Physical |
| Unit Weight | 22 lbs [9.97 kg] |
| Unit Dimensions | 14” x 17” x 4” [ 36cm x 43cm x 10cm] |
| Shipping Weight | 31 lbs [14 kg] |
| Shipping Dimensions | 20.5”x 24” x 10” [52cm x 61cm x 25cm] |
| Color Options | Black Silver |
Power Requirements |
| Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
| Power Consumption | 30W |
Media |
| Optical discs | SACD/CD/CD-R/CD-RW/ DVD-R*/-RW*/+R*/+RW* (*Audio data file only) |
| USB Drive | USB Flash Drive with audio files |
| Supported File Formats | MP3/WMA/AAC (~48kHz/320bps) WAV/FLAC/AIFF (~192kHz/24bit) ALAC (~96kHz/24bit) DSD (~5.6MHz) |
Outputs |
| I2S | 1 I2S output for PCM and DSD (raw) |
| Coax | 1 output for PCM and DoP |
| BNC | 2 outputs for PCM and DoP
Use in tandem for double-rate DoP |
| XLR Balanced | 2 outputs for PCM and DoP
| RJ45 and WIFI | Ethernet and WIFI for over-the-air code updates |
PerfectWave SACD Transport
Discontinued from new production in 2025
Design
Application
Overview
Galvanic Isolation
DSD Master Layer
Features
17 key featuresSACD/CD/CD-R/CD-RW/DVD-R*/-RW*/+R*/+RW* (*Audio data file only)
PLAYS MP3, WMA, AAC, WAV, FLAC, AIFF, DSD, 2xDSD, AND ALAC FROM DISCS OR USB INPUT
2x BNC (COAX) OUTPUT FOR PCM AND DOP. USE IN TANDEM FOR DOUBLE-RATE DOP
USB DATA INPUT FOR STORED DIGITAL MEDIA
SACS DSD LAYER AVAILABLE THROUGH I2S OUTPUT
ADVANCED DIGITAL LENS TECHNOLOGY
I2S OUTPUT FOR PCM AND DSD (RAW)
2x XLR OUTPUT FOR PCM AND DOP. USE IN TANDEM FOR DOUBLE-RATE DOP
MEMORY PLAYER TRANSPORT
GALVANICALLY ISOLATED OUTPUT STAGE
1x RCA (COAX) OUTPUT FOR PCM AND DOP
LARGE ANALOG POWER SUPPLY
SEPARATE POWER REGULATORS
FPGA SIGNAL PROCESSING
NEAR-FIELD LATCH PLACEMENT
ZERO SETUP, JUST PLUG AND PLAY
REMOTE CONTROL
Reviews
4 reviews
Although audio streaming is good, there is nothing like listening to digital music with the PS Audio PerfectWave SACD Transport in the chain. SACD (DSD) is on another level for digital listening. So I squeezed every ounce of music from Redbook and SACD (DSD) by using the PST connected to the PS Audio DirectStream DAC
Read full review →
The PerfectWave SACD Transport was consistently better than the other transports I threw against it in almost every category. It took my digital front end to a level I did not know it was capable of. Limitations that I previously thought were inherent in the Redbook format were significantly reduced, primarily in the areas of soundstage depth and the resolution of low-level detail. What it does for Redbook CDs may be worth the price of admission in itself. I spent many a night listening to CDs
Read full review →
The sonic superiority of the PerfectWave was evident within moments of hitting Play and hearing Chet Baker's floppy vocals from the soundtrack to Let's Get Lost. All of his spit, wit, and loose-toothed wisdom entered the Barn's space as if nothing stood in between the recording and me but air
Read full review →
DOING THE IMPOSSIBLE: PS Audio PerfectWave SACD/CD Transport unboxing and review.
Read full review →Want to leave your own review?
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
