Stellar DAC
Stellar DAC
Couldn't load pickup availability
Design
Application
Technology
Think of the Stellar DAC as the gateway to building a high-performance audio system at a down-to-earth price. Whether your dream system's main source of music is digital, or you're building a hybrid of both vinyl and digital, Stellar DAC offers great sonics that can bring a level of musicality to any system. Stellar DAC supports pure DSD, asynchronous USB, Digital Lens technology, I²S to connect to our best transport, balanced throughout. Replace your preamplifier, your DAC—or both—and be stunned at the level of improvement when the full and rich tapestry of music surprises and delights your senses. The Stellar DAC is the perfect foundation for those on a budget but are unwilling to compromise sound quality. Rich. Lush. Powerful. A music lover’s answer to spiraling cost-no-object equipment without sacrifice. In the more than fifty years of PS Audio’s design innovations and breakthrough products, Stellar’s groundbreaking level of performance as our gateway standalone DAC is unmatched for price and performance by its standalone competitors.
Features
Specifications - Stellar DAC
Physical | |
Unit Weight | 22.5 lbs [10.2 kg] |
Unit Dimensions | 17"W x 3"H x 12" D [43.18 cm x 7.62 cm x 30.48 cm] |
Shipping Weight | 26 lbs [11.8 kg] |
Shipping Dimensions | 22"W x 8"H x 17"D [55.88 cm x 20.32 cm x 43.18 cm] |
Color Options | Black Silver |
Power requirements | |
Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
Power Consumption | 25W |
Digital audio inputs | |
Inputs | I2S (2), Coax (2), Optical, USB |
Sample Rates | I2S: 2 inputs - PCM 44.1KHz to 384Khz, DSD64, DSD128, DSD256 Coax: 2 inputs - PCM 44.1KHz - 192KHz Optical: 1 input - PCM 44.1kHZ - 192KHz USB: 1 input - PCM 44.1kHZ - 384KHz - DSD64, DSD128 (native) - DSD64, DSD128 (DoP) |
Analog Audio Output | |
Connector | RCA single ended, XLR balanced |
Output Level High, Maximum | 4 VRMS Balanced 2 VRMS Single Ended |
Output Impedance | 100Ω / 200Ω |
Frequency Response | 20Hz-20kHz, +/- 0.1dB 10Hz-55kHz, -1dB |
Max Output | 4V RMS Balanced, 2V RMS single-ended |
THD+N @ 1KHz (full scale) | <0.003% at full output |
IMD | <0.004%, CCIF, at full output |
SNR | 110dB, referenced to 4V RMS |
Data Handling | |
Format | PCM or DSD |
Sample Rate (PCM) | 44.1kHz, 48.0kHz, 88.2kHz, 96.0kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz |
Word Length (PCM) | 16-32 bit |
Data Rate (DSD) | Up to DSD256 (11.2MHz) Native |
Digital Volume Control | Yes |
Analog Conversion | ES9018K2M DAC Chip |
I2S Digital Input | |
Connector | HDMI |
Format | PCM or DSD. DoP on all inputs as well as native DSD on |
USB Digital Input | |
Connector | USB "B" Type |
Format | PCM, DoP v1.1 (DSD over PCM), or Native DSD |
Transfer Mode | Asynchronous |
