplifier to make sure I wasn't fooling myself. And, yes, I was hearing something new
Read full review →
The result of all these strengths gives the S300 a beautiful voice which mates well with the variety of upstream gear we had on hand for testing. It holds its own against components that exceed its price tag. This PS Audio component deserves a spot on a short list of bargain amps that perform beyond what one should expect for the money. After a few weeks with the S300 in my reference system, I must admit I am smitten with it. I applaud PS Audio's new approach to circuit design bringing together
Read full review →Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
