<strong>The Power Port is a high-end AV grade AC receptacle that will make a significant contribution to your system’s performance.</strong>
At the heart of everything we do with AC power is the interface between our equipment and our power sources; the AC receptacle. Unfortunately, standard AC receptacles are made from cheap brass that does not provide the best levels of conductivity. The Power Port™ is a custom built, isolated ground, 15 to 20 amp receptacle that will insure a life-long level of excellence and superior conductivity. The Power Port exceeds hospital grade for grip strength, contact resistance and current delivery. Easy to install in your wall, this is one component you need in your listening room. 15 coats of polished nickel over high-purity brass, with the “grip of Mickey Mantle” and polished nickel plated hardware, this a must have in your system.
In stock
$49.00
The PS Audio Home Experience
Hear it. Live with it. Love it.
There’s no better way to know if new gear truly belongs in your system than to hear it at home — in your room, with your music.
With the PS Audio Home Experience, you can audition any new product for a full 30 days in the comfort of your home.
Let it burn in, settle into your system, and decide at your own pace.
If it’s not the perfect match, simply return it — no questions asked.
Trading up? No worries. Keep your current gear until you decide, then send back whichever you’re not keeping.
Experience music the way it was meant to be heard — right where you live.
Purchase or Audition Locally
Contact an authorized dealer in your area:
Save up to $12 on your PowerPort Classic
Your old gear is worth more than you think. We'll give you full original retail value for your trade-in equipment, applied directly to this purchase—up to $12 maximum trade credit. Try it risk-free for 30 days—love it or return it.
On the product page, simply press the Trade Up and Save button on selected products and complete the Trade Up information as requested on the Trade Up form. PS Audio offers full, original retail manufacturer price value back as an immediate credit towards your new purchase.
Adjusted Retail Price:
Upon check-out, we will only charge you the Adjusted Retail Price.
The PS Audio Sales Team will review all Trade Up claims within 48-hours. We will authenticate the original retail manufacturer price value of your Trade Up, and we will call or email you if we see any discrepancies. Once you receive an order confirmation from us via email, your Trade Up proposal has been accepted.
We will also email you an RMA with an RMA Number, which you can write on the box or shipping label, which you can use to return your unit. You will have 30-Days to return the Trade Up.
What we accept in trade:
We will accept nearly any HiFi make and model. We ask for component-level product in trade. What's component-level mean? Component-level refers to any high-quality stereo product such as a preamplifier, power amplifier, DAC, phono stage, loudspeaker pair, turntable, headphones, or CD transport. We require that all Trade Up gear is functioning. Additionally, all Trade Up gear must have respectable cosmetic condition.
What we do not accept in trade:
We do not accept broken or non-functioning product. We do not accept most accessories, phono cartridges, power cables, or interconnects. Exceptions can be made based on the value of the accessory or cable. Go ahead and enter your Trade Up for quote, and the PS Audio Sales Team will review your proposal. We work hard to accept every trade we can.
Can I Trade Up multiple items?
Heck yeah! You can trade multiple items for value back up to but not exceeding the credit-cap. Just click "Add Another…" at the bottom of the Trade Up form.
I don't know if PS Audio can accept this Trade Up…
Don't worry, you have options:
Call us, you will speak with a real person: 800 PSAUDIO (800-772-8346)
Email us, and a real person will write you back: sales@psaudio.com
Trade In Your Equipment
We'll purchase your trade-up equipment and apply that credit towards your PS Audio product. Add up to 5 items from any manufacturer.
Quick Select (Optional)
Select your PS Audio product to add it to your trade-in
PS Audio Trade-Up Items
Other Manufacturer Items
Other Brand Item #1
Total MSRP Value:$0.00
Your Trade-Up Credit:$0.00
Original: $49
Your Price: $49
Design
The Power Port contacts are cast from the highest purity non-ferrous material available: pure OFC copper and beryllium to maintain excellent grip. The OFC copper contacts are then plated with a high phosphor electroless nickel coating, free from flux-density and power supply issues. nce the electroless nickel plating has been added to the OFC copper connectors, each Power Port goes through a final step before insertion into the body of the receptacle. Each contact is hand polished to improve the surface smoothness and hence an increase in surface area and better conductivity. The main body of the Power Port is a UL approved polycarbonate material while the front cover of the Power Port is a glass fiber filled high temperature nylon, both excellent dielectrics.
Application
Power Port AC receptacles should replace any standard wall outlets connected to your stereo or home theater system. To install a Power Port takes about 10 minutes. Turn off the power to the outlet. Remove the cover plate. Remove the two screws affixing the existing receptacle and pull the receptacle out from the box. Using a Phillips screwdriver, simply disconnect the wires from the existing plug and place them on the Power Port. Reverse the removal procedure and you are done. Not only will the Power Port ensure that your system will always be provided with as much power as your listening habits require, but it will also give you peace of mind that your AC wall plug is no longer the weak-link in your power chain.
Overview
You spent a great deal of time, money and personal effort building a great sounding music or home theater setup and in all likelihood, you’re feeding it less than great power. Everything we see and hear in our AV systems starts out as raw AC power. The unrestricted quality of that power has a great deal to do with the performance quality of our systems. Garbage in, garbage out. If you're serious about sound and video quality, replacing your home's cheap brass power receptacles is the first step. The Power Port is among the finest AC receptacles made. Hospital grade, and using high purity copper with 15 coats of polished nicer as conductors, the Power Port is a must have in a high-performance system.
What's In Your Walls?
Most every home in the US and Canada has a 15 amp duplex NEMA socket in the wall. Some have 20 amp versions, most have 15 amp varieties, but all are basically the same. These receptacles are constructed out of low-grade brass with very little care as evidenced in their purchase price of under $1.00. They are very poorly built, have poor grip, lower surface area and tend to build up oxidation "barnacles" on the untreated brass, which hampers connectivity. Poor connectivity and loss of surface area from the contacts interacting with airborne pollution spells audible degradation for audio systems and increased visible noise for video systems.
Why AC Receptacles Matter
AC power is the source for everything we see and hear through our media systems. Whether a 2-channel audio setup or a multi-channel home theater, AC power supplies everything needed to bring music and pictures into our homes. The quality of that raw power impacts our system's performance. Just as cables make a difference, so too do the contacts and connectors gluing everything together into a system. The receptacles in our homes are made from cheap brass that will oxidize and over time suffer conductivity issues. These can be helped by constant cleaning, plugging in and out to remove oxidation and airborne pollutants. Or, simple replace with the Power Ports and never worry again.
Features
11 key features
15 COATS POLISHED NICKEL
15 OR 20 AMP READY
IMPROVES IMAGES
EASY TO INSTALL
CLEANS THE SOUNDSTAGE
OPEN, AIRY, TOP END
IMPROVES MID RANGE BLOOM
WILL NOT DEGRADE OVER TIME
IMPROVED CONNECTIVITY
LOWERS APPARENT NOISE FLOOR
AV GRADE
Reviews
0 reviews
No reviews yet for this product.
Write a Review
Share your experience with PowerPort Classic
Thank You!
Your review has been submitted successfully. We appreciate you taking the time to share your experience.
Review
Loading review...
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
